Question about RCA Televison & Video
My vibe axcess will go to menu but want let my go to set up on my rca truflat
5 Suggested Answers
Kindofcheap
  • 241 Answers
SOURCE: Can't connect my ps2 with my rca truflat
well if u have a VCR or DVD play with u can run it though the the vcr first then back up to the TV makes sure u have the correct channel on and if that is not the case u may have to buy a small switch box (wal-marrt) Cheap to add more AV in puts.
Let me know if this works!!
Thank U jayson
Please feel free to rate my suggestions.
we depend on your votes!!!
Posted on Jul 04, 2009
SOURCE: TruFlat 27F520T 27" TV: my rca controler is lost all settings are locked...
http://www.eserviceinfo.com/index.php?what=search2&searchstring=24F512T
http://www.devicemanuals.com/guide/Television/RCA/RCA-Tube-TV-27F520T-User's-Guide-TXpFeE16UT.html
Top one is a service and repair manual; the other is a user manual, both should assist.
Posted on May 20, 2010
gopakumarg43
  • 74858 Answers
SOURCE: How do I turn my RCA TRUFLAT FPA OFF?
Solution to this problem has been posted a few while ago.
Posted on Mar 11, 2012
gopakumarg43
  • 74858 Answers
SOURCE: RCA Truflat TV 27F522T is completely locked both manually and remote do not work. Was working manually but after checking menu for block accidently FPA locked not can't turn on tv at all.
You must have its remote control to unlock this TV. Try to make your remote control get repaired, and check these.
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Posted on Jun 29, 2012
Where is the setup button on the vibe axcess 5 n 1 remote. None of the buttons say set or setup
Any one have the codes to the Mitsubishi TV ? I really need them bought a remote and my kids lost my manual , can someone please help
Aug 18, 2015 | Televison & Video
How do i program a vibe axcess remote to a sanyo tv?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls.If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Aug 08, 2014 | Televison & Video
My rca truflat tv is stuck on fpa lock mode and I don't have the remote. How can I unlock it?
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Aug 09, 2012 | RCA TruFlat 27F520T 27" TV
How do you turn off the FPA lock on the RCA TRUFLAT TV? I Can't access menu.
Hello
First of all, you must ahve its original remote control to unlock FPA lock. If you have it, go through the folloing steps.
* Hold down Menu button on the remote control, and the Volume Down button on the at the same time for at least 4 seconds. "The set won't say so, but the lock will be released".
** Hold down Zero button on the remote control, and the Volume Down button on the TV. The set won't say so, but the lock will be released.
*** Hold down Menu button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. The set won't say so, but the lock will be released.
Mar 11, 2012 | RCA TruFlat 27F520T 27" TV
I have a rca truflat tv 27F522T how do i change it from mona to stero
This is a stereo TV:
From the manual:
Stereo Capability: Includes built-in amplifier twinspeaker
system; allows reception of TV programs
broadcast in stereo.
Use a stereo cable
Sep 17, 2009 | RCA TruFlat 27F520T 27" TV
Can't get channels.
You need a converter box on that unit.
Jun 22, 2009 | RCA TruFlat 27F520T 27" TV
RCA TruFlat 27F520T 27" TV Reset
Buy a new remote.
Look around the tv and find the menu button.
Generally there is a separate power button.
You can also download the manual:
http://tv.manualsonline.com/manuals/mfg/rca/27f520t.html
Dec 02, 2017 | RCA TruFlat 27F520T 27" TV
Televison & Video Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
