Question about The Toys
I have the Air Hogs Axis 200,and was flying it indoors the one day and it hit the ground harder than normal. I set it back up and when I tried to start it,the helicopter went crazy. What should I do?
There are two blades and I figured out that the top one was not working correctly. It was not rotating as fast as it should be. I think it might need a replacement blade. But is there any other way?
SOURCE: crashed blade 400 repaired it unsure of servo settings helicopter tilts forward and tends to spin around
dude is your swash plate levle if it is not it will cause your heli to drift
or if not go on youtube and reset your dx6i settings
Posted on Sep 29, 2009
SOURCE: my john lewis mini helicopter auto stability control not flying
I had a similar problem with mine, check if the central shaft on which the blades turn hasn't become lose and is no longer engaging the gears on the underside of the helicopter.
If the whole shaft can move up and down then this probably means it has come loose, you can solve this by squeezing the lower set of blades towards the bottom gear with your fingers. You should feel the bottom blades move slightly down, if you push them too far they will stick against the main body so you might need to pull them up slightly.
Posted on Jan 03, 2010
Testimonial: "thanks very much, you are absolutely right about the problem. i had difficulty moving the blades so put some clingfilm (!) in the gap on the shaft."
SOURCE: heli max hicro helicopter just keeps spinning in circles
Spinning is caused by one of the main propellers rotating faster than the other. If both propellers are secured tightly to their drive shafts, the spin control knob on the remote control can be used to stop the spin. However, if one prop is slipping with respect to the other, the spin control knob will not fix the problem.
I've found that the set screws holding the propellers to the drive shafts tend to loosen after a while. If one prop is a bit loose and the other is tight, the relative slippage will cause the helicopter to spin.
To check, turn off helicopter power and manually rotate each propeller separately, watching the nylon gears in the body. If the propeller is moving and its drive shaft gear isn't, the propeller is slipping because its set screws are not applying enough pressure on the propeller's drive shaft.
Carefully tighten the set screw and the problem should be fixed. DON'T OVERTIGHTEN, or the plastic threads for the set screw will be stripped and the propeller assembly will be ruined.
Posted on Apr 23, 2010
SOURCE: After flying for 2 weeks,
Let me know if you ever get an solution for this. I bought one for my son and the same thing is happening. We're able to get it about a foot off the ground but that's it.
Posted on Sep 05, 2010
SOURCE: I have Brookstones silver bullet
Sometimes the metal weights fall out of the top rotating bar causing the blades to be out of balance and the bottom blade to hit the tail. Check to see if both the weights are in the top bar.
Posted on Jan 13, 2011
My 9116 double horse RC helicopter just spins clockwise in circles, on the ground or in the air. I can hover it, but only spinning. What could be wrong?
Air Hogs remote control aircraft are designed to be easy to fly and use, and rarely have flying issues. However, there are the occasional issues that the company can't really predict. Some Air Hogs helicopters, for example, have a hard time flying forward without some assistance. If you're having this problem with your helicopter, this can be annoying, but it is not the end of the world. There is as solution, and it's easier than you might think.For more information: Playground Mats and Playground Flooring Tiles Soft Play Equipment
Jan 10, 2014 | Toys
My air hogs stinger since day one will not fly straight up.
Look for a trim setting or reference trim the users manual. It is usually a dial on the side of the remote.
Oct 10, 2012 | Air Hogs Glow In Dark Havoc Stinger Rc ...
I need a new blade were can I find one seems to have quite a large selection of "replacement blades" but you will need to look them over to see if one fits your exact needs. Good luck!
Dec 31, 2011 | Air Hogs Spinmaster Air Hogs Havoc...
My green air hog helicopter is spinning on the ground, it won't lift and fly, how do I fix it?
There is a problem on the motor gear, check the underside where you could see a big gear that should spin when you try to lift the helicopter. Check both big gears if they rotate/spins.
Usually the problem is the small gear on the motor shaft that is not aligned to that big gear. Check on it and adjust the small gear of the motor.
Hope that copter flies high.
Thanks for asking FixYa!
Aug 09, 2011 | Air Hogs Havoc Heli Helicopters
I have an air hogs sharpshooter helicopter and it wont stop spinning when i try to fly it and it only gets about a foot off the ground
it could be that you just need to use the adjustment nob it is next to the right joy stick u can turn it to make the heli fly straight. or one of your blades is not working like it should.
Jan 06, 2011 | Master Heaters Air Hogs Sharp Shooter...
My AH-64D LONGBOW helicopter spins out of control when i try to fly it how can i fix this problem?
make sure the tail motor does not have any hair stuck in it take of the little propeller and clean it.
next adjust the trim so when your taking off so helicopter will not spin any more and your good to go
Dec 13, 2010 | Spinmaster Air Hogs R/C Ah 64 Apache Havoc...
How do i fly my spin master air hog rc helicopter all it does is go in circles
If you trimmed your heli but it still can't work, try using the direction knob to trim it instead. When it goes clockwise push th knob leftwards and hold, and vise versa for anti-clockwise. Or, push and release repeatedly in the direction mentioned till it flies straight. Tested on around 6 air hogs helis and works each time. If you still can't trim you might try it after turning it off or contact the service centre.
Feb 05, 2010 | Spinmaster Air Hogs RC Reflex Micro...
My air hogs havoc stinger will not fly,lost instructions
This might help:
Jan 11, 2009 | Air Hogs Glow In Dark Havoc Stinger Rc ...
Havoc wont fly
try spining the blades.
Jan 01, 2009 | Air Hogs Havoc Heli Helicopters
Air Hogs Micro Havoc Heli spins wildly
The same thing happened to me. It turned out that some hair and fibers got wrapped around the tail rotor axis. I pulled the tail roter off and cleaned it out. After I put it back together it worked fine. I hope this helps.
Dec 26, 2008 | Air Hogs Toys
Toys Logo
51 people viewed this question
Top The Toys Experts
Paul Carew
Lawrence Oravetz
Are you a The Toy Expert? Answer questions, earn points and help others
