Question about Miele Vacuums
Where can I take my non-working Miele vacuum to be diagnosed and repaired?
Problem with Miele Maverick telescopic wand - the plastic sleeve on the tube cracked and when I slide it back in the other tube won't fit In.
Call on the 15 year warranty!
Miele Vacuum Cleaner Accessories
https://www.miele.ca/en/c/vacuum-cleaner-accessories-1839.htm
All product benefits at a glance - Vacuum Cleaner Accessories. ... The Miele AirClean filter system filters more than 99.9% of all fine dust particles. ... Genuine Miele accessories are specially designed for your Miele vacuum cleaner. Missing: maverick
Spare parts & accessories - Miele
https://www.miele.ca/en/professional/spare-parts-and-accessories-135.htm Spare parts & accessories. At the end of the production of your appliance, Miele gives you a supply guarantee of up to 15 years for functional replacement parts. In addition, it is often possible to deliver original replacement parts for important functions. Delivery option up to 15 years following production end. Thanks to their ... Missing: maverick
Where to Buy - Miele.ca
m.miele.ca/en-CA/WhereToBuy.aspx Looking for: Appliances. Vacuums. Vacuum Repair Centres. Miele Certified WetCare Professional. Depending on what you are looking for, you might want to consider further refining your search. Learn more. Miele Retail Gallery. Miele Innovation Centre. Find Locations. Back ...
Apr 08, 2018 | Miele Vacuums
Why won't my Miele 8310 vacuum switch on?
The problem could be a restriction in the brush roll somewhere. Remove the brush roll and clean it and the nozzle housing. It could be an electronic problem which is much harder to diagnose.
Apr 10, 2016 | Miele Vacuums
How do I register my shark model NV42?
Shark has no customer service dept. They do not make parts, and the machines are non repairable. If you just bought it, take it back and get your money back before it's too late. Quality vacs can be purchased for the same amount of money. Miele, Sebo, Riccar are all better and in the same price range.
Dec 10, 2014 | Euro-Pro NV22 Shark Navigator Bagless...
S5830 canister vacuum
Do you mean S5380?
Phone local vacuum repairers and ask for estimates. The power cord is only fairly cheap. I would have thought that even with expensive labour it should cost less than 100$. He's probably trying to cover himself in case its something else. Have you contacted Miele? it is worth asking for a price if they'll give you one
Miele Inc Anything Else is Compromise
As far as replacing the cord yourself, it's not as simple as just connecting it, i think it has to be put on a tensioned drum.
Heres some more info
How to Access the Motor and Cord Retract on Miele S326
Miele vacuum cleaner repair
May 20, 2014 | Miele Vacuums
Miele 5281 vacuum cleaner permanently on high speed
Most likely the speed control board has failed. The solution for this is to replace the electronic unit unless you know of someone who can diagnose and repair circuit boards. The part is common and easily replaced for around $60. Miele's website can point you in the right direction for a service center, or tell me your zip code and I'll look it up for you.
Nov 09, 2013 | Miele Vacuums
My parents have a miele vacuum cleaner model s538. Do you know where I can obtain a repair manual for this vacuum cleaner. It is always on the "fritz". The vacuum has been taken for several...
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Miele model by clicking the link below.
http://m.miele.ca/OperatingInstructions/en-CA/Vacuums/Previous%20models/Miele%20Vacuum%20Cleaner%20Manual%20S500-548_S600-648.pdf
You can purchase a wide variety of high quality Miele replacement parts for your Miele vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Miele
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jul 07, 2011 | Miele Leo S5381 Canister HEPA Vacuum...
Miele vacuum dust problem
Hello. The problem you are having can be rectified with the new Miele FJM bags.
http://www.mielevacuumbags.us/
Also, if you have never taken your machine into a vacuum repair shop for an internal cleaning, please do so. J.
May 24, 2010 | Miele S4210 Carina Bagged Canister Vacuum
My Miele capricorn has started making an odd noise. It seems like something is blocking the engine. I've turned if off and on, and reset it and it still have the odd, almost loud barking noise. The power...
Greetings,
This is a major problem. The Miele vacuums motor should never make a loud noise, period. The way the motor is designed, it's quiet and should be quiet for the life of the motor. There are two motors on your Miele canister. One of the motors controls only the suction of the vacuum, while the other motor controls the power brush. Which one of your motors is making this horrible noise? You can tell this by removing the wands and power brush so that you just have the handle of the hose by itself. Now turn on the vacuum, do you still hear this noise? If yes, then this is a problem with your suction motor, and you need to bring this in to have an authorized Miele repair center take a look at it. The reason I say that is because you have a 7 year warranty on that suction motor, so if something is wrong with that motor, then this will be covered under Miele warranty. If it's the power brush motor that's causing the sound, this probably will not be covered unless the vacuum is under 1 year old. If it is the power brush, please just use the clarificaiton request here on Fixya and let me know, I'd be more then happy to try and walk you through diagnosing the power brush motor with you.
I hope this was helpful to you. If you did find this helpful, please be sure to click the thumbs up icon in the repair. I really appreciate it.
Chris J.
Mar 21, 2010 | Vacuums
My vacuum (miele s251i) will not turn on. I just changed the filters and bag. Just wondering if I have put the top filter in the wrong spot. Does it go under the black flip-up bit or on top of it? I do not...
Hello Miller_04,
Regardless of how the filter is put in the vacuum cleaner should turn on. Really is no way to put the filter wrong in these. I have a white star myself.
You can contact Miele Vacuum support and they can further troubleshoot or recommend a vacuum shop in your area to send it to for repairs
Miele Dealer Locator (vacuums: non repair)
(800) 579-4583
Monday-Sunday: 24 hours Miele Dealer Locator (vacuums)
(888) 785-2828
Sep 16, 2009 | Miele S251i Plus Bagged Canister Vacuum
Vacuums Logo
24 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
