Question about Stamina Products Stamina Gyrotonic Transformer 1000
Need to replace frayed pulley cables on Gyrotonic 1000
05 lancer 2.4l serpentine belt keeps fraying. had someone look at it and they said it could be the ac pulley is out of alignment. suggested ac pump or clutch?
You must check for wear and alignment on the pulley with a straight edge like a steel ruler/yard stick. Likely you will find a bad bearing in the tensioner pulley or the crankshaft pulley is separating from the inner ring and walking outward.
Mar 28, 2014 | Mitsubishi Lancer Cars & Trucks
Belt fraying
the idler pulley is more than likely broken and is what caused the original belt to break to begin with, take the machine back apart and check the pulley for chips and sharp or rough areas
May 29, 2012 | Dryers
I need excercise instructions for a Gyrotonic 1000.
Still looking? Check the website or take a few privates from a certified instructor.
Nov 16, 2011 | Stamina Products Stamina Gyrotonic...
How to lift the bench on the gryotonic 1000
If you haven't figured it out here is the instruction from the manual.
STORING THE TRANSFORMERTM 1000The TRANSFORMERTM 1000 can be folded as illustrated for easystorage. Please follow the following process:Adjust the SUPPORT ARMS(47, 48) and ROTATINGARMS(102) to the position shown in illustration 1. Removethe EYEBOLT(39) from the BENCH LEG/w HOLE(34).Remove the LOCKING PIN(37) from the SUPPORT TUBE(35)on the Bench. Press down the SNAP PIN(95) on theSUPPORT TUBE(35) and fold the bench down. Lock it inposition by inserting the LOCKING PIN(37) into the hole in theSUPPORT TUBE(35). Turn the PULLEY FRAMES (15) toface to the inside of the UPRIGHT FRAME(1).Loosen the SECURING KNOB(41). Fold the Bench up to theUpright Frame and lock it in position with the EYEBOLT (39)and SMALL KNOB(40) as shown in illustration 3. TheEYEBOLT(39) must be attached to the Upright Frame asshown. Hook the two HAND STRAPS(21) onto the tubes onthe BENCH FRAME(31) for more security.
Nov 09, 2011 | Stamina Products Stamina Gyrotonic...
My gear cable has snapped - frayed at the changer end, & I need to push the frayed end out to replace the cable, & I am having difficulty. Help please
Get a pair of dikes to cut the frayed end of the cable from the cable, then the cable will slide out of the cable housing. If you have jammed the frayed end of the cable into the cable housing and you can't get to the other end of the cable to pull it out, use a clothes hanger to push the cable out.
Nov 25, 2010 | Cycling
The passenger side power sliding door on my 2003 Silhouette binds up when opening and shuts automatically before fully opens. I have disabled the power control to the door to open manuallly. It still is...
sounds as if the cable is shot which means that the motor will have to be replaced cause i think after 01 they went from cable pulley to sleeved cable and cause of the frayed cable in the sleeve is causing the stiff door btw i have installed power sliding doors on my 02 venture and know the system intimatly
Sep 11, 2010 | 2001 Oldsmobile Silhouette
I got a frayed flow boa lace cable is it fixable? frayed and brok
usually once there dead they need to be replaced, wait until the day they break or it annoys you enough to buy new ones.
Feb 03, 2010 | Flow Winter Sports
The cable came off for my power window
definetly have to remove the inner. i would have to imagine that if it came off then you have to replace it, it is probably frayed or twisted. if it is frayed or twisted, there is no way to fix it. you have to replace it.
Jun 21, 2009 | 1999 Volkswagen Beetle
Stamina Products Stamina Gyrotonic Transformer 1000 Logo
Top Stamina Products Exercise & Fitness Experts
Tom Chichester
Bill Boyd
Are you a Stamina Products Exercise and Fitnes Expert? Answer questions, earn points and help others
