Question about Nespresso D250 Espresso Machine
Where can I find parts for a nesspresso d250 espresso machine
My machine isnt working
I've had this issue a couple of times. The water just goes straight through to the drip tray and the pod doesn't get pierced. The first time it was fixed under warranty but the 2nd time Nesspresso wanted $150. I took the back off the machine myself (very easy, just unplug it from the wall, remove the 4 screws and unclip the back cover) and saw that the $3 flowmeter had been replaced at the first repair (it had a date on it which was after we purchased the machine). It's the white thing at the bottom right and very easy to remove, (Take a photo of it so you know which way it goes, then just pull off the electric plug, unclip it and take off the 2 water tubes). I couldn't see anything wrong but blew through it a few times and put it back...........its since been working perfectly for over a month now, (I think microscopic solids from the water supply can block it). The whole process shouldn't take more than 10mins.
Jul 21, 2014 | De'Longhi EN720M Lattissima Premium...
My Nesspresso machine is a U.S. Version machine and uses 120VAC 60 hertz power input, and it is used on a private aircraft using a 120 VAC 60 hertz power converter. When plugged in an turned on the small...
I don't know if you already solved the problem, but did you check what the maximum output power of your aircraft is? The nespresso machine needs about 1250 Watts, which is a lot of power. A vacuum cleaner or microwave use less power than that (maybe between 800 - 1000 Watts). Maybe that difference is the reason. Also, you mentioned that you converted from 220V 50Hz to 120V 60Hz. I think you only converted the voltage, a frequency converter would cost thousands of dollars.
Jan 18, 2011 | Nespresso Citizmilk C120
How to use the astra coffee espresso
Hello there:
here is a couple of links that will help you get the right manual that you need ok?
best regards michael
  1. CoffeeGeek - Espresso: Espresso Machines, Astra Boiler Level Control ... i got the user manual, and a parts list from Astra, and am attempting to ... Expertise: I love coffee. Espresso: LM GS3. Grinder: Mazzer. Vac Pot: have one. Drip: no ...www.coffeegeek.com/forums/espresso/machines/407128 - Cached
  2. CoffeeGeek - Espresso: Espresso Machines, need help understanding my ... Astra recommends a particular type in their user manual, but there are better ... Expertise: I love coffee. Espresso: Astra Pro. Grinder: Macap M4 & Digital M4, BV ...coffeegeek.com/forums/espresso/machines/378621 - Cached
  3. Espresso Grinders Coffee machines, Grinders,parts, Slush machines ... HGS007 Astra home espresso grinder with timer for direct ... MDF manual. MDF Exploded diagram. Virtuoso Conical Burrs Espresso Grinder. Virtuoso user's manual ...saecoparts.com/EspressoGrinders.html - 235k - Cached
  4. Astra Espresso Machines Espresso machines, Grinders, parts, Slush ... Astra Mega III Manual rocker switch dosing 220V 5500 Watts 18 liter boiler ... All Astra machines operate with ground coffee and / or pods interchangeably - no ...www.partsguru.com/AstraEspressoMachines.html - 162k - Cached
Sep 15, 2009 | Coffee Makers & Espresso Machines
No function when i pushe smalle or big cup
Dear,
My wive bought a new nesspresso machine.
I will keep my old machine for repair parts for my mother, she has simullar machine.
greetings
Dec 26, 2008 | Krups Nespresso 554
Nespresso D250
I can send you a copy by e-mail
Apr 27, 2008 | Nespresso D250 Espresso Machine
Nespresso C100B
800-562-1465 is the phone number for Nesspresso.
They can direct you to the local parts outlet.
Feb 18, 2008 | Nespresso C100B Essenza Single-Serve...
Nespresso D250 Espresso Machine Logo
41 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
