Assemble four4 dogs into slots of agitator cam for 285748 cam agitator
SOURCE: trying to connect agitator without dogs getting out of place
I thought the two parts would snap/connect together. They don't. Put the agitator on upside down over the "dogs" and their connector. Holding that together put the top agitator over the bottom. Carefully put over the metal connector inside the washer and connect the bult. The bult is what holds the pieces together.
To take apart initially I had to use a socket set with a long extension and a pipe over the racket handle to get enough torque to loosen the bult
Posted on Dec 05, 2008
SOURCE: Agitator Dogs
To disassemble, you need to destroy the tabs that are holding the translucent thing to the four post on top of the bottom part. This of course means that the translucent thing needs to be replaced too. I hammered the screwdriver into the tabs until they gave way. The rest of teh parts come out undamaged.
(if you have snips with really long handles, that would be a better tool).
Posted on Dec 12, 2008
  • 130 Answers
SOURCE: removing clutch assembly from agitator
easy bud, take the top off the agitator then you will see a cover. pop that off and you will se a bolt. remove and take off the middle prt of agitator and you can get to the dogs
Posted on Feb 16, 2009
SOURCE: How to remove agitator cam from the upper part of the agitator?
Had same problem with my washer. Check to see if there are little plastic tags holding top/bottom of agitator. after replacing dogs just ensure that you realign with tags so they do not break off.
Posted on Oct 13, 2009
  • 1937 Answers
SOURCE: how do I remove the cam-drive from the agitator
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Look at the section on the Sears site for Agitator, basket and tub.
See the part "Dog, agitator "
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Also see the following illustrated description of the above.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=0da65cea0e338fe930b1fde153a243f0
Posted on Jan 30, 2010
Agitator spindle isn't revolving
If the problem is just the agitator auger not working, but everything else does, you may just have a worn agitator cam assembly, worn agitator dogs, loose agitator bolt, or all of the above. The following link explains what agitator dogs are and how to access them:
http://www.fixya.com/support/r3608577-replacing_agitator_dogs
Whirlpool manufactured washers (such as Kenmore) use a split agitator design. The top half is known as the "auger, while the lower half is the agitator. Between the two pieces is a cam assembly, with small teflon teeth known as "dogs". There's also an agitator bolt that holds the entire assembly to the center post.
If the auger (top half of the agitator) is slipping, I would suspect the dogs or cam assembly need to be replaced. The part number for the dogs is included in the link I provided. For a little more you can purchase the entire cam assembly which includes the dogs, the cam, the cam seal and thrust bearing.
If the entire agitator appears loose or slipping, check the agitator bolt to ensure it is tight. DO NOT overtighten as this can restrict movement of the agitator or damage it. Tighten until snug.
Replacement parts (if required) can be purchased at any of the following websites:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If you do not wish to order parts on line, use the part numbers from the Sears website and go to your nearest appliance parts retailer. These parts are commonly sold as part of their in-store inventory.
Read through the information provided and let me know if you have any questions. I hope this is helpful to you.
May 30, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator problems..
If the problem is just the agitator not working, but everything else does, you may just have a worn agitator cam assembly, worn agitator dogs, loose agitator bolt, or all of the above. The following link explains what agitator dogs are and how to access them:
Whirlpool manufactured washers use a split agitator design. The top half is known as the "auger, while the lower half is the agitator. Between the two pieces is a cam assembly, with small teflon teeth known as "dogs". There's also an agitator bolt that holds the entire assembly to the center post.
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If you do not wish to order parts on line, use the part numbers from the Sears website and go to your nearest appliance parts retailer. All these parts are commonly sold as part of their in-store inventory.
Thank you for posting your model number. The part numbers you may need are as follows:
Item 10 - If just replacing the Agitator Dogs: 80040.
Item 9 - If replacing the entire Cam Assembly: 285809 (includes the Dogs and the Cam Thrust Bearing).
Item 22 - Spacer Thrust Bearing: 3951608
All these parts can be viewed under the "Agitator, Basket and Tub Parts" section of the parts resource websites I listed for you. The last digit of your model number is a "zero" (0), vice the letter "O".
