Wrong region code on my Ematic EPD121 portable dvd player. How can I fix this? I tried several dvds and none of them worked
Noggin
  • 944 Answers
SOURCE: whats region 1 dvd?
dvds are coded differently depending on which region of the world they are intended for. there are eight regions - check this link for more info; http://www.amazon.co.uk/gp/help/customer/display.html?nodeId=502554 this was a pointless idea that was supposed to limit video piracy, but only actually causes problems and increased production costs The US is in region 1, so the problem is the settings on your dvd/vcr as to what region it is coding the discs as. You may be able to change this in one of the menus, but it may be designed for only one region code output. Check the manual - if you need a manual or have trouble then please post the make and model of your dvd vcr recorder and we can try to help Hope this helps you :)
Posted on Mar 24, 2007
  • 4 Answers
SOURCE: region code
I have a firmware update supplied by Curtis that you can burn to a cd. Let me have an email address if you want it
Posted on Jun 12, 2008
rizla
  • 1463 Answers
SOURCE: DVD PLayer Region Unlock
hello mushkil
you could try the following
1. Turn on the unit
2. Open the loading tray
3. Press the "Setup" button on the remote
4. Navigate to the "Preferences" page using the right arrow key
5. Enter 138931
6. You will now see the current region code displayed
7. Use the Up/Down arrow keys to select the region required or "0" for all
regions
8. Press the "Play" button on the remote
this should unlock it to all regions .
riz.
Posted on Aug 16, 2008
SOURCE: GPX Portable D.V.D Player : No Disc/ DIsc Error
I check the motor. for sping its good. clean the liner eye it's good also check for bad hardness connection it,s with um meter. ok what can it be
Posted on Nov 18, 2008
brownline45
  • 310 Answers
SOURCE: Sony portable DVD player wont load DVDs
maybe the spindle motor is defective so it cannot read the disc. just bring that your dvd to sony service center to fix your dvd.
Posted on Jun 19, 2010
It plays cds but not dvds comes on screen wrong disc each time
A lot of DVD players are region specific ie. you cannot play US dvds in the UK or from Asia , depending on where the region code for the dvd player is set depends on which dvds are playable
Feb 26, 2015 | US Logic DVD800P Portable DVD Player
Toshiba SDP72S - Help to unlock this region 1 portable DVD player please. I followed those instructions given by this forum and it did not work. When it comes to pushing the memory button it states...
To changethe Region code on your DVD player, open Control Panel - System - Hardware -Device manager, and click on DVD/CD ROM drives, then right click on the DVDdrive and click Properties then click on DVD Region.
You can enter a new region and it also shows you how many changes have beenmade.
NOTE you can make only 4 changes and the player will lock permanently on the4th change.
If you want to play DVDs from any region you maybe able to upgrade the firmwareto make it region free BUT if you make a mistake or installed the wrongfirmware the player will be a piece of junk.
The best solution to make the player region free is to install a piece ofsoftware that allows you to play DVDs from any region. There are severalavailable on the Internet but my favourite is DVD-Region Free From: -
www.dvdidle.com/dvd-region-free.htm
Dec 08, 2011 | Toshiba SDP72S Player
Says loading disk and then says wrong disk everytime. tried several different dvds. always the same answer!
The DVD portable player and the DVD disc came from the same countries?Ur DVD portable player and DVD disc u are using might have the wrong region DVD disc format frequencies.Like PAL frequencies only play Euroupean,Asia,Middle East,Austriala and Africa products.NTSC frequencise play only USA,Canada and Mexico DVD Disc products.
Dec 13, 2010 | Coby 7" Widescreen TFT Portable DVD Player...
I power it up and insert a disc and it says Wrong Region on the screen. This is a Canadian unit that has worked fine for two years now, and I've tried several different DVDs which work fine on my larger...
If you have relocated then the region code may need to be changed. However using region 0 is most practical. Clean the optical head of the player with a CD/DVD cleaner too & see if it responds............sodeep
Sep 25, 2009 | Mustek MP70C Portable DVD Player
Pe 705 is saying wrong region when yo try to play a dvd
The solution depends on where you bought your dvd player, certain dvds are released in north america or japan, etc, and they have different 'region codes' - meaning they can only be played by devices that have a matching code. To clarify, if you bought your dvd player in america, chances are you can only play dvds released in north america. For more information on region codes please go to http://en.wikipedia.org/wiki/DVD_region_code
Jul 14, 2009 | Eddie Bauer PE702 Portable DVD Player
Displays "No Disc"
It can be several reasons
1. Disk is upside down
2. Lens is durty. CD/DVD cleaning disk will help
3. Disk is in different formate (for instance NTSC for US but you trying to playback disk in PAL)
4. Disk has different region code (look is the dvd player and disk have the same code, or ALL Regions code)
Good Luck
Dec 26, 2008 | Durabrand DUR7 Portable DVD Player
Problems playing DVDs due to regional codes.
FIRST
CONFIGURE YOUR PLAYER IN THE LANGUAGE YOU WANT TO LISTEN, AND THE SUBTITLES YOUR GOING TO USE BECAUSE ONCE YOUR DISC IS BEEN REPRODUCED NONE MENU IS GOING TO WORK.
SECOND.-
PUT YOUR DISC ON YOUR REGION YOUR GOIG TO USE AND, SET ON YOUR REGION AND INMEDIATLY AFTER TO CLOSE THE COMPARTIMENT START TO PUSH CONSTANTLY, (TOO MANY TIMES), THE NUMBER "6" - ENTER
YOU HAVE YO PUSH IT 10 TO 15 TIMES , AND THEN YOU CAN SEE THE MOVIE WITH THE LANGUAJE AND SUTIBLES THAT YOU HAVE SELECTED BEFORE.
ENJOY YOUR MOVIE.
MAYBE FLIP UP A MESAGE LIKE " REGION INCORRETA" "WRONG REGIION", DONT WORRY, YOUR VIDEO IS GOING TO REPRODUCE HOWEVER.
IF 6 - ENTER DOESNT WORK, TRY WITH 7 - ENTER A LOT OF TIMES (I MEAN CLICKING) OR 8 OR 9 OR 10, IT DEPENDS OF THE NUMBER OF CHAPTER THE MOVIE STARTS.
ONCE YOU OFF YOUT REPRODUCTOR IT RESTARTED LIKE YOU NEVER DID THIS PROCEDE.
YOU HAVE TO DO THIS IN EACH MOVIE YOU WANT TO PLAY.
or1. Switch on the player
2; Pop open the CD compartment
3. Enter the following code (using the remote): 2812
4. Highlight the region
5. Change to 9 (for Multi-region) using the 'Enter' button
6. Hit 'Clear' to exit
7. Pop in a DVD and enjoy!
Dec 03, 2008 | Sony DVP-FX810 Portable DVD Player
Wrong Regional Disc.
DVDs are ecoded with region codes to indicate what area of the world they are made for. These codes may be 1,2,3, etc depending on which region they are made for.
DVD player read these codes and if the disc region code does not match the region the device is made for, the player will not play the disc.
Region 1 is for USA so most DVDp players made for use in USA require region 1 discs.
Some DVD players called multi region DVD players can be set to play different region DVDs but they are typically more expr=ensive then one region players and the code must be changed each time a different region disc is played.
Aug 27, 2008 | Audiovox D1710 Portable DVD Player with...
Portable Mustek DVD player indicates Wrong region
Thanks Guest Mar 07, 2008!
Solved my region problem with the code 9735.
Nov 30, 2007 | Car Audio & Video
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
Electro Med Services...
