No foreign object in housing. Some wear on plastic engagement part even though fairly new with only a dozen starts.
SOURCE: Paper not feeding into printer: pulls to the right and jambs
Normal
0
I suggest you get a sheet of Card Stock (Heavy
paper) and place it in the feed way. Then press the print
button applying a slight amount of pressure on the Card Stock so it
will feed through the printer. The reason for this is in some cases I
have been able to clear the paper track of debris that was deposited there
over time.
Worth a try, as I have fixed a number of printers this
way, saving costly repairs.
Hope this helps.
Bud
Posted on Jan 29, 2009
SOURCE: Pull Start Locks
Disassemble and, re-engage the pull cord locking pawl spring
Posted on May 20, 2009
SOURCE: my Chainsaw Husqvarna 345, won't start. With
I hope 2 different problems Marvin. I think the starter is most important, after you reply with findings we will take on the likely fuel delivery problem. Please do this and post back (below) with what you find.
Starter Handle difficult to pull:
1. Remove the starter cover. Does the starter operate smoothly? If yes, reinstall the cover and continue with 2, if not repair the starter.
2. Is the saw equipped with a decompression valve? Yes continue, no proceed with 3.
· Leave the ignition off, set the valve and pull the starter.
· Pull gently to release the valve. Is there a difference in the effort required?
· If yes continue with 3, if no repair or replace the decompression valve.
3. Was this saw perhaps operated in a lean condition (metal transfer from the piston to cylinder wall)? This may be caused by many things including but not limited to; leaky intake connections at the engine or carburetor; leaky crankcase seals; cracked fuel delivery lines; running on gasoline containing no 2-cycle oil.
· Disconnect the spark plug wire and remove the plug. Remove the muffler (clean it and the spark arrestor before reinstalling), hold a light at the plug hole and inspect the cylinder through the exhaust port. Is it smooth and shiny or does it appear speckled with dull gray spots or smears?
· Pull the starter slowly, inspect the piston as it rises and falls. Is it a dull gray without scratches and gouges?
· Hold the light at the exhaust port and look through the spark plug hole, inspect the cylinder above the exhaust port. Is it shiny and smooth or speckled with gray spots or smears?
Please Note: Any spots or smears on the cylinder or deep scratches and gouges in the piston indicate the saw was operated in a lean condition. Repair of this on a home owner quality saw often exceeds replacement cost. A repair estimate by an independent saw shop should be considered.
4. The last likely possibility is the saw has jumped timing. Inspect the flywheel and crankshaft under the starter cover. Are the woodruff key slots aligned and the key intact? Please take it to a good local saw seller/mechanic for a written diagnosis before authorizing any repair.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Starter fluid removes what little lubrication is provided by the fuel mix. I suggest a teaspoon of mix into open carburetor throat or the plug hole. Do not go to speed with the air filter removed.
Posted on Mar 29, 2010
Testimonial: "I think this is excellent advice. Thankyou very much"
SOURCE: pull cord will not retract
This takes some mechanical skill and knowledge to fix...definitely would take it back..I would have thought these manufacturers could have fixed these idiotic quality control problems by now....it goes on and on and....I know, folks would say..ya get what ya pay for....so in this case, you paid for a useless machine that you never even were able to use...that is NOT what you were SUPPOSED to get now was it!
Posted on Jul 16, 2010
SOURCE: when we started using toro
You must use at least a 12 guage extention cord . Your current cord mostlikely can not handle those amount of amps for long duration of time.
Posted on Nov 07, 2010
Dec 26, 2016 | Husqvarna Garden
Nov 26, 2015 | Garden
Sep 27, 2015 | Husqvarna Garden
May 24, 2012 | Garden
Aug 18, 2010 | Frigidaire ATF6000ES Front Load Washer
Mar 02, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Oct 21, 2009 | Garden
Sep 24, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Jan 10, 2009 | Husqvarna Chain Saw 20" Bar
Sep 08, 2008 | Hoover S3765-040 WindTunnel Bagless...
51 people viewed this question
