Question about Radio Communications
Trying to pair my new phone a galaxy s7 to my parrotbluetooth headset and the headset is rejecting pairing up to my phone
SOURCE: how to reconfigure the H500 headset with a new phone?
Turn off your earpiece.Then turn it back on but hold the button until the blue light comes on and stays on.(that puts it in discovery mode) Now go to bluetooth devices in you r phone and search for the device.
Posted on Dec 28, 2007
SOURCE: Motorola H700C Pairing with LG VX8700
im having a problem with my h700c and my lg too it was paired with a samsung and i got the lg now the phone phone the BT fine it just wont pair,wat can it be?
Posted on Feb 09, 2008
Push and hold both vol(+) and vol (-) at the same time for approx 2 secs. The headset will falsh green and red lights. Get your phone to search for bluetooth devices. It should find the headset. Enter pairing code 1234 in phone. Done
Posted on Jul 13, 2008
The mamual says to hold the - and + volume keys at the same time for approx. 2 seconds till the light starts to flash green and red. The pairing code is 1234
Posted on Aug 26, 2008
SOURCE: how can i pair my samsung bluetooth headset to
turn off the head set then press and hold the on button until the blue light stays solid blue.
search for device on your new phone and add device code is 0000
Posted on Apr 12, 2009
How to pair it with galaxy tab 4
This is for the 1900, but should be the same. Go to Bluetooth settings on your Galaxy.
Samsung HM 1900 User Manual
Aha, I found this for the 1500
4 Enter the Bluetooth PIN (0000, 4 zeros) to pair and connect the headset to your phone. Your headset supports the Simple Pairing feature which allows the headset to be paired with a phone without requesting a PIN. This feature is available for phones that are compliant with Bluetooth version 2. The headset also can be paired via the Active pairing feature, see page 14. Connecting with two Bluetooth phones
With the Multi-point feature activated, your headset can be connected with two Bluetooth phones at the same time. 1 After connecting with the first Bluetooth phone, press and hold the Talk button until the blue indicator light stays lit. 2 Press and hold the Volume up button to activate the Multi-point feature. 3 Activate the Bluetooth feature on the second Bluetooth phone and search for the headset (see your phone???s user manual). 12
4 Select the headset (HM1500) from the list of devices found by the second Bluetooth phone. 5 Enter the Bluetooth PIN (0000, 4 zeros) to connect the headset to the phone. ??¢??¢ You can set the headset automatically to reconnect to the recently connected phones each time you turn it on. -- To reconnect to the two most recently connected phones, activate the Multi-point feature. Press and hold the Volume up button in Pairing mode until the blue indicator light flashes twice. -- To reconnect to only the most recently connected phone, deactivate the Multi-point feature. Press and hold the Volume down button in Pairing mode until the red indicator light flashes twice. ??¢??¢ When the headset connects to two Bluetooth phones, some phones may not connect to the headset as the second Bluetooth phone. English
Disconnecting the headset
To disconnect the headset from your phone, ??¢??¢ Turn off the headset. 13
Reconnecting the headset
When the headset is paired with a phone, it will attempt to automatically reconnect each time you turn it on. If the headset does not automatically attempt to reconnect, ??¢??¢ Press the Talk button. Pairing via the Active pairing feature
With the Active pairing feature, your headset can automatically search for a Bluetooth phone and try to make a connection with it. 14
3 Press and hold the Talk button until the violet indicator light turns on. The headset will switch to Active Pairing mode, search a Bluetooth phone within range, and attempt to pair with it. [. . . ] ??¢??¢ To switch between the current call and the held call, press and hold the Talk button. 19
Oct 30, 2015 | Samsung HM1500 Bluetooth Headset
Pairing rejected problem?
Make your device visible for a longer time so that you can enter the pairing PIN.
Sep 28, 2014 | Radio Communications
Poor sound quality when paired with my galaxy nexus
this seems to be a phone related issue. but try to reset your ear piece first. refer to the manual or contact them
Apr 29, 2013 | Motorola Mobility Hx550 Bluetooth Headset...
How do I pair a Samsung bluetooth headset model HM1000 to my Nokia C7-00 phone?
1.first on samsung bluetooth device hold call answer button in bluetooth device now light is on ,not blinking
3.and then search your bluetooth device by your phone and pair.
Apr 11, 2012 | Samsung HM1000 Bluetooth Headset
0000 or 1234 does not work - states incorrect password. I was just wondering if it is even possible to pair an em227 bluetooth with a Samsung Galaxy S.
You must put you headset in pairing mode, prior to trying to pair it with your phone. In order to do it, starting with it turned off, press and hold the power button for some 10 seconds, until the indicator light is alternately flashing in red and blue. It is in pairing mode now. Then, bring your phone close to it, and make its bluetooth application search for new devices. After a little while, your headset should appear on-screen. Select it and make it connect. If a pairing code (or passkey, or PIN) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset should enter the stand-by mode (blue light flashing every few seconds). By the way, If its user guide happens to be missing, or, rather, you need further informations on how to pair it with your phone, feel free to download it from this location.
Jan 13, 2011 | Samsung Galaxy S GTI9000 Smartphone
How do I pair my wireless Jabra BTS30 headset with a new cell phone? It was paired to another phone before.
All that is required is to repair the headset with another phone. If you need instructions on how to place the headset in pairing mode, please let me know i will be glad to help =)
Mar 30, 2010 | Jabra Bluetooth Headset with Adjustable...
I am trying to pair a Blackberry 8900 to the HS830 Bluetooth device. I know the passcode is 0000. But the Blackberrry is not detecting the HS830 at all. It detects other Bluetooth items, but not this one....
Put the headset in PAIRING mode, if it has been paired with another phone, it will not accept a new pairing or another phone until you put it in pairing mode again. Press the button until the LED gets steadily ON, search the headset and pair it with the new phone. It only accepts one paired phone at a time.
Nov 04, 2009 | Motorola Mobility HS850 Consumer Headset
Can the LG HBM 550 be paired a second time to another phone?
Sep 16, 2009 | LG HBM-550 Wireless Headset
Bought new van with parrot ck3100 will not pair with nokia 6600 used pass code 1234 and 0000 parrot still rejects phone
You need to delete the existing paired devices from the setting in the parrot before it will allow new ones.
Jun 03, 2009 | Parrot MINIKIT Bluetooth Hands-Free Kit...
Pin number for philips SHB6100 aside from 0000.
yeah hedenram is right. my problem was that i was trying to pair something WITHOUT the headset in pairing mode. just switching it on doesnt put the headset in pairing mode and it will reject the 0000 passkey even if this is correct. it is vital when you turn on you hold the power button til it flashes red/green and then it will be in pairing mode and accept the 0000. the only way i found this was in the instruction booklet which i thought i had chucked away
Oct 22, 2008 | Philips VOX120 Wireless Headset
Radio Communications Logo
50 people viewed this question
Top Radio Communications Experts
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
