Question about Optics
Doesn't shoot bb out - Optics
Is there a city ordinance prohibiting shooting birds with a BB gun or pellat gun from front porch?
Yes that is against the law. Not only shooting the birds but discharging a gun and yes even a BB gun or Pellet gun in city limits is a misdemeanor.
Apr 03, 2017 | Washing Machines
When i pump the action lever 10 to 12 times and prepare to shoot it the bb rolls out of the barrel. what do you think is wrong
your head there is nothing in the barrel that HOLDs BB's inside . they will always roll out when the end is lower than the stock .
Sep 26, 2015 | Toys
I have a crossman 1377 (177) cal pellet pistol. Is it ok to shoot BB'S in this gun? Does it damage the rifling in the barrel? Thanks, Gary
yes it safe to shoot bb,s in the 1377 pump pistol,i have 3 of them they actually shoot true'er and with more vilocity
Sep 19, 2011 | Crosman 1377 177 Single Shot Air Pistol
I just got my son a crosman 760 pumpmaster bb gun and we cant figure out how to shoot it. we loaded it, but for some reason it isn't shooting the bb's out
Are you pumping the gun??? Once you have bb's in the gun you have to **** it and then pump the foregrip 10 times then pull the trigger.......
Apr 24, 2011 | Sport & Outdoor - Others
I have a Crosman Pulse R71 Model SAPR71. Its a Soft air gun using plastic BB's. When I shoot the gun, it has no power. The battery is fully charged but it seems like there is not enough power to shoot...
I had the exact same problem.. turned out to be that the cylinder wasn't lubricated properly so it wasn't sliding well.. I dripped some lubricant down the barrel and it shot like a champ! (ps, I used the wrong lube and I'm too lazy to look up the correct lube, but either way, that's your problem)
Apr 24, 2011 | Toys
I work the lever to load one BB. then pump 6 or 7 times. BB will not shoot out. When I pull the trigger, it sounds like it is shooting, but no BB comes out. this is for a crosman 760 pumpmaster. it...
Can you see through the barrel? Or run a rod down the bore? It sounds like the BB is either falling out the end of the barrel or the BBs are getting jammed up in there. Do not hold your hand in front of the barrel to see if any air comes out. You might get stung with 10 BBs. Hope this helps.
May 22, 2010 | Crosman ® Quest cal. Air Rifle with 4x32...
My daisy buck 400 shot repeater bb gun wont shoot
bazthespazz i would like that file you said, just bought the daisy buck 400 and got jammed arround the first 20 shots nd i want to repair it but its hard to remove the piece of the trigger
Jul 30, 2009 | Toys
Daisy Red Ryder BB gun won't shoot
1) **** the gun and look through the hole in the top, half way down the barrel.
2) You should see a BB loaded into this area.
- if no bb is present and you can see a circular magnet, then it is not loading.
3) if the bb is present and does not exit the barrel when you fire the gun, then the bb is deformed and will require the rifle to be dissasembled and rodded through the back side, forcing the bad bb out of the way.
4) If no bb or magnet is present through the hole, call daisy for a replacement. This indicates the shot tube has moved and will no longer load.
Apr 05, 2009 | Toys
Optics Logo
20 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
