Question about Bosch Dishwashers
What is the proper wiring set up for a siemens/bosh dishwasher control panel 5wk52014
This is for a bosh dishwasher.
Kenmore dishwasher clean button constantly flashing ,washer has been unplugged ???maybe reset itself did not work. 2 yrs old
please follow this steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 09, 2013 | Dishwashers
Dishwasher Siemens /se64m359gb tap light comes on in red on main display,what does this mean?
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jul 08, 2013 | Dishwashers
Siemens dishwasher has stopped taking in water red light on indicating this problem, I have checked water supply that's ok
Click this link for tips : Inlet valve
Check the voltage to the valve to confirm that the control panel is working,
Jan 24, 2013 | Siemens Dishwashers
Dishwasher bosh SCH4c02UC does not start- power does not turn on.
Hi, I would start by first shutting off the breaker. Then removing the kick plate ( access panel at the bottom ) and checking the wiring at the junction box for the dishwasher 120vac supply line. This is actually quite common to find a wire connector come loose due to improper fastening and once the unit is in use for a while the connections heat & cool, become loose from normal operating vibrations and burn up from all the added heat caused by "resistance". The end result is no power to the controls. Check it out and post back what you find. Thanks for visiting "fixya" and please take a moment to rate the solution/suggestion provided here for you. Good luck. Macmarkus :)
Apr 24, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
An electrician switched off the power whilst doing other work. Power was restored OK. But when we came to use the dishwasher there appeared to be no power to it i.e the control panel remained blank. We...
Maibe the internal fuse of the dishwasher blow for a spike, check first if you have power at the socket if so is highly posible that you have a blown fuse in the dishwasher
Nov 13, 2009 | Siemens Dishwashers
Bosh Intergrated dishwasher not powering up...nothing at all
Check the circuit board in the control panel. Look for a burn mark on the relay board. This is the heater relay circuit. Push the tabs back around the connector areas, use a flat blade to pop the cover open.
Sep 07, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Siemens SE64A630 GB I got a tingle up my arm when holding the dishwasher and touching my sink. I checked and when the dishwasher is plugged in, there is 24VAC between the dishwasher door and the stainless...
I would say it is an earthing problem, check over your earth wires, normally black and grey is neutral, check to make sure your earth wires are connected properly, and tight, better to completely turn appliance off by disconecting power plug while doing this, take care not to play around with the wires too much to prevent a nasty electric shock
Jul 01, 2009 | Siemens 24 in. SE64A630GB Built-In...
Control Panel
See:
http://www.siemens-home.com/pdf/sl84a30xuc_manual.pdf
There is a pic with the buttons in there.
Aug 13, 2008 | Siemens 24 in. SL84A305UC Built-in...
BOSH SHU43 dishwasher
From my experience.. usually when a motor is humming it could be something is stuck in your impeller.. if your can get to your drain pump to check it out.. and getting to your drain pump can be a pain.. good luck.. hopefully that works
Jul 17, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosh dishwasher not starting
Since the power is fine, now to get to the issue. You will need to pull the front panel and see if there is power to the on/off switch. There should be the same as what is at the junction box of the incoming power. If there isn't the proper voltage there, then you have a broken wire. If the voltage is there, then check the voltage going over to the control with the on/off switch in the on position. If power there and not lighting up or starting. Then the control is bad.
Jan 19, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
