Question about Coby Televison & Video
My COby tv wont turn on.
I was messing with volume settings since my shows volume were fine but the commercials the volume would blare loudly. I believe I hit an "execute" option. The screen went black but the volume remained. I was not able to do anything. Eventually I turned the TV off thinking it would reset and now it won't turn on.
    New Friend:
I unplugged my TV for 5 minutes after 5 minutes I pressed the Power button on the side of the TV not the power button on remote for a full minute. Plugged the TV back in, pressed the power button and it turned on. Doing this essentially does a reset.
Posted on Feb 21, 2017
  • 81 Answers
SOURCE: TV turns on......eventually
check for a bad cap ,relay sound ok or could be a bad solder connection in the power supply at the regulators
Posted on Dec 15, 2006
joey64
  • 209 Answers
SOURCE: PS2 screen won't show on tv set to game
try to trouble shoot if the wire is the problem, how? remove the 3 colored wires from the tv and ps2 then try to use the red color instead of yellow to the video from tv and ps2 (both red) temporarily do not use the yellow color. once a picture appears use now the white for the audio (both white) for left audio once there is a sound you may try the yellow for the right audio. i hope this will help you and hear a positve reply from you.
Posted on Dec 03, 2007
  • 223 Answers
SOURCE: Toshiba 50hp66
I think that the pop you heard was an electrolytic capacitor blowing its top on the picture frame board. If you are able to check this for yourself by looking on the board for the one/s with a bulging top or are a brownish/black colour like something has caught fire. And also in this situation smell can be of great help as it will smell burnt out but PLEASE before putting your nose or anything else in the tv take all necessary precautions against electric shock and discharge any electrolytic capacitors in the vicinity. If you are not able to do this yourself find a competant technician. Hope this helps.
Posted on Oct 07, 2008
SOURCE: commercials come on and volume is louder than tv shows
Volume and video levels for live broadcast, as well as satellite feeds are preset at a master control panel prior to broadcasting. TV commercials are pre-recored via satellite feeds, on seperate equipment, where audio and video levels are set manually by a technician. These manually set levels are very difficult to match, since the levels on the master control panel change. When the master control technician switches control to mark, a robot, mark loads the commercial and it is broadcasted, hence the different audio levels.
Posted on Mar 15, 2009
  • 117 Answers
SOURCE: My Sylvania LD320SSX is royally messed up, while
try unpluging it
Posted on Jun 24, 2010
Volume for my COBY 32" Television is out to whack.
Your volume control/circuits are fubar. Coby is outta business so getting parts for it might prove next to impossible.
Jul 20, 2017 | Coby Televison & Video
Coby 32" Television, Volume is messed up.
Coby is apparently out of business.
Feb 12, 2014 | Televison & Video
What is the problem with the Vizio TV volume, it seems that when I am watching a show the volume goes up and down; it just blast up, especially when commercials come on.
There is nothing wrong with your TV. The loud commercials are to catch your interest before you leave the room for another snack or beer. You are not alone here, all other brands of TV will act the same. You may opt into the menu settings and seek an automatic volume control for commercials. Many TVs will have one. Not all, but just some. Thanks for asking and show a few hands of support!
Mar 26, 2011 | Vizio E420VO 42 in. LCD HDTV
I just bought a Coby home theater system 5.1 surround sound dvd/cd/ player model#765. I've got it all hooked up but I have one problem, when I want to listen to my tv stations through the home theater...
Hi - Your Home Theater System and your TV should have separate volume controls. You should be able to control each individually. Start by checking the volume level on your TV with your HTS shut-off. Turn the volume on your TV all the way down to 0.
Next, turn your HTS on and check the volume level there. Is it still loud? If so, try turning the volume down on your HTS. That should do the trick. If its not loud then you know you can control the volume on either the HTS or the TV. If this answer does not help, then please write us back with a little more detail. Thanks.
Feb 28, 2011 | Audio Players & Recorders
Randomly my volume is as loud as it can get no matter what. Whether the volume is on 1 or 60 it is blaring. Turning the volume to zero is still muted...anything I can do to fix this problem?
I turned my television off and unplugged it for a few hours and when I plugged it back in and turned it on... the volume worked like normal again. Woo
Nov 18, 2009 | Durabrand DWT2704 TV
Sound on my rca tv
I wonder if your problem with loud volume occurs primarily on commercial breaks, when you turn down
the sound and then, since the sound, for the program itself, is so low in volume, you have to turn it way
up again to enjoy the program?
