Question about Saws
How to align the laser sight on Kobalt 10 mitre saw
SOURCE: ryobi compound mitre saw sliding 10
rotating the laser in its' housing moves it left and right. The hexagonal bolt on the sides needs to be loosened to do this, then it can also be adjusted up and down. Make sure the trigger to the saw is locked before doing this.
Posted on May 08, 2009
  • 8404 Answers
SOURCE: Compound mitre saw won't shut off unlss unplugged
Relace the switch.
I am presuming the lock button has not been inadvertently pressed ... Check that first.
The condition you deacrive is dangerous. Please fix it before you use it any more.
If you require additional assistance, let me know.
Otherwise, check RepairClonic.com for parts and technnical instruction from their crack crew.
Thanks for the opportunity to lend you a hand
a
Posted on Sep 26, 2009
  • 12 Answers
SOURCE: Mastercraft Maximum Compound Mitre Saw
Mastercraft's help line is 1-800-689-9928. However this saw is no longer in production and parts are available only until stock is depleted. It was supplied by an european company called WMH Tool Group that apparently doesn't supply CTC any longer.
Posted on Aug 31, 2010
rowdy45176
  • 2176 Answers
SOURCE: macallister mitre saw sparking
I would plug it into another outlet first. The small arcing that you see might be normal especially on stopping because of the brake. If another outlet doesn't work then I would take it back. Upon startup this saw will draw more than the rated running amps.
Posted on Mar 01, 2012
  • 17 Answers
SOURCE: i need to know where to adjust my 10 inch kobalt miter sliding saw for a true 45
Should be in the back of the saw wher it pivots
Posted on Mar 22, 2012
I need a arbor nut and washer for a kobalt 10 inch table saw model kt 1015
First try Lowe's, the only Kobalt tool retailer. If they can't help you, the Kobalt customer service number is (888) 356-2258. I looked for Kobalt power tool parts onlline without success. That may suggest that their one-and-only retailer is the only source, or it may mean you should look for a replacement saw, basing your choice on likely future parts availability.
Oct 04, 2017 | Saws
How do I alligne the blade to the miter fence on my table saw. delta 10" no.34-670. thanks gregg
Just performed the same task on another brand table saw. un-sungged the bolts holding the table to the saw frame and tapped corners of the table while measuring distance from the mitre slot to the lead and tail of the fully extended saw blade (not from the teeth) calibrated to a perfect 90 degrees position. I figured out how to use a digital miter gauge to measure the distance from the blade to the edge of the mitre slot. You can tap appropriate corners to align.
Note when you are in alignment, re-tighten the bolts a little at a time, measuring and tapping as you go.
May 17, 2017 | Delta Saws
How do you adjust the laser from side to side on a Kobalt 10-in 15 Amp Slide Compound Laser Miter Saw
goto https://www.lowes.com/pd/Kobalt-10-in-15-Amp-Single-Bevel-Sliding-Laser-Compound-Miter-Saw/3512785 and scroll down to guides and documents download PDF
Dec 22, 2017 | Measuring Tools & Sensors
Ryobi 10 in Mitre saw with laser, switch / motor wiring diagram?
capacitors are known as capacitors or condensers. Both do the same job of storing electrical energy and then releasing it when the current flows back . They are used to either start an electric motor or stop arcing on the brushes by absorbing the current flow as it stops over each commuter bar of the armature
Dec 02, 2012 | Ryobi 10 In Miter Saw With Laser
I have a ryobi 10" mitre saw and i took the guard
I don't know but if you have figured it out let me know. I have same prroblem.
Apr 19, 2011 | Ryobi 10 In Miter Saw With Laser
Bosch gsm 10 compound mitre saw. which way does the screw turn to undo blade
On the Bosch compound sliding miter saw, turn the blade nut clockwise to remove it.
Jul 26, 2010 | Bosch 12" Dual - Bevel Compound Miter Saw...
My makita sliding mitre saw is off a few degrees How do I adjust...non laser...10''
move the blade until it is square to the fence then loosen the screws on the table with the degree increments and set to zero.
Nov 19, 2009 | Makita 10" Compound Miter Saw LS1040
Looking for a site to download a manual
I understand that Denali is made by GMC. Here is the website for GMC miter saw manuals.
http://www.gmcompany.com/index.cfm?module=manuals&cid=54
See if the 10" miter saw with "redeye (R)" is the same as yours.
May 30, 2009 | Skil 3800 01 Factory Reconditioned 10"...
Ryobi compound mitre saw sliding 10" laser line is 1.5 mm out to the cut is there any way to adjust it
Apr 17, 2009 | Ryobi Circular Saw W/Dual Laser
Saws Logo
77 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
