What use is the USB socket in a linear 26" tv
  • 4,103 Answers
Usb memory stick playback of Photos, Movie files AVI. MPeg 4, Ect
Posted on Dec 27, 2016
Testimonial: "Thanks this give me something to work with.Brian"
How can i boot from usb in hp elitebook 8469p
Set boot sequence to USB as first boot device then place your bootable USB stick in the socket and start the laptop.
Dec 18, 2014 | HEWLETT-PACKARD Hewlett Packard HP...
How do I replace the Leviton Bi-Pin on a Linear Fluoresent Lampholder?
Take the end cap off the fixture case - unwire the old socket and reverse the process for installing a new socket.
The little slots on either side of the socket slide onto the fixture case.
Nov 12, 2014 | Leviton 23351 T8 Or T12 Turn-type...
Where do i put my usb in the tv?
If the TV has USB compactable input, you can see a USB socket, either at its front panel or at the side. If there is such, insert the USB stick to that socket, and select the appropriate input selection to TV. For more details, refer TVs user manual
Sep 02, 2014 | Televison & Video
Can I hook up a copying device to my LG 26LV2500
Such as a DVD recorder?
Yes, conventionally a recorder takes the feed from aerial or box befiore the TV but recording whatever you're watching can also be done mostly by using one of the Scart sockets usually on the back of a TV usually identified as Scart 1 AV in/out which should be connected to Scart In on a recorder.
If there are digital output sockets - and digital input sockets on a recorder - you'll get higher image and sound quality than you'll get from Scart.
Sep 23, 2011 | LG 26 26LV2500 26 LCD TV
If I walk 26 sq feet for every 10 steps then what is my stride? I am having a hard time figuring this out or the pedometer is very inaccurate.
you cant walk in square feet as this is an area.
you walk in linear feet. a straight line.
if you walk 26 linear feet in 10 strides then your stride length is 2.6 feet or 2 and a half feet per step.
Oct 13, 2010 | Gaiam Walking Fit Kit Pedometer...
Men Mountain Bike (26"): How to adjust tention on the rear brakes...
Your bike likely has linear pull brakes so you will need to a. loosen the pinch bolt that holds the brake cable to the noodle (down at the wheel). You then pinch the brake in towards the rim with your hand until it's almost touching and then retighten the cable. You can then do some fine adjustment on how close the brake pads are the rim with the adjusting nuts up at the levers.
May 18, 2010 | Huffy Men Mountain Bike (26")
I have a 27
Hello pwilkers,This sounds very much like a vertical linearity/size problem; a malfunctioning coupling capacitor, a malfunctioning yoke transformer, or a problem in the vertical circuitry can cause this. I would suggest taking the TV to a repair shop because to troubleshoot this problem you will need a signal/pattern generator, an oscilloscope, a capacitor/inductor analyzer, and a multimeter. If you have these pieces of equipment this task becomes very easy, if not it is best that the problem be taken care of by a TV technician. I hope this helps,Thank you,Shuttle83http://www.electron-age-technologies-llc.com
Jun 10, 2009 | iLO Televison & Video
Hitachi L26H01U headphone socket doesnt work
User problem!! The main TV volume and the headphone volume work independently so you can have the TV volume set at zero and use the headphone volume. However I suggest getting a pair of headphones with it's own volume control.
Dec 26, 2008 | Hitachi 26HDL52 26 in. LCD Television
Ps3 sound setting for Acoustic Solutions tv
i had the same problem with my acoustic solutions astv 3619ws, you have to change the settings to:
linear PCM 2 ch. 44.1 khz
linear PCM 2 ch. 48 khz
linear PCM 2 ch. 96 khz
linear PCM 2 ch. 192 khz
you have to unselect all the other settings.
Feb 06, 2008 | Televison & Video
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
