Question about Video Game Consoles & Games
Update does not appear in settings.how do I update
Has software rev 6.3.4. How can I determine whether it needs mandatory software update?
A new, free software update available for your Kindle Fire HD 7" (2nd Generation). This update automatically downloads and installs on your Kindle Fire when connected wirelessly; however, you can also manually download the software and transfer the update to your device via USB cable.
Swipe down from the top of the screen to open Quick Settings, and then tap More.
  1. Download & Install Software Updates Automatically.
Swipe down from the top of the screen to open Quick Settings, and then tap Sync. The software update automatically downloads in the background, and installs after the download is complete and the device is asleep. Your Kindle Fire will restart during the software update. After the restart, the message"Kindle is upgrading" will appear on the screen.
Mar 19, 2016 | Amazon Kindle Fire HD
Not receiving text messages
Try to
Update your iPhone by Settings > General > Software Update.
Update your Carrier setting by Settings > General > About and If an update is available, a prompt will appear. If need more help on message problem then read http://support.apple.com/kb/TS2755 and still require guidance on any iPhone problem follow Mac Support .
Aug 03, 2014 | Apple iPhone 3G
X-box 360s brand new, cannot get it to download the update
Hello
The easiest option to update the Xbox 360 hard drive is to connect to Xbox Live. The console will automatically prompt the user to install any available updates. Alternatively, users can download the update files to a USB flash drive to transfer to the Xbox 360 hard drive.
Update via Xbox Live
Open the Xbox 360 dashboard menu. This menu automatically appears when the console is turned on. Press the "Xbox" button, followed by the "Y" button to return to the dashboard menu from a game.
Scroll up to the "My Xbox" tab of the dashboard menu.
Select "System Settings" from the "My Xbox" section of the dashboard. Scroll to the right while the "My Xbox" tab is selected to reach the "System Settings" icon.
Select "Network Settings" from the "System Settings" menu.
Select "Test Xbox Live Connection" from the network settings. A prompt will appear to update the Xbox 360 hard drive if your system is not already updated to the latest version.
Select "Yes, update now" to install the latest updates to your Xbox 360 hard drive.
Updating via USB Flash Drive
Copy the update files onto the root directory of your USB flash drive. You can download the Xbox 360 update files by going to download.microsoft.com/download/1/d/8/1d8c09be-278e-41cd-98be-eb9188128227/$systemupdate9199.zip. You must extract the files from the .zip file before placing them on the USB drive. The update files cannot be placed into a folder or the Xbox 360 system will not recognize them.
Remove the flash drive from your computer.
Insert the flash drive into the USB port on the Xbox 360 console.
Turn on the Xbox 360. An update prompt will appear when the system powers up.
Select "Yes, update now" to update the Xbox 360 hard drive.
Nov 21, 2010 | Video Game Consoles & Games
Why haven't you found solutions for the posts above???
Hello joe_east,
The Belkin Router's software (firmware) can be occasionally updated. To check for new updates, go to the Belkin Router Setup page http://192.168.2.1/ . The following choices will appear to update firmware and save current settings:
•Select Firmware Update (Near the bottom of the left-hand panel)
From time to time, Belkin may release new versions of the Router's firmware. Firmware updates contain improvements and fixes to problems that may have existed. Click the link below to see if there is a new firmware update available for this Router.
•Firmware update Options:
Firmware Version > #.##.##
Check for New Firmware Version > [Check Firmware]
Update Firmware > [Enter file name/Browse]
[Update]
•NOTE: Please backup your current settings before updating to a new version of firmware. Click Here -> http://192.168.2.1/system_c.stm to go to the Save/Backup current settings page.
•Save/Backup Settings
You can save your current configuration by using this feature. Saving your configuration will allow you to restore it later if your settings are lost or changed. It is recommended that you backup your current configuration before performing a firmware update.
