SOURCE: patio heater won't lite
There is possibly a spider web or wad of web blocking the gas flow between the valve and pilot.Take the line off between the valve and pilot and blow it out with compressed air and it should fix the problem.
SOURCE: charmglow gas patio heater
charmglow heater,,my pilot lights,but when we turn knob to #2 the pilot goes out.tank is full,is it the regulator or the thermostat control valve?
SOURCE: my patio heater model tmc s.s.l the pilot works
That may have an oxygen sensor on it and if it gets dirt in it that will happen...
Take apart the pilot assembly and blow it out with high pressure air and then reassemble it...that should fix it...
heatman101
SOURCE: Charmglow 810-7400-S Propane Grill: have a charmglow patio heater, the pilot comes on ...
I have a Charmglow Patio Heater Model SRPH02, it needed a Thermocouple and searching the net was hard to find an ariginal part, but here it is, call 1-866-814-0585 $3.95 +6.00 shipping the original part.
SOURCE: Frontgate patio heater, serial number
First check that you are getting a spark, if not check lead and ignitor. If getting a spark make sure that there are no leaks, to do a gas leakage test see Patio heater problem solving. Next check the tilt switch if fitted, just short it out by joining up the two leads. If OK look for any debris/insects around the pilot and clean. A worn thermocouple will turn the gas off, these can last anywhere for 2 years up to 6 years but will at some point need replacing.
