Question about RCA Televison & Video
How to hook rca converter box to a rca truflat tv
SOURCE: unlock rca truflat tv with no remote
Buy a universal remote and program it for the TV. That's the only thing that will work.
Posted on May 05, 2008
SOURCE: rca converter box need 3 digit code
Samsung 005 013 079 080 145 177 195 202 213 216 227 255 256 260 266 274 275 282 295
RCA 001 005 072 073 074 075 076 077 078 135 138 140 144 150 156 159 162 163 169 171 178 229 246 249 260 274 275 293 302
Panasonic 040 045 125 179 187 254 257 288 299 301
Posted on Sep 14, 2008
  • 12 Answers
SOURCE: I have an RCA converter box hooked up to an RCA tv
Basically, you cannot use the coax connections for both the VCR and the RCA converter box. I would hook up the phono/cinch connectors from the VCR to the TV if you can (these are also called RCA connectors, but I'm avoiding using that name so we dont confuse the digital receiver with a cable/connector name that is the same here). There should be a yellow one for video and red/white ones for left and right stereo. I believe the RCA converter comes with a three headed cable that can do this for you. With this configuration, you can set the TV to input on these connectors and the VCR should always output there. Once that is set, you can still use the converter box to receive the signal from your antenna, then run the coax to the VCR. Now, the VCR will always have to be set on channel 4 in your setup and you will need to manually change channels on the converter box for it to record a show. Does this make sense so far?
Posted on Feb 27, 2009
rulds2008
  • 3866 Answers
SOURCE: audio set up to xbox 360
There would be a RED,YELLOW,WHITE input cables that you would hook up to the back, there should be a Video mode on you remote turn it to one of the input channels and you should be fine.. Thanks and please rate.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on May 21, 2009
Kindofcheap
  • 241 Answers
SOURCE: Can't connect my ps2 with my rca truflat
well if u have a VCR or DVD play with u can run it though the the vcr first then back up to the TV makes sure u have the correct channel on and if that is not the case u may have to buy a small switch box (wal-marrt) Cheap to add more AV in puts.
Let me know if this works!!
Thank U jayson
Please feel free to rate my suggestions.
we depend on your votes!!!
Posted on Jul 04, 2009
Good evening.,i have the RCA TruFlat model number 20F424T. I'm trying to connect a converter box and I cannot get the tv itself to change confused either manually out with the universal remote. I...
your problem is likely the universal remote will not enter the menu and engage the auto program this set has--if it does and finds nothing either no signal or a bad tuner in the set.
If set has audio video jacks see if a DVD etc works on them--can always hook up signal to those inputs to bypass the problem.
Apr 28, 2012 | RCA Televison & Video
What antenna do I need for this TV?
If you are concerned about over the air programming, you will need a converter box to pull in and decipher the new channels. After the converter box, a pair of rabbit ears will work just fine. If you are subscribing to cable or satellite TV, nothing more than a connection to your RF connection on the TV itself. Thanks for asking and show a few hands of support!
Feb 13, 2011 | RCA TruFlat 27F520T 27" TV
When I hook up the cable to the RCA truflat tv the screen stays blue. I had it working with a cable box, do you know why it's not working with just the cable?
Your cable system is probably digital, and the tuner in this TV isn't compatible with the system. The cable box output was a regular TV channel 3 or 4 signal the TV could tune in. Without the box, though, your TV's tuner sees nothing. You'll need to stick with the box.
Jan 12, 2011 | RCA TruFlat 27F520T 27" TV
Do i need a converter box for my rca true flat 27 in? if not how do i connect a digatal antenna i have lost my manual
Your TV will require a Digital Converter Box to recieve over the air Digital Television Signals. You will need to hook up the antenna to the converter box and then hook your converter box to the TV. Hooking your television directly to a digital antenna will not get you Digital signals...only analog signals.
Jun 25, 2010 | RCA TruFlat 27F520T 27" TV
Is the rca true flat tv able to be used by putting up an antena -or will we need a convertor box ? currently we have direct tv and are thinking about canceling it and use an antena.
This model does not have a built in HD tuner (ATSC Tuner). You would need an HD antenna (that is a more recent antenna that receives UHF) and an HD converter box to get the newly broadcast HD signals.
Nov 06, 2009 | RCA TruFlat 27F520T 27" TV
Can't get channels.
You need a converter box on that unit.
Jun 22, 2009 | RCA TruFlat 27F520T 27" TV
The female cable connector on the back of the tv broke off
yes,you could also use RCA cords from the cable box to the tv and bypass that by selecting the video channel that you hook the rca's to
Jun 02, 2009 | RCA TruFlat 27F520T 27" TV
I have an RCA converter box hooked up to an RCA TV and a Sanyo VCR. The TV and VCR are set on Channel 3. The converter box is set on Channel 4 and the TV is also switched to CH 4 when viewing digital...
Feb 27, 2009 | RCA Televison & Video
My rca tv
The remote control may only work for the cable box and you may have to manually put the TV on the correct input channel also you might double check that the cable to the TV is hooked to the antenna input. Here is the website for the manual TV if you think it might help.
http://tv.rca.com/RCATV/Assets/pdfs/27F520T_1641312E_IB_e-06.pdf
Sep 05, 2008 | RCA TruFlat 27F520T 27" TV
Televison & Video Logo
27 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
