Question about Hotpoint Washing Machines
Hotpoint HSWP1000M4WW how to tighten agitator it seems loose
SOURCE: agitator
SM8280867
Posted on Dec 12, 2007
  • 958 Answers
SOURCE: loose agitator on Whirlpool Ultima Care II washer
it could have stripped the spline on the plastic agitator. there is a bolt at the middle of the agitator and you can access that thru the top . remove the top cover and you can remove the bolt using a deep socket.
once you remove the agitator you can look at the dog agitator. these a 4 pcs plastics that works like a one way wrench.
be careful on the location, they are very hard to put back.
check also the spline on the inner part of the plastic assembly.
they do get stripped.
if they are, replace the whole agitator.
tnx 4 using fixya,
drcool
Posted on Sep 07, 2008
  • 1122 Answers
SOURCE: kenmore 90 series washer 110.28902790
if you remove the agitater cap and the inside cap,you will see what they call dogs(4 of them)they wear out and the agitater will not wotk,if you remove the 7/16 bolt and pull the agitater off you can replace them and all will be fine,you can get them at your local appliance part store,please leave me a fixya-mike
Posted on Mar 13, 2009
  • 401 Answers
SOURCE: The top portion of the agitator seems to be very
NO BUT YOU MAY NEED WHATS CALLED ADJITATOR DOGS.TAKE THE TOP FABRIC DISPENSOR OFF AND REMOVE THE INNER CAP {IF THERE IS ONE} TO GET TO THE BOLT THAT HOLDS IT DOWN. REMOVE THIS AND PULL THE ADJITATOR OFF THE TRANSMITION AND OUT OF THE MACHINE. NOW YOU CAN SEPERATE THE TWO PIECES AND REPLACE THE DOGGS. GOOD LUCK!
Posted on Jan 17, 2010
  • 353 Answers
SOURCE: agitation and spinning problem
get a new cap or try some sort of glue
Posted on Jun 28, 2010
How do I get to the pump on a hotpoint washer model HSWP1000M4WW
then test the pump to see if it will run if not replace it
Dec 12, 2015 | Hotpoint Washing Machines
Why does my clothes get stuck around the bottom of my agitator during washing?
the center of your Agitator has a cap or a pull off top inside you should have a Nut, Tighten the nut back down sounds like the plastic Agitator has lifted up and has to be tapped or tighten back down into the Tub.
Mar 15, 2014 | Hotpoint Washing Machines
Simpson Encore 605 agitator bolt comes loose - does it need loctite?
The wear is preventing it from tightening correctly, loctite won't be a long term fix, it will still come loose again due to the forces put on the bolt by the vibrations of the agitator. The only way to fix it is to replace the agitator.
Mar 06, 2012 | Washing Machines
The agitator on my washer seems to be slipping or stripped. How do I get into it to see if it's loose or needs to be replaced?
On some washers, you may be able to tilt it to look under it. There should be a main rubber belt that drives the agitator and other components, see if there is any slack or looseness in the belt. It should be pretty tight. If it is not, you may look for documentation on how to tighten it or else you might consider a replacement belt in some cases.
Dec 13, 2011 | Whirlpool Washing Machines
The agitator seems loose on my Maytag top loading machine.. model LAT9206BAE it started this after one of my kids overloaded the machine.. works fine but makes a loud clanging noise while washing.. almost...
Use a 1/4 inch nut driver to tighten the set screw to the agitator shaft. It is about 3 inches up from the bottom of the agitator on the side of the agitator.
Dec 28, 2010 | Maytag Washing Machines
Hotpoint oven won't hold temp and it is not the temp sensor
if it's not the igniter, check for loose wires in the top - my husband tightened one leading to the control board, seems to be working now
Dec 08, 2010 | Hotpoint RGB745 Gas Kitchen Range
Loose agitator on Whirlpool Ultima Care II washer
tnx 4 using fixya,
drcool
Sep 07, 2008 | Washing Machines
Tub shakes back and forth during agitation
it could be the inner tub thats loose , check for a broken screw at the center mast that holds the inner tub. hope this helps.
Apr 28, 2008 | Hotpoint VBXR1070W
Loose agitator Maytag LAT2600AAE
Look toward the bottom end of the agitator. There should be a small indentation where a 10mm screw is. This screw holds the agitator the the transmission shaft. Sometimes the screw works loose and needs to be tightened.
Dec 17, 2007 | Whirlpool LSB6200PQ Top Load Washer
Washing Machines Logo
124 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