If this is the case, and there are no other problems with the set, this may not be the set's problem, but the
fact that commercial material is broadcast at a higher volume than program material by some outlets, so
that while you are in the kitchen, during commercials, the sound of the commercial can still be heard.
Apr 18, 2009 | RCA Televison & Video
Low volume on some channels
Well, some TV stations do broadcast at different volume levels. This is very noticeable when watching a TV show and the volume seems normal and then when a commercial comes on, the volume is very loud. They do this to get you to pay attention to the commercial. Another problem might be that you are adjusting volume from both your TV and your cable box. What you should do is make sure your cable box is set to "FIXED VOLUME" and then just adjust your TV volume. Fixed volume will have the cable box output only one volume level, letting the TV do the adjustment. Just go through your cable box setting and look in the audio settings. Hope This helps...
Mar 14, 2009 | Element Electronics FLX3711B 37 in. LCD TV
TV volume equalizer
Ear-jarring volume discrepancies between television shows and commercials may be a thing of the past if Motley Fool Stock Advisor selection Dolby Labs (NYSE: DLB) persuades TV manufacturers to include its new technology in their sets.
We're all familiar with the phenomenon: We're reclining in our Barcaloungers, calmly watching the late show when a commercial comes on and the volume has suddenly increased 10 decibels, causing us to spill our beer as we jump for the remote control. Dolby says its new Dolby Volume technology will make that rude awakening a thing of the past.
The technology is pretty important for Dolby, because systems incorporating its surround sound technology make the experience that much more jolting when it occurs. It might not be as jarring on your rabbit-ears set in the kitchen, but on that 60-inch plasma screen with five, six, or seven high-def speakers pointed at your cochlea, it can leave your ears ringing.
Dolby will unveil its volume control system at the Consumer Electronics Show Monday in Las Vegas, and the company hopes it will start appearing in television sets by year's end.
The difference in volume occurs because programmers try to compress the sound to boost volume without exceeding the limits the government has set. While most televisions today are equipped with circuits that are designed to stabilize the differences between TV shows and commercials, they are not necessarily effective and can still be problematic if the broadcaster fails to properly operate equipment on its end. Part of the problem: Depending on the type of program a commercial is inserted into, the commercial might actually be broadcast at too low a volume. While viewers might not consider that a problem, advertisers would, so generally, broadcasters transmit the sound all at one level.
Audiovox (Nasdaq: VOXX) recently came out with a device to help minimize sound differences by automatically detecting when a television has gone to commercial and lowering the volume for you. Dolby seems to go one better than this.
First, its technology isn't an external box that needs to be hooked up to the television set. We've already got enough wires crawling from our sets with DVD players, cable boxes, game systems, and whatnot. A sound "equalizer" might just be too much.
Dolby instead offers one chip that would be part of the set's components. (According to some reports, Cirrus Logic (Nasdaq: CRUS) has spoken highly of the development; it may wish to partner with Dolby to put the technology on its chips.) The technology then mimics how the human ear works, and how people perceive changes in loudness because of various factors. Dolby then created formulas to have the technology react to those factors to create a more even experience. It believes it could be applied to MP3 technology as well.
Perhaps another area where it should be investigated is cell phones. Despite advances there, sound quality has never been all that good, but Q Sound Labs (Nasdaq: QSND), another surround-sound developer, is using its MobileQ technology to provide a surround sound experience on close-proximity speakers and headsets. With advertising moving to mobile phones, quashing loud commercials before they begin could be a big seller.
Let's hope Dolby's technology proves popular, if only so that another drop of beer will never be spilled while jumping to turn down an annoying commercial.
Want to see what other high-decibel recommendations have been made in Stock Advisor ? A 30-day guest pass gives you full access to all the market-beating selections.
Fool contributor Rich Duprey owns shares of Dolby but does not own any of the other stocks mentioned in this article. You can see his holdings here. The Motley Fool has a disclosure policy.
May 12, 2008 | Transparent French TV Commercials, Volume...
Sci Atlanta 8300 DVR HD sound in HD channels soft - analog channels OK
Experience has shown that with this relatively new mode of transmission, audio levels can be quite dynamic. If your set provides it, you may try turning on "Audio Compress" or whatever the name might be. Could also be called Dynamic audio also or some such. Reason for all the hubbub is that along with HD, mixing engineers are also providing the most range for the audio dynamics as well the most video composition info in the new broadcasts...Accordianman.
Oct 11, 2007 | Televison & Video
Televison & Video Logo
91 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
