Question about Garden
How does one remove the steel balls from the passages in a duplex carburetor ?
2 Suggested Answers
  • 130 Answers
SOURCE: pulsejet carburetor 5hp briggs&straton engine
go to partstree.com and see a diagram for your 5 hp carb.hope this helps.let me know.ok
Posted on Jul 25, 2009
Have to keep full choke on to keep it running
Hi Byron
The fuel pump is built into the carb.
Here are a few suggestions:
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Also be sure to check and clean your spark arrestor in the exaust,if you have one installed on your engine.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of chainsaws and weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor or take a pictue for later reference.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil if your using a two cycle chainsaw or weedeater with the oil to the right mixture...too much oil as it can cause hard starting and excessive smoking.
If the chainsaw/trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indention in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
Mar 24, 2013 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
Tip
Duplex Stainless Steel Flange Manufacturer
Duplex stainless steel flange have a lower nickel and molybdenum content than normal austenitic stainless steel flanges. Due to this duplex stainless steel flange are one of the lower costing flanges available. Duplex stainless steel flange are subject to incredible corrosion resistance levels and also have very high mechanical strength. Duplex SS flange Manufacturer also have proven toughness and ductility. They are tougher than ferritic grades. The better price stability on duplex stainless steel flange is one of the reasons that it is being offered on a larger scale by a number of major manufactures around the world.
on Oct 07, 2016 | Miscellaneous
Tip
Super Duplex Steel Pipe Supplier
Super Duplex is an austenitic-ferritic iron chromium - nickel alloy with molybdenum addition. Super duplex pipes are extremely resistant to pitting. They have an improved tensile strength and have a higher corrosion cracking resistance at moderate temperatures compared to that of normal duplex steel pipes. Super duplex steel pipe Supplier also have an impeccable resistance to erosion corrosion. The main and most pre-eminent feature of super duplex steel pipes is that it has very high mechanical strength. It is also proven that welding can be done with more ease on a super duplex steel pipe than a normal duplex pipe. From the introduction of its first-generation, super duplex steel pipes have seen a steady increase in popularity.
on Oct 05, 2016 | Miscellaneous
I have a Ryobi 30ss straight trimmer that only runs with 1/2choke position. I changed fuel lines, filter, pump ball and spark plug.
Hi iriviere3...
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of weedeaters.
Make sure you are using fresh fuel...and oil mix if your using a two cycle weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Note:
Normally there is a small indetion in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
Please take time to rate me thumbs up
Sep 17, 2011 | Ryobi Garden
Starts runs then dies replaced fuel lines primer ball no imprrovement
Hi jmlischak...
You probably have check some of these
Make sure you are using fresh fuel...and oil mix if your using a two cycle chainsaw or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Note:
Sep 16, 2011 | Garden
My push mower will not prime no matter how many times i push the red prime button.
Hi scottyerober...
Sometimes you can get by with priming the carburetor or by using starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets or passages,but most of the time you will need to rebuild the carburetor.
Check/Clean/Replace your fuel filter if you have one.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor.
If the mower is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
Jul 24, 2011 | Craftsman 550 Torque 22 in Deck 2n1 Side...
2 hp b&s rngine runs 20 secs. and dies
Hi mowertools...
Sounds like you have dirt/debris in your carburetor jets or fuel passages.
Also make sure you are using fresh fuel.
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
May 27, 2011 | Briggs & Stratton Briggs Stratton...
Why will my tiller only run when the primer ball is pushed in. I replaced the ball and still have the same problem as soon as i let off the primer ball the tiller stops running.
Hi mjlqm....
Make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
May 25, 2011 | Craftsman Gas Mini - Tiller/Edger
For mtd 3hp 2cycle motor only stays running when pushing prime repeatedly on full chock 5 sec
This is usually a symptom of blocked or partially obstructed metering passages in the carburetor. Carburetor should be removed and metering passages cleaned to restore fuel flow through the carburetor.
Feb 12, 2011 | Tecumseh Snowblower Snow Blower Starter...
I have a 48 inch belt driven walk behind once i get it started it will run but when I engage the blades or put it in gear it runs then stalls out?
Check your fuel filter if you have one.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
If the mower/weedeater is over a year old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
This is a FREE answer,Please rate me
Oct 06, 2010 | Encore EXMARK LAWN MOWER HEAVYDUTY STEEL...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
