Question about Car Audio & Video
How to set up radio channels on PSUFM1245A (Pyle Discojam )
How to set the time on a pyle plcd11mrkt marine radio?
Click "Download manual or factory spec sheet", save it to your documents folder, and see page 9 here... http://www.rocktheboatmarinestereo.com/html/67460.html
Jul 16, 2014 | Pyle Audio Players & Recorders
I have a pyle 12"
I am afraid in order to make use of your sub, you will need to buy an amplifier and a cabling kit to run it. You could run it straight from the headunit from one of the main channels but it would need a crossover so it wasn't fed any sounds which it couldn't cope with (high frequencies, they require very fast movement of the speaker cone, your sub wouldn't be able to do it)
Here is a link to a downloadable copy of headunit manul.
Hope this helps
May 09, 2011 | Pyle Car Audio & Video
2003 Cadillac DTS w/Bose, has rear sub & adding Pyle dual 10 sub
two channel will do with the same power power rating of your speakers ex. your speaker is 500 watts per piece so you need to buy a 500 watts per channel amplifier
May 16, 2010 | Pyle PLHB10 Car Subwoofer
My amp and subs work but the subs dont sound very loud. how do i adjust my Pyle PLA4340 amp and fix this problem
Hello polarisracin,
You need to bridge 2 of the amp channels to each 4 ohm sub to get the most power from the amp. Bridge channels 1/2 to one of the subs and channels 3/4 to the other one. But the amp is only rated for 75 watts RMS per channel and Pyle products are sometimes rated higher than their real capabilities. So, even bridged and with the rated output, you'll only be getting at most 150 watts from a pair of bridged channels. That's not much for a sub.
Hope this helps.
Oct 01, 2009 | Pyle PLA4340 Car Audio Amplifier
Trouble connecting marine amp to stereo
Hello lizskates814,
You can use either the high level (speaker) or the low-level (RCA's) inputs to the amp, but not both. Choose whichever one sounds the best or is more convenient to install and leave the other disconnected.
Hope this helps.
May 23, 2009 | Pyle PLMRA400 Car Amp
PARTS
Pyle does not sell parts for their units. What kind of part is it? You might be able to find a generic replacement...
Oct 15, 2007 | Pyle PLBINDV7 Car DVD Player
What is wrong with my system
wiring may not be the problem but try connecting each coil to separate channel and make sure polarities are correct.
Aug 08, 2007 | Pyle PLA2200 Car Audio Amplifier
Car Audio & Video Logo
55 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
