Question about RCA Televison & Video
How to scan for Chanel's when using a converter box with a locked rca truflat tv
SOURCE: unlock rca truflat tv with no remote
Buy a universal remote and program it for the TV. That's the only thing that will work.
Posted on May 05, 2008
SOURCE: rca converter box need 3 digit code
Samsung 005 013 079 080 145 177 195 202 213 216 227 255 256 260 266 274 275 282 295
RCA 001 005 072 073 074 075 076 077 078 135 138 140 144 150 156 159 162 163 169 171 178 229 246 249 260 274 275 293 302
Panasonic 040 045 125 179 187 254 257 288 299 301
Posted on Sep 14, 2008
maatmartin7
  • 1210 Answers
SOURCE: 27F520T RCA Truflat, won't scan for channels, auto or manual, only blue screen, no channels on tv
You need to replace the microprocessor. GoodLuck there is 52 pins to unsolder and resolder a new one. The price for the chip may bee about $35
Posted on Jun 26, 2009
rulds2008
  • 3866 Answers
SOURCE: My RCA truflat tv won't turn on? It is only like
Could be a fuse in the unit or a bad powersupply i would have a estimate done on it before repair gets started as a newer tv would cost less if this was a major issue.
1. check fuse
2. check power supply unit
If you do not know how to do this would recommend you take it to the experts as there is serious high voltage that can be fatal inside, Please do leave postive feedback and ratings for your free answer today.
Posted on Oct 24, 2009
gopakumarg43
  • 74106 Answers
SOURCE: I accidentaly turned the FPA
Hello
It will be very difficult to unlock RCA TVs without its orginal remote control handset. Anyway just try this, This is the actual proceedings to unlock the RCA TV with its original remote. If you fail to do this with your present universal remote control, just buy an new original one from RCA Authorised Service Center at tyour town, or just borrow it from any of your friends or relatives; just to unlock your set. After unlock, you can use the universal remote control. Just follow the proceedings given below. One amoung them must unlock your RCA TV.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK.
Posted on Aug 24, 2011
CHANEL SCAN A RCA TV CONVERTER BOX
If the box has been installed correctly, you should be able to press SETUP (or some equivalent) on the remote to display a menu of choices including channel scan.
Jan 03, 2015 | RCA Analog (RCA) to Digital (VGA)...
Do i need a converter box for my rca true flat 27 in? if not how do i connect a digatal antenna i have lost my manual
Your TV will require a Digital Converter Box to recieve over the air Digital Television Signals. You will need to hook up the antenna to the converter box and then hook your converter box to the TV. Hooking your television directly to a digital antenna will not get you Digital signals...only analog signals.
Jun 25, 2010 | RCA TruFlat 27F520T 27" TV
I have an sdtv truflat 13 in tv. All I use it for is video games I can't remember what chanel to put the tv on to view the picture what channle do I use
if you are useing it for games then it must be on AV source if you want to watch channels then turn AV off press av / tv button on remote
Jun 23, 2010 | RCA 24V412T TV
Is the rca true flat tv able to be used by putting up an antena -or will we need a convertor box ? currently we have direct tv and are thinking about canceling it and use an antena.
This model does not have a built in HD tuner (ATSC Tuner). You would need an HD antenna (that is a more recent antenna that receives UHF) and an HD converter box to get the newly broadcast HD signals.
Nov 06, 2009 | RCA TruFlat 27F520T 27" TV
How record tv chanels using the DTV converter box? The converter box determines the chanel of interes while the DVD recorder must remain on chanel 3 in my area. My DVD recorder is a combo with a VCR...
Can you connect directly from the DTV converter to the DVD recorder input using RCA phono connector cables? You'll have to select the input on the recorder menu as well.
Oct 21, 2009 | GoVideo Go Video DVD/VCR Combo
Can't get channels.
You need a converter box on that unit.
Jun 22, 2009 | RCA TruFlat 27F520T 27" TV
Converter Box Problem
If you are receiving digital signal and channel is fuzzy, something wrong. Only Analog signal is fuzzy. With Digital it is great picture or nothing. For channel 6, check to see if they are broadcasting in digital yet. If they are not, this is why you are not getting a signal. If they are broadcasting in digital, then you need a stronger antenna.
May 27, 2009 | Insignia Digital-to-Analog Converter for...
May 13, 2009 | RCA TruFlat 27F520T 27" TV
Rca 14" truflat
This set was made before it was required to have digital tuning built in. You would need a digital converter box if you want off-the-air reception. (The federal program at www.dtv2009.gov that is giving $40 coupons toward purchasing a converter is out of money right now and is only putting people on a waiting list. It also looks like the changeover to digital is going to be delayed again, so you might not need to worry about it for a while longer.)
Feb 06, 2009 | RCA 27F534T TV
Unlockint the rca truflat
just had the same problem... found the old RCA remote in my house... put new batteries in it...used RCA remote.... hit menu... arrow down to preferences and hit "ok" on remote.....use arrow again to go down to FPA lock and hit ok to turn it off, hope this helps, hit menu again to remove menu from your screen
Brenda
Dec 29, 2008 | RCA TruFlat 27F520T 27" TV
Televison & Video Logo
23 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
