Question about Samsung Televison & Video
I have a Samsung UN46F6300 TV and the external sound output has quit working. Would replacing the T-com board most likely fix this problem?
I've tried two different amplifiers that I know are working and I get no sound output. I did a factory reset on the TV, per Samsung, and that didn't fix it.
  • Samsung Master
  • 6,694 Answers
Check the audio settings menu of the TV. May be there would be an option to select the audio output whether you wish use inside speakers or external amplifier. if its there then You have to change the setting to external amp.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Posted on Dec 26, 2016
  • Ken Bloomquist
    Ken Bloomquist Dec 26, 2016
    Yes it has a selection for internal or external speakers and I do have "External" selected.
SOURCE: audio output not working
I had what may have been a similar problem and even talked to Westinghouse to see what I was doing wrong. Woman suggested there was a problem with the audio output port and suggested I exchange tv for another one. When the new one had the same problem, I discovered that to get audio out requires the volume to be turned way up on the tv (set speaker preference to external only if you don't want sound from tv speakers as well). If you have a digital optical connection on both the tv and the home theater, the sound output is independent from the tv setting and is easier to work with.
Posted on Nov 10, 2007
skotkolr
  • 558 Answers
SOURCE: Trying to connect digital audio output optical terminal to existing analalogue hi-fi amplifier
there should be on the tv out a red and white rca output or a coaxial, your yamaha my be too old to deal with the outputs on the tv. at the jvc website you can download the manual for this tv.
Posted on Apr 27, 2008
moto34
  • 155 Answers
SOURCE: Samsung LCD Tv
Try this:
Access menu service by press on your command, with your TV OFF:
INFO + MENU + MUTE + POWER ON
Then you should get access to Service Menu.
The last item says: RESET
This will do a reset to the TV.
Make no harm.
WARNING: If when on service menu you feel tempted to "screw" on anything FIRST take note on ALL you change! You can compromise the TV ...
Posted on May 03, 2008
  • 304 Answers
SOURCE: 46" Samsung LCD, no sound output whatsoever
First try hooking up a different source such as a DVD player or Cable box and see if you have audio. If you do then check the audio output from the computer. If you do not have audio then make sure the tv audio is up half way and turn off the set. When you do this you should hear the down chime provided you have the chime turned "on". If you do not hear the down or up chime then the sudio circuits on the Main bd are bad and the Main bd will have to be replaced. A quick way to check to see if the audio circuits are working is to listen for the up or down chime when turning on of off the set coming from the tv speakers speakers.
Posted on Jul 16, 2009
  • 257 Answers
SOURCE: Samsung lnr238w (23'') LCD TV has sound but no picture.
You got sound meaning the power supply and mainboard have no problem at all. Look at the back, have you seen back light lit up?
If there is light, the problem may come from T-con board.
If there is no light so the inverter board has defective.
Posted on Aug 14, 2009
My Samsung plasma screen PN51430A3DXZA tv all functions work but have no sound.
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electro-medical.blogspot.com/
Dec 30, 2016 | Samsung Televison & Video
I have a Samsung un46f6300 smart tv, and the sound cuts in and out every other second. It happens when I stream videos via youtube, use my blue ray player or any other input devices. Even on the startup...
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
Apr 10, 2017 | Samsung Televison & Video
Samsung Model PPM42m6hb No Volume
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Aug 05, 2014 | Samsung Televison & Video
I have a Samsung LE40B650T2 - no sound direct from the TV
It sounds that the sound processing section [digital circuts] are working well, and the fault must be either to the speakers, settings or to analogue audio amplifier section. Make sure that the Mute function is OFF. If it is OFF, and still you do not get audio output by tV speakers, surely the fault must be to audio amplifier circuits, provided speakers are OK. If your TV has a headphone out socket, this socket should also checked for proper interconnection.
Jun 24, 2012 | Samsung LE40B650T2 40 in. Full HD Crystal...
A Sharp LCDTV that, at first, had the screen turn white with sound then no sound or visuals other than the white screen. Suspicions that linked the problem to a game console were erased when it did the...
Tries tv unplug,replug it back like about an hour later.The tv will be resetting itself back to the factory original setting.The tv now,might be working.If not,the tv still have the same problems.This tv problems i fixed it before,the tv main Tunner signal board it is the causes and problems.It is a dying output board.The tv main Tuner signal board,that the board where all the external devices and the tv incomming broscasting signal cable wire plug into it.U can do some basic mechanical works like take things aparts and putting it back togeether again?Yes.Tries websites like Shopjimmy.com,Ebay.com to buy a whole tv main Tuner signal board for the replacement.
Apr 30, 2011 | Televison & Video
LG tv sound quit - will it work if I add external speaker system
Maybe!! It depends on where the audio sys failed. If it failed at the output drive, then you can take the audio off at the audio output jack and input it to your stereo system where there is an audio input. You'll need a cable with RCA jacks on it for this.
If your system is muted for some reason, this may not work.
May 16, 2010 | LG 32LB9D TV
Sound quit on Samsung rear projection TV
We solved the problem by purchasing a surround sound system and hooked it up to the Cable box thus bypassing the TV speakers. It was a cheaper fix than having a TV repair service guy come out and we have even better sound! Thanks anyway!
Jan 13, 2010 | Samsung HLN4365W 43" Rear Projection...
I have a plasma Samsung with picture but no sound
Internal sound board/amp is probably bad. But make sure that the speakers were not turned off in the sound settings menu for the television. You could try hooking up and external reciever to the audio output jacks of the TV and see if you get any audio from there. If you do at least you can still get sound from your tv...even though it is not from the internal speakers.
Sep 26, 2009 | Samsung LN-R328W 32 in. HD-Ready LCD...
TV has low sound output through right speaker of stereo receiver
try the balence. if no joy. try the cable if you have a meter also see if the cable and see if the cable has been reversed???????
Mar 27, 2009 | Samsung HL-S5087W DLP TV
Televison & Video Logo
32 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
