Question about Sewing Machines
I wasa askingabout sewinging not game boy ganmes!!!!!!!!!
I need the emerald 116 book
I have 116 emerald sewing machine, seldom used, I do not have oiling Instructions in manual.
The Husqvarna Viking Emerald 116 is an electronic sewing machine. These machines do not get oiled by the user. See page 42 of the manual for the routine maintenance; here's a link to that page: . You should only clean the bobbin hook assembly and the feed teeth.
If you have a problem, you should take the machine to a trusted sewing machine repair person. If you add oil, you could damage the electronic components of the machine.
I hope this helps.
(I have access to both a completely mechanical sewing machine and an electronic 'computerized' machine. I only do the maintenance indicated in the manual for each machine.)
Jul 14, 2017 | Sewing Machines
Recently my sewing group was given Husvarna Viking Emerald 116. Stitch width is off.
Be sure and use the correct sewing foot...the machine is probably reading the foot and won't let you make adjustments. Also make sure the needle plate is the correct one.
Jun 01, 2016 | Husqvarna Viking Emerald 116 Sewing...
What is the weight of Viking Emerald 116 sewing machine?
This is a tabletop machine. So what about picking it up and putting it on the bathroom scale?
Sep 22, 2015 | Husqvarna Viking Emerald 116 Sewing...
The needle threader is stuck down on my Emerald 116
Typically the threading device moves downward and then rotates sideways. Which function is stuck? Is the shaft bent? In any case, the threader apparatus is removable. If you need help disassembling, get a service manual for that model (probably about $20 on the internet).
Feb 11, 2013 | Husqvarna Sewing Machines
Sewing Machines Logo
22 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
