Rotate screen - Computers & Internet
Screen won't rotate
Screen won't rotate at all - Android Forums at AndroidCentral.com
forums.androidcentral.com > ... > Verizon Galaxy S3
Aug 4, 2012 - 25 posts - ‎22 authors
So far this is the absolute best phone I have owned hands down. I have a small but annoying problem of the screen not auto rotating, or rotating ... Samsung Galaxy S6 Screen rotation won't work
Apr 18, 2015
Note 4 problem - Screen won't rotate
Apr 12, 2015
S6 Edge - Screen rotation does not work properly
Apr 10, 2015
Screen won't rotate
Jan 3, 2015
More results from forums.androidcentral.com
Jan 17, 2016 | Tablets & eReaders
My FaceTime screen is at 90 degrees
  1. Verify that screen rotation lock is off. If you see this symbol in the status bar, rotation lock is on: lock_rotate.png Follow the steps below to turn off screen rotation lock.
    • Swipe up along the bottom of the screen to display Control Center (you can do this from any screen, including the Lock screen).
    • Tap the Screen Rotation Lock button.
    • If the button was highlighted, the button will appear dimmed after tapping it.
  2. Not all iOS apps are designed to rotate. Some may use only portrait or landscape mode, or switch depending on the content. To test screen rotation, open the Calculator app that comes with your device. If the screen does not rotate as expected while using the calculator app, continue troubleshooting.
  3. If the issue persists, restart your iOS device.
  4. If the screen remains locked, back up and restore your device.
Oct 05, 2014 | Apple Ipad I-pad
My acer screen is sideways. how do i fix it?
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
Apr 11, 2013 | Acer Computers & Internet
Rotate screen back to normal
Feb 23, 2013 | Gateway Computers & Internet
My Samsung n120 screen is displaying only vertically - how do I go back to horiz display?
Feb 15, 2013 | Samsung N120-12GW Netbook
My screen does not flip 180 degrees when i turn the screen around
Jan 28, 2013 | Panasonic Toughbook 19 Rugged Notebook -...
My son has rotated the screen on my fujitsu lifebook s series so now it is upside down! How do i rotate it back? Please help!
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish. Hope this helps
Jan 21, 2013 | Intel S6240 Notebook
Acer tablet troubleshooting
b>
Jan 14, 2013 | Computers & Internet
Change screen orientation
b>
Dec 14, 2012 | Dell Computers & Internet
P c screen upsidedown
Hope this helps
Oct 20, 2012 | Fujitsu Siemens ESPRIMO MOBILE V5535...
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
