Question about Element Televison & Video
Element lcd tv bad picture - Element Televison & Video
Does the main board for element tv control the picture
There are two board which controls the picture. The TCON board and the main board.
If you wish to get some details about LCD TV repair then check the following link.
Jul 24, 2016 | Element ELDFT501 50" LCD TV 1920x1080, 60...
Why does my 40" element TV have sound, but no picture?
could be many issues. Take a flashlight and hold it right against the screen. Can you see a picture? if so the lcd is working but the backlights are not. If that is the case you could have bad power supply caps on the 24 volt section, a bad inverter board, or a bad ccfl lamp itself inside the back of the screen
Aug 16, 2014 | Element ELCHW402 40 in. LCD HDTV
I think my tv had a power surge tv went to static then shut off when i was watching a movie on my dvd
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 03, 2014 | Element Skateboards Element ELGFW551...
32" Element HD LCD TV screen often sticks to one
The tv have a long board called a LCD inverter board it is dying.This LCD inverter board help the tv LCD screen panel to have a backlight for the tv LCD screen panel to produce a picture.Tries websites like, to buy a refurbish a new long LCD inverter board for the replacement.
Oct 09, 2011 | Element Electronics FLX-3211B 32 in. LCD...
My element flat panel tv has sound, but no picture.
Ur LCD inverter board it dead.Replaced the LCD inverter board will get ur picture back.It a long board in shape.Tries websites, to buy a refurbish LCD inverter board for the replacement.
Mar 31, 2010 | Element Electronics FLX3210 32 in. LCD TV
I have an element ELCP 0371 lcd tv and the picture goes black intermittently
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc.
Please post back what you find.
Dec 18, 2009 | Element Electronics FLX3711B 37 in. LCD TV
Televison & Video Logo
22 people viewed this question
Top Element Televison & Video Experts
Are you an Element Televison and Video Expert? Answer questions, earn points and help others
