Question about Kenmore Refrigerators
What is the storage capacity of a white kenmore fridge model number 970-678720
4 Suggested Answers
  • 10865 Answers
SOURCE: What is the capacity of my washing machine?
This washer has a capacity of 13 pounds.
Posted on Feb 09, 2009
  • 39 Answers
SOURCE: kenmore side by side not cooling
First off how far did it get leaned when moved and second it might just need to be cleaned.
If you laid it down when it was moved it should have been left unplugged for 12 hrs before plugging in because the refridgerant used is also a lubricant and it needs time to settle.
As far as cleaning it you will need to take off the back panel and use a vac to clean out the dust.There is also a kickplate on the front that needs to come off and clean the cooling grates that are under there.If you have a dryer brush it works great for cleaning the grates.You can get between them with it.
Unplug it before you do any of this.
Posted on Oct 22, 2009
  • 3 Answers
SOURCE: I am looking for the dimension and capacity of fridge 69852990
Measure Exterior Height & Width and Depth for Dimension.
Interior Space = Then, Measure all open accessible area inside the fridge and add the two together, following the formula of H+W+L Freezer and H+W+L Refrigerator,add together and BAM ya got cubic inches.= Square inches, then divide by 1,728 (the number of cubic inches in a foot (3) Cubed.
Example 1: 60 inches tall, 42 inches wide, 30 inches deep = 75600/1728 = 43.75 Cubic Foot AREA
Example 2: fREEZER dIMS = 24 DEEP x 18 HIGH x 36 WIDE =15552/1728 is 9 CuFt. Refridgerator 36 wide, 36 high 28 deep = 36,288/1728 = 21 CuFt. + 9 CuFt. = 30 Cubic Foot Capacity.
By the Math Wiz RUDY :)
Posted on Apr 18, 2010
What is the cubic feet of Kenmore refrigerator 253.77872509?
The fourth digit after the prefix usually indicates the refrigerator capacity. It probably has 27 cu. ft. capacity. (If it is a small apartment size fridge would be a 17 cu. ft. model.)
I hope this helps.
May 05, 2017 | Kenmore Refrigerators
How many cubic feet is Kenmore Coldspot Refrigerator Model 10674254400 Serial ER3139075
Kenmore appliance model numbers have a three digit prefix (106 in this case) for the manufacturer. The rest of the model number indicates a lot of the specifics for the refrigerator. The third digit is the second group indicates the capacity. This fridge is a 22 cubic foot model (or slightly smaller).
I hope this helps.
Apr 15, 2017 | Kenmore Refrigerators
How do I work out the storage capacity in liters for my fridge Frigidaire FPC523TEW1?
Hello Howard;
My name is Peter. I am a retired field service refrigeration technician.
Near the top side wall inside your freezer there is a label that gives you the exact cubic feet. Your model number has a rounded off cubic of 23.
So,
23 Cu.Ft. x 28.316 = 651.218 Liters.
Mar 13, 2015 | Frigidaire Freezers
What is the size of my kenmore 253.77879506 top freezer fridge
This appears to have been sourced from A. B. Electrolux (Frigidaire) but Sears does not supply a capacity. The outside dimensions can help determine the capacity as most 18 cu. ft. units will be approx. 66" high while 21 cu. ft. models will be 68" high (or higher.)
Oct 22, 2014 | Kenmore Refrigerators
I just need the specifications/dimensions of my Kenmore Elite Refrigerator, model #106.54609300. I need a new fridge of similar size to fit in an enclosed space. I have searched all over the web and...
I have this exact model. Here are the specs:
depth: 30"
height: 68.5". with hinge: 69.5"
width: 35.5"
15.5 cubic feet in the refrigerator section
10.0 cubic feet in the freezer section
25.5 cu ft total
Sep 08, 2011 | Kenmore Refrigerators
Need a replacement shelf/drawer for my Kenmore fridge
Good day
For starters you can try here. It may list the model number.
Be sure the model number is correct.
On Kenmore machines the model number always starts with a 3 digit number followed by a dot and then the balance of the model number. For example 106.12345678
http://www.appliancepartspros.com
Jul 18, 2010 | Kenmore Refrigerators
Apr 18, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Kenmore refrigerator and unknown capacity specs
It should be 25 cubic ft. It is usally the first few numbers in the model number.
Phil
Apr 10, 2009 | Kenmore Refrigerators
Kenmore fridge stopped working
While not specific for your model number, this Kenmore manual has lots of information about changing fuses, checking wiring, etc. https://www.appliancefactoryparts.com/content/pdfs/145975-2.pdf
Apr 12, 2017 | Kenmore Refrigerators
Refrigerators Logo
76 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
