Question about Sewing Machines
Making 2layered tulle skirt sandwiched between 2 laters of fleece. Machine worked until sewing top layer to other 3 layers. bottom of project was mess. Took Machine apart cleaned it, no better
Newhome memory craft 4000
bargainbox
  • 1388 Answers
SOURCE: bobbin thread bunching
I agree with brodering about the damage to your bobbin case, it should be smooth all over, as the thread travels across the top surface to form a stitch, and the small step on the underside locates it as the hook spins underneath.
Needle strikes often compromise the surface, as will the hook colliding with the under surface... and although it is possible to gently polish off the damage with fine grain wet & dry (black) sand paper (emery paper) there are limits to the success depending on the degree of damage.
While on the subject, ensure the bobbin case and hook race beneath are clean and free of lint or thread.
For a guide as to setting tensions and the rest, look here
Posted on Feb 24, 2008
SOURCE: CLICK AND GRIND IN 270D BROTHER SEWNG MACHINE
This happened to me and I discovered that my presser foot was stuck up. (LOL) I was using embroidery and the needle was actually brushing against the raised presser foot. So, I turned machine off, removed embroidery part and checked the presser foot switch. It was not moving. Well, I put the machine on regular sewing and just turned the wheel a few times and the presser foot reset. When I went back to embroidery all was fine (and still is). so, check yours.
Posted on Dec 26, 2008
louislevel_2
  • 374 Answers
SOURCE: Thread looping on top and bottom of fabric
hi! there,
on this condition,you can avoid wasting time and material try on this, the problem is your set up of tension thats why.,but you should follow upper theading. see figure,c978815.jpgthis just sample of exact threading,next bobbins set up see fig.the thread should be clockwise rotation on winder5a00a72.jpgfollow this set up,and upon inserting be sure
you have clean feed dogs and shuttle race free from fabrics and threads chips.set dial tension to #3 to #4 and stitch dial to #12.then try this set.and you can watch on you tube sewing. try this stuff on internet address type www.youtube.com then on search box type sewing machine,have enjoy and have a nice day.don't forget to rate me,
Posted on Apr 14, 2009
bargainbox
  • 1388 Answers
SOURCE: Sewing machine not stitching at all
SIX Layers !!!!
You really need a size 16 needle that won't bend and miss the hook by the sound of it....can you sew on less challenging thicknesses OK ??
If not, the timing may need adjusting...here is a link to assist:
HERE
Posted on Aug 02, 2009
chris592
  • 86 Answers
SOURCE: janome memory craft 4000 manual online
You can find it here:
http://ifixmachines.com/index.php?page=shop.product_details&product_id=776&option=com_virtuemart&Itemid=54
Posted on Nov 16, 2010
Why do stitches bunch when using walking foot on 3 layers of quilting fabric?
make sure that the thread tensions are correct for the thickness of material
remember that only the bottom foot walks and draws the material through so it may need a help and be pulled as it sews.
I find that women in sewing shops just love to talk about problems and how they can help so find a shop and discuss any problems with them
May 08, 2015 | Brother PC420-PRW Project Runway...
I'm working with 2 layers of cotton for most of a project but part of it is 2 layers of terry cloth in addition to the cotton and I keep running into trouble with my bottom thread. I'm very new to sewing,...
well, Rose, i could make a few suggestions- but, my wife is the guru of sewing machines- will turn her loose on it later- what make & model? sounds heavy duty. later.
Nov 03, 2013 | Euro-Pro Sewing Machines
Janome 6260 not stitching properly. skipping stiches on top and bunching on bottom
New needle, clean under bobbin case and look at this.......Looping thread underneath is a top thread tension issue...
I have written a 5 page illustrated Tutorial on overcoming this problem....HERE
Nov 23, 2011 | Janome 6260QC Computerized Sewing Machine
I cannot get the tension right on my 2600 Brother machine. I am stitching in the ditch with three layers of material. Can you please help?
Make sure you have the right size needle...not to small. Then do a simple seam through three layers (doesn't need to be a seam just sewing through 3 layers of scrap) using a wide zig zag stitch. Examine the stitch looking at both sides. Do they look even, identical?
Think in opposites, ie the bottom thread tension affects the stitch on the top side and the thread tension on top affects the stitch on the bottom side. If one side is loopy then the opposite side tension is too loose (or, sometimes that side's tension is too tight). Adjust until both sides are identical looking. Then try stitching in the ditch like you wanted to.
Mar 30, 2011 | Brother XL-2600
How do you lessen the pressure on the presser foot for sewing fleece?
On some machines there is a knob on the left the top or a recessed screw that is used for adjusting the pressure.
You may find you will get better results if you use a walking foot when sewing fleece or any other type of fabric where the layers tend to shift during the sewing process.
Mar 17, 2010 | Singer Quantum XL-1000 Computerized Sewing...
What tension setting should I use for6 layers of polar fleece on my brother PS 1800?
Depending on the thickness of fleece I would go back about 1-2 settings, being that your tension on bottom is already set correctly
Nov 30, 2009 | Brother PS-1250 Pacesetter
SIX Layers !!!!
HERE
Jul 31, 2009 | Janome 1017 Mechanical Sewing Machine
Difficulty sewing quilt blocks
Try using a "walking foot" presser foot. It has feed dogs on the top to help all the layers go through evenly. A generic brand usually fits most all machines. :)
Jan 17, 2009 | Kenmore 15212 Mechanical Sewing Machine
Kenmore 15343
No problem :) I have been using this machine to make all sorts of things. The thick and thin layers issue is mainly in just having too much. I have been trying to design my own re-usable moon pads, and there are many layers to that, and depending on what fabric you are using (I have been using a combo of fleece, felt, waterproof layering and more fleece), but it handles it just fine as long as I adjust the settings to take on that thickness, and don't run the stitching at full speed. I have made some curtains, pillows, blankets, patchwork purses, etc......and I have been so happy with it. There is enough variety of stitches to keep preoccupied with for some time, and it comes with an overlock foot and stitch which is really nice, since I don't have a serger, but can still get that "serged look".
Not to mention that being a belly dancer, learning to sew and make my own costuming is just priceless. In my humble opinion, couldn't be happier with it and it's great for all around.
Have a great night!
Natalyn
Nov 11, 2008 | Kenmore 15343
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