If you have any questions, please post back and let me know. I hope this is helpful to you.
May 26, 2010 | Whirlpool LSQ9030P Top Load Washer
Top portion of agitator doesn't rotate
repairclinic.com
May 25, 2010 | Whirlpool LSR5132PQ Top Load Washer
Will not agitate during wash cycle. If i apply pressure to the agitator then it will but if no pressure then no agitation
repairclinic.com
May 13, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 70 series clicks loudly inside agitator like it is missing. It will agitate. It is like turn click click turn click click click turn. Not the rhythmic noiseless turns it had a week ago
If its just the agitator not working, but everything else does, you may just have a worn agitator cam assembly, worn agitator dogs, loose agitator bolt, or all of the above. The following link explains what agitator dogs are and how to access them:
If you have any questions, please post back with your MODEL NUMBER (located along the wash tub rim under the lid) and let me know. I hope you find this information helpful.
May 08, 2010 | Washing Machines
The agitator is not moving as well as it should. It turns very little. Should it not be agitating aggressively?
You have (agitating dogs) in the bottom of your washing machine. These little plastic pieces tend to wear out over time or from overloading. These can be replaced, cost about $5 for for 4 of these (dogs). Take the very top piece of the agitator off, it spins off. There's a bolt in the bottom of the agitator that will have to be removed. After it's removed, you can pull the agitator out. You will see the little (dogs). It's a very simple task, and takes about 10 min to do this. Look up (picture of agitator dogs) this will give you a better view at what you are looking at.
Mar 04, 2010 | Roper RAX4232KQ Top Load Washer
It leaves soap on the clothes after it goes thru the cycle and I noticed that the top part of the agitator doesn't move hardly. The washers model # is LSR8233JQO and the serial # is CK4729250, Type 111.
The agitator dogs (part # 80040) that grip and turn the top agitator to push the clothes into the bottom agitator during the wash cycle are worn and must be replaced. It costs about $5 and replacing it is an easy task to do.
Disconnect the power to the washer. Open the lid and remove the agitator cap by prying it with a flat-bladed screwdriver off the agitator top. Remove the 7/16 inch stud and seal holding the agitator to the shaft using a socket wrench with extension.
Lift the agitator off the shaft and pull the top agitator off the bottom agitator. Remove the cam that holds the agitator dogs from the top agitator.
Lay the cam upside down and install the agitator dogs on the slots. Hold the cam with the newly installed agitator dogs on one hand and the top agitator upside down on the other. Slide the cam up into the top agitator and turn the assembly in the upright position.
Align the cam and bottom agitator tabs and cut-outs and place the top agitator with the cam over the bottom agitator. Place the agitator assembly on the shaft and rotate it until the grooves match. Push the agitator down and reinstall the stud and seal. Do not over tighten the stud or the agitator will not spin properly.
Feb 10, 2010 | Dryers
Agitator wobbling from the stem. it comes right
Those are the agitator dog ears. They have teeth that grip and turn the top agitator during the wash cycle. It must be replaced when damaged or worn.
  1. Unplug the washer.
  2. Remove the fabric softener dispenser by pulling it off the agitator top.
  3. Look for the prying location on the agitator cap and insert a flat blade screwdriver between the agitator cap and the agitator then pry the cap off.
  4. Use a socket wrench, usually 7/16", with extension to remove the stud and seal holding the agitator to the shaft.
  5. Pull the top agitator from the bottom agitator.
  6. Pull the cam that holds the agitator dog ears from the top agitator.
  7. Lay the cam on its top and install the agitator dog ears on their slots.
  8. Hold the cam on one hand and the top agitator on the other.
  9. Slide the cam up into the top agitator and turn it over so that the agitator dog ears do not fall off.
  10. Reinstall the top agitator into the bottom agitator.
  11. Reinstall the agitator assembly into the shaft.
Jan 11, 2010 | Maytag Washing Machines
One part of agitator moves the other part doesnt.
