Question about Crafts & Hobbies
G gauge Lionel Pennsylvania flyer ready to run- wheels move furiously when off the track, when put on the track wheels grind and won't move
4 Suggested Answers
  • 13 Answers
SOURCE: I bought the 6-30089 Pennsylvania Flyer Train Set
Hope you got the set working. If not, look underneath the locomotive near the rear (under the "cabin"). There are two switches, one on either side. One says "Smoke", the other says "Reverse". If the "Reverse" switch was set to "Off" when the locomotive was in Neutral, it will stay in neutral even when the power is cycled or the "Direction" button is pressed on the power supply. Even in Neutral, all the lights will work and I believe the smoke element will heat up but won't puff. Whatever setting the "Reverse" switch is on, try changing it to se if that works. Hope this helps...
Posted on Jan 18, 2011
  • 38 Answers
SOURCE: Ι've just joined 2 ovals
It sounds as though you may have two defective transformers. Lionel has reported problems with some of their smaller transformers. I would have the transformers and the engines checked by a Lionel service station or contact their customer service department for help.
Posted on Jul 23, 2011
  • 34 Answers
SOURCE: Purchased a Lionel New York
The magnet may not have enough punch using track power. Recommend you use an aux power source fixed 10 to 13VAC supply and not track power. There may also be a slight + difference between the track magnet head and the plate on the coal car so that there is insufficient force to release the dump mechanism.
Posted on Sep 05, 2011
Lionel g gauge wont run on track
I think you have solved the problem. Check all the wheels to be sure that they all turn. The locomotive isn't powerful enough to drag a car with a stuck wheel.
Dec 25, 2013 | Lionel Trains Holiday Express G Gauge...
Help please. Lionel (30190) Thomas & Friends remote O gauge. Train won't move. Light comes no, nothing. I took the roof off and made sure the switch was in the on position. ??
First, check to make certain that the batteries in the remote are good.
Second, if the train has been running and the problem is new, clean your wheels and pick up roller on the locomotive, then clean the track.
Make certain that when you use the remote, you orient the antenna in an upright position and are within 6 to 8 feet of the locomotive.
If none of the above helps, contact the Lionel Service Department.
586-949-4100
Oct 07, 2013 | Lionel (31956) Thomas The Train Set
How to add water
Here's a link to Lionel Service Documents,,Owners Manual for you train.
http://www.lionel.com/media/servicedocuments/71-0018-250.pdf
Dec 02, 2012 | Lionel 6-30018 Pennsylvania Flyer Steam...
Instruction manual
Search the Internet, you may find a PDF file containing the manual. If all else fails, contact Lionel and request a manual.
Dec 08, 2011 | Lionel 'o/o27' 1645 4-4-2 Pennsylvania...
Purchased a Lionel New York Central Flyer Operating Freight Expansion Pack with a coal dumper. My set runs on O-gauge track, not fas track, but the magnet operation appears to be the same. The coal...
Apr 22, 2011 | Lionel New York Central Flyer
My train wont go in reverse
Try flipping the "Reverse" switch on the bottom rear of the locomotive.
Jan 03, 2011 | Lionel Pennsylvania Flyer Train Set
I bought the 6-30089 Pennsylvania Flyer Train Set last year. It's been in storage in the original box in a cool, dry place since last Christmas. I put it together, but it will not run. There is power to...
Dec 04, 2010 | Lionel Pennsylvania Flyer Train Set
Ι've just joined 2 ovals 40x60 lionel fastrack, used some other items 2 Lionel 6-12018 FasTrack O-36 MANUAL SWITCH RH, 2 Lionel 6-12017 FasTrack O-36 Manual Switch LH, A few 6-12014...
Nov 12, 2010 | Lionel 40 Watt Transformer Train Set Track...
Crafts & Hobbies Logo
85 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
