Question about Dimplex Heating & Cooling
How do I change the bulbs on a dimplex sal 20 E
2 Suggested Answers
  • 3 Answers
SOURCE: How to change bulbs on
To change the bulbs on the Dimplex Horton:
Remove the loose coals from the top of the orange plastic fuel bed moulding to prevent them falling inside the fire.
Remove the two screws, one either side of the metal grate at the front.
Withdraw the grate and you now have access to the two candle bulbs.
Posted on Feb 08, 2013
Change bulb in dimplex mrl20
Search YouTube for Dimplex Electric MRL20 bulb replacement.
This video link may be just what you need:
https://www.youtube.com/watch?v=UD3kROvvuX4
Nov 01, 2017 | Dimplex Heating & Cooling
How do you change the light bulb in a dimplex gem 20 heater?
Hi, First ALWAYS disconnet from the mains!
To change the bulb on your Dimplex you'll firstly need to remove the log effect, there are 2 small black head pozi type screws hidden at the front one on the left and one on right which your bulbs are under situated in their holders (as there are 2 of them) they are mini screw types as opposed to the standard baynot type replace the defective bulbs with like for like once fitted reconnect the mains and try if working, JOB DONE! Page 14 on the link shows exactly how to do it Regards Steve.
http://www.dimplex.com/cms/publications/7400070000r01.pdf
Aug 07, 2014 | Dimplex Compact Electric Flame Stove...
How do I change the bulb in my dimplex wynford inset fire?
On the back of the cabinet, about 3" to 4" up from the bottom, you should see a removable rectangular panel. Removing it, will give you access to the bulbs. Which are 60 watt, small base chandelier bulbs.
Turn the unit OFF & Unplug it, before removing the rear access panel.
Hope this helped you and thanks for choosing FixYa.
Aug 24, 2011 | Dimplex DS5603 Heater
Bottom bulbs don't work
Sounds light the 2- 60 watt small base, chandelier bulbs need changing. To access the bulbs and change them does require some dismantling of the base of the insert.
In case you have misplaced your Owners Manual, I have included a link to it that you can download and print for future reference. Pay particular attention to Page # 5 - Maintenance - Changing Light Bulbs.
http://partner.dimplex.com/files/domain4103/7205650100r04.pdf
Hope this helps you solve the problem. Please let me know. Thanks
May 07, 2011 | Dimplex DFI2309 Electric MidSize Heater
How to change bulbs on Dimplex HTN 20
If you have a compact fireplace in a cabinet mantle, you will need to remove the front Plexiglas and frame from the front of the firebox. Remove the logs, then the 1- piece ember bed (it just lifts out). This will give you access to the light bulbs.
If you what looks like an old wood stove, you access then from the rear of the unit. Remove the bottom access panel by unscrewing the 4 screws that hold it in place. You can then reach the light bulbs to change them.
In both cases, the replacement bulbs are small base chandelier bulbs.
Hope this helps to solve your problem.
Mar 11, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
We have a Dimplex Danesbury Dan 20 fire and need to change a bulb! How?
1.Remove the coals .
2.Remove the two screws in the front of the brass grate second bar down.
3.pull the grate assembly away from the fire.
4. The bulbs are now exposed.
Replace with 60 Watt SES clear candle bulbs. Reassemble in reverse order.
Oct 25, 2010 | Heating & Cooling
Dimplex Model 3087S
I have the dimplex dancing fire W..20 and I've just managed to change the bulbs!!!! Take the coals out and turn the fire upside down. In the bottom you can get your hand in the middle and unscrew the bulbs. There are two and they face each other. It's a real pain and a large mans hand won't fit. You meed two 60watt candle small screw to replace them. hope this helps.
Nov 29, 2007 | Heating & Cooling
Heating & Cooling Logo
26 people viewed this question
Top Dimplex Heating & Cooling Experts
Paul Carew
ashburton
David Burbee
David Burbee
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
