Looking for 12v dc cord to connect cd player to main unite model mwcdv1.0
  • 3 Answers
SOURCE: cord missing
http://www.18002526123.com/products.aspx?type=pa&view=104&p=34&sc=6
Posted on May 06, 2008
SOURCE: Durabrand DUR-7 dvd player
the 12 volt car adapter only puts 9v to the dvd player. It is poorly marked. It really only runs on 9v. If you plug 12v into it it will smoke... thats what mine did.
Posted on Aug 27, 2008
SOURCE: dc line cord needed for durabrand dual dvd player
You can buy a new one at: http://www.1800customersupport.com/products.aspx?type=pad&view=389&p=73&sc=5.
Posted on Dec 17, 2008
  • 33 Answers
SOURCE: replacement ad/dc power cord
you can get a replacement ac/dc power cord for durabrand portable dvd player model # PVD-707 here;
http://www.acdapter.com/DURABRAND_PVD_AC_ADAPTER.html
Posted on Dec 19, 2008
  • 303 Answers
SOURCE: Can't find a replacement 10.5V DC power cord
You can buy a new car adapter by clicking on the hyperlink:
buy replacement car adapter power charger cord for Durabrand DUR7 DUR-7
Posted on May 31, 2009
Can I charge my device with a 12v lighter power cord? Does it matter if the power cord is 12v and the device is 12.9v? Bill Dobson.
i am looking into the same thing at the moment. apparently you can use a 12v car charger to charge this unit, you just need the correct size plug to fit. when the car is running, it generally outputs 12.3 to 12.7v through the dc plug, so it will charge the unit, just may take a little longer, best to charge while travelling to keep charge volts up. i got this information from a car battery shop.
Jun 01, 2010 | Logitech 984-000057 Pure-Fi Anywhere 2...
I'm installing a gps tracking unit on one of our landscape trucks. It's a 97 gmc/chevy 2500. I need to connect it to the ignition(12v dc) and constant power (12v dc)
your looking for an orange wire for your ignition and a yellow wire for constant power i believe. it's easiest to find them behind your deck/cd changer. just cut the wires and slice into them before the connection point of your deck wiring harness
May 13, 2010 | 1997 GMC Sierra K2500
When I press the power button to turn the unit on,
Check your cord first, make sure it's in good shape. Sometimes the main transformer goes out, and you can use a DC adapter to bypass the 120 V source. Could be a fuse, or something else in the power supply inside the unit.
Mar 13, 2010 | Durabrand CD Boombox, Pink Boombox
Ive got a standard stereo in my 06 mercedes vito van and the cd has jammed inside how can i get my cd out than. matt
Follow this 3 steps :
Step 1 : You mast find the dc motor inside the car radio.
Step 2 : Desolder the 2 wires of the dc motor.
Step 3 : Connect the 2 wires to a 12V DC source, if the CD do not come out then reverse the wires.
Nov 09, 2009 | JVC KD-LH7R CD Player
My clarion dc 628 cd 6 disc changer will not switch on
Well, I have just had the same problem with the same model.
I had a look inside and it turned out in my case that the din socket that connects the multichanger to the head unit had one pin that had failed, (the power 12V). I had to go through every pin, one by one and found that the 12V was present on the lead coming from the head unit, but was not making its way to the board. It had failed within the socket surprisingly.
So I wired in a new, fused 12V feed to the circuit board, and hey presto, everything came back to life!
I thought I would just add this in case anyone ever searches for this problem in the future.
Jb
Sep 03, 2009 | Clarion DXZ385USB Car CD/ MP3 Player
I have an insignia T.V. that I picked up on the curb. The power cord was cut. I want to rewire a cord to it. It has a white and black line. Does the white line go to the fat plug or the thin plug in the...
it will be a DC power supply normally so i would not plug direct in the mains.
normally there is a marking on the unit of required voltage also the white line is usually + and black -
and it could be anywhere from 12v onwards
best of luck.
Aug 26, 2009 | Insignia NS-8PDVD
Aug 14, 2008 | Durabrand DUR7 Portable DVD Player
Power supply for the 2nd screen ??
If you are not using the car power adapter that came with your PDV-768 for the 2nd screen, you are likely running into the possibility of "reversed polarity" with the power adapter you are attempting to use. This can & often will cause a problem with your unit.
Nov 28, 2007 | Protron PDV-768 Portable DVD Player
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