Two-Piece Agitator: Bottom Works, Top Does Not - Whirlpool brands
Some Whirlpool brands washing machines employ a two piece agitator. The bottom is call the agitator and the top is usually referred to a 'Mover'. A multi-piece cam and bearing assembly connects the two and allows the top portion to index.
If the bearing or cams become stripped or damaged, the mover will often not work. Fortunately, Whirlpool produces a cost effective agitator repair kit that replaces all of the critical components in this cam assembly. There are three different repair kits. They differ in the height of the cam.
Agitator Removal Instructions:
Remove Dispenser or Cap:
Some models of washing machines utilize a fabric softener dispenser that resides on top of the agitator. This dispenser simply snaps onto the top of the agitator. Other styles utilize a decorative cap. To remove the dispenser, simply grab it and firmly pull up. To remove the agitator cap, insert a small flat-head screw driver into the seam between the agitator cap and the upper agitator (mover). Use a twisting or prying action to pop the cap off of the agitator.
Remove Internal Debris Cap:
Inside the agitator you will see a cap with a raised handle, much like that of your automobile. Simply reach into the agitator and twist the cap while pulling up. This will remove the cap and its o-ring.
Remove Agitator Stud:
When looking into the agitator assembly, you will notice a single nut in the center of the agitator. Use a socket kit or nut driver to remove this bolt (agitator stud).
Remove the Upper Agitator (Mover):
With the bolt removed you should be able to remove the upper half of the agitator (mover) by simply pulling up. Sometimes pulling up will actually remove the whole agitator assembly. If this happens, place the Lower Agitator on the floor and stand on the flat lip. Then Pull up to separate the Upper Agitator (mover) from the Lower Agitator.
Remove the Cam and Clutch Dogs:
When you remove the upper agitator (mover) it contains the cam and clutch dogs. Tun the assembly upside down. The cam and dogs should then come out.
-- Stop Here if Replacing Cam Kit --
Remove O-ring:
The lower agitator remains on the transmission shaft. On the top of the agitator, there is an o-ring. Remove this o-ring.
Pull the Lower Agitator:
All that remains is the lower agitator. This can be removed by simply pulling straight up on the agitator.
Agitator Installation Instructions:
Set Lower Agitator:
Slide the lower agitator onto the transmission shaft. Rotate the lower agitator until the splines in the shaft match those in the agitator. Once aligned press the agitator down. Install the o-ring into the top of the lower agitator.
-- Start Here if Replacing Cam Kit --
Assemble Cam and Dogs:
Turn the cam upside down. Place the small round ear of the dog into the corresponding slot on the cam. Repeat this for each of the four cams.
Install Cam and Dogs into Upper Agitator:
Invert the Upper Agitator (mover) and slide the cam/dog assembly inside. The cam should be pushed into the mover until it shoulders. Then rotate the whole assembly upright.
Install the Upper Agitator (Mover) on the Lower Agitator:
The lower agitator has two tabs that stick up that are 180 degrees apart. These tabs fit into two slots on the bottom of the cam. Align the matching tabs and slots and place the Upper Agitator (mover) and cam assembly onto the lower agitator. Push down until the cam snaps onto the Lower Agitator. If the dogs fall out during this step it is necessary to return to the 'Assemble Cam and Dogs' section above and start over.
Install the Agitator Stud:
Place the bolt (agitator stud) into the hole in the bottom center of the cam. Use a socket kit or nut driver to tighten the bolt .
Install Internal Debris Cap:
Install the o-ring into the groove on the OD of the debris cap. With the o-ring in place, push the cap into the Upper Agitator (mover). It is important that the cap is pushed past the ports in the Upper Agitator (mover) so that the wash water can enter and exit as designed.
Install the Dispenser or Cap:
The final step is to replace the top cap. Both the cap and the dispenser simply snap into place. Just make sure they are installed as far down a they will go and are firmly in place.
Apr 07, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Agitator not spining properly to pull clothes down into water
remove agitator cap remove boplastic cover underneath remove bolt remove upper portion of agitator replace agitator dogs part # 80040
Jun 06, 2008 | Roper RAB2121KW Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