*Saved File name is user.conf*
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Jul 04, 2010 | Belkin (F5D7230-4) Router (587009)
Describe how to update blue ray player
Software Update Instructions
    • WARNING!! Do not power off the Home Entertainment Server or disconnect it from the AC power outlet. Doing so may damage the Home Entertainment Server to the point of requiring repair.
    • WARNING!! Do not press any buttons, except as instructed, until the update is complete. Doing so may damage the Home Entertainment Server to the point of requiring repair.
    • The software update process usually takes about 15 to 30 minutes, depending on system configuration and network connection.
    1. Power on the television and make sure it is tuned to the inputs to which the HES-V1000 Home Entertainment Server is connected.
    2. Connect the LAN terminal on the HES-V1000 to your Internet source using an Ethernet cable.
    3. Power on the HES-V1000 Home Entertainment Server.
    4. Press "HOME" to go to the Home Menu.
    5. At the "Home" menu, select "Settings".
    6. At the "Settings" menu, select "System Settings" and then press "ENTER".
    7. At the "System Settings" screen, select "Software Update" and then press "ENTER".
    8. At the "Software Update" screen, select "Network Update" and then press "ENTER".
      Note: The network connection display appears.
    9. Select "Yes" and press "ENTER".
      Note: The server starts to check the version information.
    10. At the version confirmation screen, select "Yes" and then press "ENTER".
    11. The software License Agreement appears. After reading the content, select "Agree" and press "ENTER".
    12. The software update is downloaded and automatically starts updating the HES-V1000 software.While the software update is downloading:
      • "DOWNLOADING XX%" appears on the front panel display, indicating the progress.
      • If the download fails, an error message appears on the screen, and the display returns to the Home Menu.
      When the software update is complete:
      • "VERSION UP FINISH" appears on the front panel display, indicating that the update was successful.
      • If "VERSION UP FAIL" appears on the front panel display, repeat the update procedure above.
    13. The system will power off automatically.
    14. Power on the Home Entertainment Server again.
Please refer the following link:
http://esupport.sony.com/US/perl/swu-download.pl?upd_id=5321&mdl=HESV1000
Feb 11, 2010 | Sony HESV1000 200 Disc Blue-Ray Server
How to update my mobile software?????
* These steps apply only for Sony Ericsson Mobiles (ex. Z550i)!
1. To update the Mobile OS / Firmware software, you have to connect to internet.
2. Goto Menu >> Settings >> General >> Update Service.
3. Select 'Search for Updates' to search latest available software update OR
4. Select 'Software Version' to display current software installed on phone OR
5. Select 'Reminder' to set time when to search for new updates.
* To use "Update" service online (not on phone) :
1. Visit www.sonyericsson.com/update
2. Select a 'Region' and 'Country'.
3. Enter the Product Name.
4. Select 'Sony Ericsson Update Service' and follow the instructions that appear!
please rate this advice if it helps...tc! :)
Jan 19, 2010 | Sony Ericsson Cell Phones
Toshiba tecra 8000 EC/KBC update
go to system setting by pressing F2 when you see the toshiba or bios logo
disable the system setting auto update.
