Question about Samsung Washing Machines
I cant get any help from Samsung to repair my washing machine been a month now with zero results!! I've been calling every week because they give appointments to fix but do not show up. PLEASE HELP
Already had dish network come out for the recall that is done now my washer will not complete a cycle and pause button doesn't work!!! A lot of people are getting ripped off. model # WA400PJHDR/AA SERIAL # Y69Q5AUF201644B. PLEASE HELP...
    Master:
  • 507 Answers
Oh bummer.....please tell me what is exactly going on with the washer it may seem like the control board/diagnostic board in the washer is having issues and may need replacing im sorry how samsung is treating you...
Posted on Jan 05, 2017
Testimonial: "I had to go out side samsung to find the problem it the mother board and rods for the tub. the problem is it will not complete a cycle get to spin become unlevel and resets to longer wash cycle every time on every different cycle so the machine will run all day on one load if I let it witch I do not stopped using it..."
Coldcut
  • 1554 Answers
SOURCE: Maytag Nuptune Washer
These units seem to all use the same control board and have the same issues. the intermittent and door lock issues are random and frustrating. it will take a person that wants to fix it. see this link for what to do. I have other links that explain the same.
http://www.fixya.com/support/t364216-whirlpool_duet_ht_ghw9400pl0
Posted on Jan 29, 2008
  • 142 Answers
SOURCE: Hotpoint Aquarius wd440 washer/dryer wont pump out water HELP!
Try unplugging the unit and plug it back in. This may reset the controls.
Posted on Jun 02, 2009
SOURCE: FI Code on Sears Oasis Washer
Called the recall dept. for Sears. Have an appointment set up for two weeks.Gave them my serial number and model number. The said if the parts show up prior to the two week time frame...call them and we could re-schedule the appointment.
Posted on Aug 17, 2009
blueextc3221
  • 15935 Answers
SOURCE: My front loader model WBVH6240FWW fills with rinse
This is indicative of a failed controller board.
- more to follow -
Posted on Sep 24, 2009
Testimonial: "Thank you for the advice. I figured it was something like that. Will pass the info along to hubby and go from there."
  • 3 Answers
SOURCE: GE washing macine stops during the wash cycle
This is exactly what my machine was doing, as well. I fixed it by cleaning out the filter in front of the water pump.
Searching here, I found that you can remove the lower front panel (three screws along the bottom edge is all it takes) to get to the filter. With the panel removed, you'll see a round white plastic cover (about 3-4 inches diameter) that screws out. Get a bucket under the cover to catch the water that's in it (could be 2 quarts or more) and unscrew the cover.
The cover pulls out, revealing that is actually a screw-in plastic strainer. I found tons of coins, broken pens, paper clips, etc. in mine when I did this. A lot will be deep inside the black rubber hose that connects this filter housing to the washer drum. You can rake the stuff out with a bent wire clothes hanger. Shaking the black hose will help hurry the junk along and out of your machine. Screw the cover back on after the clean out and your machine should go back to normal.
Thinking about it, front loaders will have lots of small items flushed into the pump compared to top loaders. Coins you alway found in the bottom of the drum in a top loader, they all wind up in the filter of a front loader. And once it slow the drainage to a crawl the machine will shut down multiple times when it can't drain the water out completely, and it will never step up to it's max spin speed with all that water still in the drum.
Posted on Nov 30, 2009
I have samsung waching machine j1453s every time i turn it on it gives 2 H then me LE and beeb beeb and i cannot start it ,, i tried many times but it gives the same result note that the two letters L...
Do you still have your Samsung manual? If not I would recommend you down load it from the Samsung website -just to have on hand for further problems. I can honestly say that I don't remember what the code stands for but it could be a plugged filter which is a big problem with Samsung. Should be drained every 3 months
Feb 14, 2012 | Samsung Washing Machines
My Samsung washing machine model WA80D5V, one month old is not working, water is not flowing in and none of the other functions are working, cleaned water in and out filters, no result. Pse suggest the...
Hi, W/D here.
My best suggestion would be to contact Samsung via telephone and have them issue a service request. Their warranties are very good, and you should have no problem getting your machine repaired free of charge. The phone numbers are listed at Samsung.com.
Best regards, --W/D--
Jan 30, 2011 | Samsung Washing Machines
Our front loading washing machine washer got damaged (pen drive got stuck). We complained in July.The machine continued to wash well for another one month. The samsung Customer care staff came on 24/8/10...
Well, if parts are not available, there is little that you can do with that machine. You can try non Samsung, like independent appliance stores, they have parts, often.
Oct 06, 2010 | Samsung Washing Machines
Sir, My name is krishnaveni. I brought a samsung washing machine on 07.07.10. It was repaired on 21.07.10. I complained to customercare then service man come and cure it. Then after 18.08.10 on that...
Please call the customer care again and inform them and give your complaint number to them Or As this is a brand new machine contact the dealer from whom you got the washing machine.They will contact the service people and will get them to do the repair.
thank You
Sep 02, 2010 | Samsung Washing Machines
I have a Hoover vhd sensor Dry Washer Dryer and its come up with error E11. Can you help ?
Hi I had the same problem about once a week and every time it happened I had to turn off the washer off and leave for a while and start new wash cycle. It worked for a while but eventually it started to throw E11 once I put it on (not the middle of cycle it used to do). I had to result to call the repair man. He checked all the hardware and nothing was wrong and re-install the program on the board and it stopped throwing errors. After 4 month of problem free period, it gave me E11 again today though..
Jun 23, 2010 | Washing Machines
Where do you get parts for Samsung p801 washing machines?
Any repair company on here answering queston for samsung appliances could help you in some way
give one of them a call or do a search in your local area.
example : go to google or yahoo and type samsung washer parts (((( your area )))) (((( your state )))
May 24, 2010 | Washing Machines
My new washing machine (Samsung WF8602), has a permanent Red flashing light on. The symbol is of a lock with a key in the centre, the same as on computers, to verify secure websites. I have pressed the...
i got same model today, i rang samsung and they said it was a known fault that was under investigation by there engineers. they said it shoud be fixed with an upgrade but in the meen time it was nothing to worry about.. they said to keep checking there website for news on the upgrade then to call them back... i checked there website and cant find anything about it... ill give it a few weeks then ill ring them again...
Jul 05, 2009 | Samsung Washing Machines
Funny noise when machine is emptying
service before you have real problems!
Sounds like the coupling connector from the trans. to the agitator is worn and ready to fail.
Bless you
ngafm
Please give me a good rating for my accurate call!
happy to be of service.
Jul 24, 2008 | Estate TAWX700JQ Top Load Washer
Washing Machines Logo
54 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
