Question about Stamina Products Stamina Gyrotonic Transformer 1000
Replacement cables for gyrotonic 1000
I have a Gyrotonic 1000 home unit. The cables (approximately 14') are frayed. Need to replace.
How do I fix screen on Northstar 951xd?
I have the same problem and am about to buy a display from Mavin.com. This is on the product page for the display:
**Note that this is not a direct replacement for the Northstar,but with some soldering it can be made to work.It is the same screen as used in the NorthStar units, it hasdifferent connectors. What this means to you is that youwill need to solder the connections directly to this board.Once connected, it works just fine.
Aug 13, 2015 | Northstar 951XD GPS Receiver
Precor error codes 53
Precor Error 53, Can't Read Target, Can't Find Home Switch Probable Cause 1. Blown F2 fuse.
2. Home switch wiring is damaged or has intermittent connection.
3. Gear (elevation/incline) motor wiring is damaged or has intermittent connection.
4. Home switch is bad.
5. Gear (elevation/incline) motor is bad.
6. Gear (elevation/incline) motor target is damaged.
7. Lower PCA is bad.
Corrective Action
  1. Disconnect power from the unit. Remove the F2 fuse from the lower PCA. Using an ohm meter, measure the fuse for 1 ohm or less. If the reading is considerably high, replace the fuse. If the fuse is blown, inspect further for the cause to avoid the fuse blowing again. Inspect for damaged gear motor wiring or a bad gear (elevation/incline) motor. Replace if necessary.
  2. Thoroughly inspect the home switch wiring for damage or intermittent connections. Repair or replace damaged wiring or poor connections as necessary.
  3. Thoroughly inspect the gear (elevation/incline) motor wiring for damage or intermittent connections. Repair or replace damaged wiring or poor connections as necessary.
  4. Ensure the moving arm is away from the home switch and disconnect power from the unit. Disconnect both wires from the home switch. Using an ohm meter, check for approximately 0 ohms. Continue to monitor the home switch resistance and activate the home switch by hand. The reading should change from approximately 0 ohms to open (infinite). If either reading is considerably incorrect, replace the home switch.
  5. With unit disconnected from power, disconnect both wires from the gear (elevation/incline) motor. Using an ohm meter, check for approximately 9 ohms through the gear (elevation/incline) motor wiring. If the reading is considerably high or low, replace the gear motor.
  6. Inspect the gear (elevation/incline) motor target for rips, tears, or bad scratches. If any of these are found, replace the target.
  7. During the start up sequence, check the voltage at the gear (elevation/incline) motor. Voltage should be approximately 12VDC. The voltage should only be present between the time the sequence was started and the error 53 occurred. If the voltage is considerably low or absent and the F2 fuse proved good, replace the lower PCA.
Precor Error Code 53
Nov 02, 2013 | Cars & Trucks
I need excercise instructions for a Gyrotonic 1000.
Still looking? Check the Gyrotonic.com website or take a few privates from a certified instructor.
Nov 16, 2011 | Stamina Products Stamina Gyrotonic...
How to lift the bench on the gryotonic 1000
If you haven't figured it out here is the instruction from the manual.
STORING THE TRANSFORMERTM 1000The TRANSFORMERTM 1000 can be folded as illustrated for easystorage. Please follow the following process:Adjust the SUPPORT ARMS(47, 48) and ROTATINGARMS(102) to the position shown in illustration 1. Removethe EYEBOLT(39) from the BENCH LEG/w HOLE(34).Remove the LOCKING PIN(37) from the SUPPORT TUBE(35)on the Bench. Press down the SNAP PIN(95) on theSUPPORT TUBE(35) and fold the bench down. Lock it inposition by inserting the LOCKING PIN(37) into the hole in theSUPPORT TUBE(35). Turn the PULLEY FRAMES (15) toface to the inside of the UPRIGHT FRAME(1).Loosen the SECURING KNOB(41). Fold the Bench up to theUpright Frame and lock it in position with the EYEBOLT (39)and SMALL KNOB(40) as shown in illustration 3. TheEYEBOLT(39) must be attached to the Upright Frame asshown. Hook the two HAND STRAPS(21) onto the tubes onthe BENCH FRAME(31) for more security.
Nov 09, 2011 | Stamina Products Stamina Gyrotonic...
My gear cable has snapped - frayed at the changer end, & I need to push the frayed end out to replace the cable, & I am having difficulty. Help please
Get a pair of dikes to cut the frayed end of the cable from the cable, then the cable will slide out of the cable housing. If you have jammed the frayed end of the cable into the cable housing and you can't get to the other end of the cable to pull it out, use a clothes hanger to push the cable out.
Nov 25, 2010 | Cycling
Replacement for Emerson Quiet Kool 12jw42k
Oh yes,there are plenty to choose from,you can go larger,if it is a 220 volt,and get better service,it will cool better,and cost less,on electric.
May 28, 2010 | Emerson Quiet Kool 10NW16K Air Conditioner
I got a frayed flow boa lace cable is it fixable? frayed and brok
usually once there dead they need to be replaced, wait until the day they break or it annoys you enough to buy new ones.
Feb 03, 2010 | Flow Winter Sports
A\\VOL Model ALTD1902M - Where to Find Power Cable?
POWER: AC 100V-240V at 50/60 Hertz means that your unit has a switching power supply built in which will operate on ANY AC (alternating current) voltage from 100V up to 240V, on either 50 or 60 hertz frequency.
(110V @ 60 Hertz is an USA wall outlet power standard, whereas 220V @ 50 Hertz is the European wall outlet power standard)
So, you can actually use it with just about any line voltage from a standard home wall power outlet, you just need the correct power cable that fits into your unit on one side and into the wall socket on the other.
The 60W power rating is just telling you how much power the unit consumes for operation which means that if you hook it to a 110V power line (USA), it will draw a current of approximately 0,54 amperes (60 watts divided by 110 volts equals to 0,54545 amperes) and if you hook it to a 230V power line (Europe), it will draw a current of approximately 0,26 amperes (60 watts divided by 230 volts equals to 0,26086 amperes).
The switching power supply in the unit has an internal fuse which is rated somewhat above the 0,54 amperes, could be a 0,63 amperes, but most probably it is rated at about 1 ampere or more.
If the specs you listed are correct, you only need to worry about the correct power cable that will fit into your wall socket on one side and into the combo unit on the other.
Hopefully, if the unit is in good health, you haven't wasted your money after all.
regards
3rq8 (Triarcuate)
Sep 15, 2009 | Televison & Video
Same thing happened to me - 04 Sienna xle
Here is a fix for a 1999 Sienna with a broken door cable.
Aug 19, 2009 | 2004 Toyota Sienna
Stamina Products Stamina Gyrotonic Transformer 1000 Logo
46 people viewed this question
Top Stamina Products Exercise & Fitness Experts
Tom Chichester
Bill Boyd
Are you a Stamina Products Exercise and Fitnes Expert? Answer questions, earn points and help others
