Question about KitchenAid Kitchen Ranges
Gas kitchenaid gas stove code F02. Turned off breaker seemed to cool down at first now getting warmer. Can't open oven door, like it is cleaning. What do Ido now?
  • KitchenAid Master
  • 3,197 Answers
Shut off the breakers and GAS make sure the oven has completely cooled... This may take a significant time
without the aid of the cooling fans...
While you are waiting the requisite HOURS....
Look up your model number on reputable parts sites..
I will list below.
The most likely failure point is a simple heat sensor... (thermal switch" which SHOULD HAVE released your door IF INDEED it
was cool enough (this is VERY critical).
My KGRS807SSS00 Model Overview from PartSelect com
http://www.appliancepartspros.com/
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Don't hesitate to call KITCHAID themselves...
They ARE SUPPOSED to be GOOD....
I DISAGREE... but that just my opinion... as a
disappointed OWNER of their "STUFF"
ServiceBench
Posted on Jan 24, 2017
aborcass
  • 2651 Answers
SOURCE: KItchenaid supera gas stove
thers is a thermal cut-offs under the main control area little black thermostat one controls display andother turns fan on/off
Posted on Feb 24, 2008
  • 2336 Answers
SOURCE: Kitchen Aid KGRA806PSS
Check HERE for more info.
Posted on Mar 03, 2008
SOURCE: GE Spectra XL44 Gas Oven, flashing "Locked Door". Can't use oven or close door
I had the same problem happen tonight. I have an XL44 self-cleaning gas range. We unplugged it for several minutes and pressed 'cancel' a bunch of times--neither worked. We finally lucked out--opened the oven door and pressed a black button on the upper left side of the front of the oven. It turned out the flashing words and unlocked our door. Weird. There was nothing in the manual about this...
Posted on Dec 28, 2008
MNTECH
  • 1543 Answers
SOURCE: brand new gas stove. When oven is turned on there is a heavily gas smell.
There have been reports of gas ranges which have been installed with no leveling legs. (due to various reasons, like a new floor installed, but the counter tops stayed in the same place, so the range surface would be higher than the counter top if the legs were installed) In some cases, this results in an insufficient amount of combustion air for the oven. To test this, put the range up on a set of 3/4 inch or so blocks and try the oven again. Let me know how that went. Thanks.
Posted on Apr 29, 2009
  • 17 Answers
SOURCE: I have a kitchenaid gas range and the door is stuck in lock
hold the oven door lite switch closed and put it on selfclean it should activate the door lock
Posted on Nov 14, 2009
No power on stove after using self clean oven door is locked and cant be open is there a braker swith somewhere
A self cleaning oven that won't open after the self cleaning cycle is usually the oven has not had time to cool down from the high temperatures of cleaning. You should wait at least an hour to open it. You can also try to unplug the unit or turn of the breaker to the over for at least five minutes. You will then have to reset the clock and then try to move the door lock. If that does not work, you can set the self clean cycle again for but only allow it to work for 15 minutes, then cancel the cycle and let the oven cool and then again try to move the door lock or open the door If that does not work, then the lock will have to be accessed and moved manually to open the door
Some ovens need the door to be manually unlatched before the controls are set to the off position before they can be unlocked.
Mar 07, 2011 | KitchenAid Ovens
Ran self cleaning oven now the door will not open and all the electric will not work.. thank you
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Oct 13, 2010 | KitchenAid KGST307 Gas Kitchen Range
Oven went dead in self clean mode and the door remains locked. Is this the thermostat? How do I get the door unlocked when control panel shut down? Kitchenaide KGRA806
Unplugged the stove and turn off the gas.Take the back off the oven and replace the thermostat. It's super easy. Before you buy the part call kitchen aid... this is a known problem. They will say the parts are not free and try to give you a discount. But if you continue to argue , they'll send it for free.
Mar 02, 2010 | KitchenAid KGRA806PSS Gas Kitchen Range
KitchenAid electric range KERS807SSS02 -in the middle of cleaning cycle, NO power outage but panel went black and door remains locked even after cooling. Circuit breaker not the problem. Top elements work.
We have a Kitcheaid gas stove and have had 3 new thermostats installed. After the 3 time it finally did it's first full cleaning cycle.
So three service calls later, (first was after the warranty) and three thermosats and over $500 and the stove has done it's first full cleaning.
Lots of examples of this same problem but it seems no recall on the stoves.
Jan 08, 2010 | KitchenAid KDRP407HSS Dual Fuel (Electric...
VIKING STOVE DOOR IS LOCKED AND WILL NOT OPEN , STOVE WAS IN A SELF CLEANING MODE AND DOOR WON'T OPEN AFTER CYCLE COMPLETE
unplug or turn off breaker to stove for 10 minutes...then try to gently open.....the oven has to be completely cool before it will unlock....when cleaning is done release lock before turning cleaning off
Nov 28, 2009 | Viking VGSC306-4B Gas Kitchen Range
Kitchenaid gas/convection stove oven door locked & won't open
F5 - E7 Self clean latch will not unlock
Remedy:
1. If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
  2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Note: Applies to all F5-E... codes.
Sep 17, 2009 | Ovens
I have a KGST300 gas freestanding range. I tried to run self clean, but immediately after starting I canceled, as I forgot to remove the oven racks. The process stopped, and the door unlatched, but I...
The manual for your range suggests you call 1-800-422-1230 for error assistance.
sorry i couldn't be of more assistance but this should get you on the right direction
Dec 01, 2008 | KitchenAid KGST300 Gas Kitchen Range
By the way the door lock error will stay there until the oven cools. Once it has cooled it will go away. the reason is in a self clean the oven is supposed to get very hot to clean. The door lock is for your protection. once it has cooled down enough the door lock will go away.
Dec 01, 2008 | KitchenAid Kitchen Ranges
White westing house stove cant open oven door
try pushing self clean then cancel or stop/clear
Jun 11, 2008 | Frigidaire FGB24S5A Gas Single Oven
Feb 08, 2008 | KitchenAid KESC307 Electric Kitchen Range
Kitchen Ranges Logo
621 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