Mar 16, 2009 | Toshiba Tecra 8000 Notebook
I have a update problem with the software
To run Settings download: Press menu on fone Go to Settings,,..then Setup Wizzard then Settings Download then press select this should then contact the provider for settings for fone ;-)
Jan 12, 2009 | Sony Ericsson K810i Blue Smartphone
How to update the firmware and software for my Microsoft Broadband Networking device
Back up base station settings Before you start, back up the current settings for your base station. To do this, follow these steps: 1. Start the Microsoft Broadband Network Utility. 2. On the Tools menu, click Management Tool. 3. When you are prompted to, log on to the base station. To do this, use the password that you created when you ran the Setup Wizard the first time. If you did not run the Setup Wizard, use the following default base station password: admin 4. On the Management menu, click Back up and Restore Settings. 5. Click Back Up Settings. 6. Click Save. 7. Type a name for the file that contains your base station settings or use the default name Config.bin. 8. Click the folder where you want to save the file, and then click Save. Back to the top Back to the top Disable firewall or antivirus programs For information about how to disable your firewall or antivirus programs, view the documentation that came with the program, or contact the manufacturer's technical support. Back to the top Back to the top Install firmware update Warning Do not install the firmware update from a computer that is connected to your base station by using a wireless network connection. If your wireless signal is interrupted, weakened, or interfered with while the firmware update is running, your base station may become unusable. Automatic update 1. Start the Microsoft Broadband Network Utility. 2. On the Help menu, click Check for Updates Online. The Broadband Networking Update Service checks for updates by connecting to Microsoft. This can take several minutes, depending on your connection speed. If any new updates are available, a download screen appears. Otherwise, you receive a ?No new updates are available? message. 3. Follow the instructions on the Broadband Networking Update Service page to update the firmware of your device. If the automatic update fails, go to the "Manual Update" section. Manual update 1. Download the MSBNDownload.exe firmware update. To do this, visit the following Microsoft Web site: http://go.microsoft.com/fwlink/?linkid=6... (http://go.microsoft.com/fwlink/?linkid=6790) 2. Save the file to a location such as your desktop or the My Documents folder. 3. If you are updating a wireless base station, use an Ethernet cable to connect your computer to your base station. 4. To run the update, double-click the MSBNDownload file. 5. Follow the instructions that appear on the screen to update the firmware of your device. While the firmware is being saved to your base station, the power light on the base station blinks and then turns orange. When the light is solid green, the update is completed. If the update fails, the power light continues to blink slowly until you successfully update the firmware. In this situation, you can try to update the firmware again, or you can reset the base station.
Feb 16, 2006 | Microsoft Broadband Networking MN-500...
Back up base station settings Before you start, back up the current settings for your base station. To do this, follow these steps: 1. Start the Microsoft Broadband Network Utility. 2. On the Tools menu, click Management Tool. 3. When you are prompted to, log on to the base station. To do this, use the password that you created when you ran the Setup Wizard the first time. If you did not run the Setup Wizard, use the following default base station password: admin 4. On the Management menu, click Back up and Restore Settings. 5. Click Back Up Settings. 6. Click Save. 7. Type a name for the file that contains your base station settings or use the default name Config.bin. 8. Click the folder where you want to save the file, and then click Save. Back to the top Back to the top Disable firewall or antivirus programs For information about how to disable your firewall or antivirus programs, view the documentation that came with the program, or contact the manufacturer's technical support. Back to the top Back to the top Install firmware update Warning Do not install the firmware update from a computer that is connected to your base station by using a wireless network connection. If your wireless signal is interrupted, weakened, or interfered with while the firmware update is running, your base station may become unusable. Automatic update 1. Start the Microsoft Broadband Network Utility. 2. On the Help menu, click Check for Updates Online. The Broadband Networking Update Service checks for updates by connecting to Microsoft. This can take several minutes, depending on your connection speed. If any new updates are available, a download screen appears. Otherwise, you receive a ?No new updates are available? message. 3. Follow the instructions on the Broadband Networking Update Service page to update the firmware of your device. If the automatic update fails, go to the "Manual Update" section. Manual update 1. Download the MSBNDownload.exe firmware update. To do this, visit the following Microsoft Web site: http://go.microsoft.com/fwlink/?linkid=6790 (http://go.microsoft.com/fwlink/?linkid=6790) 2. Save the file to a location such as your desktop or the My Documents folder. 3. If you are updating a wireless base station, use an Ethernet cable to connect your computer to your base station. 4. To run the update, double-click the MSBNDownload file. 5. Follow the instructions that appear on the screen to update the firmware of your device. While the firmware is being saved to your base station, the power light on the base station blinks and then turns orange. When the light is solid green, the update is completed. If the update fails, the power light continues to blink slowly until you successfully update the firmware. In this situation, you can try to update the firmware again, or you can reset the base station.
Feb 16, 2006 | Microsoft Broadband Networking MN-100...
Video Game Consoles & Games Logo
29 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
