Question about Garden
2012 Fisher 3 port 2 plug mm2 HT sys. Melted 11 pin plugs, bad wire, replaced both sides with new. NO HEADLIGHTS. Plow all ok and signal lights ok. Can I test the module before replacing it? Thanks.
  • 132 Answers
SOURCE: 2000 Pontiac Grand Prix interior fan speeds 1-4 not working
Check the ground, the resistors are accully resisnting the Negitive Current.
Posted on Jul 30, 2008
relaga58
  • 158 Answers
SOURCE: 1997 nissan altima has no spark at the plugs.
get those sensors connected to the output of the module tested cause its ruining the module
Posted on May 10, 2009
SOURCE: 1990 Chevy Silverado Pick-up. No spark from the plugs.
How about the MAP SENSOR? Do you check it out?
Posted on Jun 25, 2009
  • 67 Answers
SOURCE: with plow lights pluged in do not have low beam on
ca mention may be wrong un plug the 2 chk fuse and start overthen u no
Posted on Dec 11, 2009
  • 466 Answers
SOURCE: Im looking for a fisher
YOU WILL HAVE TO GO TO FISHER. TRY TO GOOGLE FISHER AND SEE WHAT HAPPENS. THANKS MOTOR62500...
Posted on Dec 22, 2010
Driver side rear turn signal and brake light don't work when I turn on headlights,
Check your wiring and connections for the affected light. This is symptom of a bad ground for the dual filament bulb.
Dec 28, 2016 | 2012 Dodge Avenger
Off/on light is flashing on HT handheld control and nothing is working on fisher plow but the headlights
joystick controller is saying its not connected to plow valves or pump , this happens a lot due to plug corrosion , using a squirt or two of "electric contact cleaner" in both sides of plugs helps with this
Jan 19, 2016 | Fisher Minute Mount Plow Joystick...
I have a minute mount plow, when I try to use it only goes to left and right side but doesn't go up, when I try to lift the plow goes to the right. What can I do
2002 Fisher Minute Mount Inst-Act Wont Angle [Archive] - PlowSite ...
www.plowsite.com > ... > Truck & Equipment Repair
Nov 17, 2011 - 90 posts - ‎9 authors
My plow went up it was jerking and did it in steps , but , it got there . Now , it onlyjerks when i try to angle it right or left or up . I filled the fluid ... Drop it and if it doesn'traise you can just use a jack and shorten the transport chain to hold it. .... I do havecontinuity on the plow side for all 3 wires going to the plug . Hooking Up A Fisher Minute Mount 2 In Under 1 ...
Feb 1, 2011
Plow Wont Angle
Oct 19, 2010
What's wrong with my plow?
Jan 9, 2003
Looking For Minute Mount Tips
Feb 13, 2002
More results from www.plowsite.com
Ultramount Intermittent Angle Problem - Snow Plow Forum - L
Dec 27, 2015 | Cars & Trucks
Fisher minute mount to 2001 chevy 1500
This sounds like there may be a short on the passenger side causing the circuit to draw more amperage than it should, thus dimming the headlights. try using an amp clamp on the blinker wire at different spots to see if the amperage jumps up.
Jan 31, 2014 | Cars & Trucks
The tail lights do not work. The headlights, blinkers, and brake lights work. I checked the fuses and they are all good.
It can be faulty tail light bulb or its issue with tail light control switch or its wiring's are short.
Check the voltage at fuse slot of tail light.Do you receive 12 volt there.If not,then it says tail light switch is not receiving power supply.
There are few help links related to your problem.I suggest you refer the list and check the help links.Click the link below:-----
1994 Toyota Camry: Bypass Tail light Relay Circuit? http://whatisbyme.blogspot.in/2012/04/1994-toyota-camry-bypass-tail-light.html
2008 Toyota RAV4: Replace Tail light Lens Cover?
http://technoanswers.blogspot.in/2012/04/2008-toyota-rav4-replace-tail-light.html
2003 Chevrolet S10 Tail light Fuse http://schematicsdiagram.blogspot.com/2012/11/2003-chevrolet-s10-tail-light-fuse.html
--------- Chevrolet Parking light and Tail lamp light Wiring diagram http://schematicsdiagram.blogspot.com/2012/11/chevrolet-parking-light-and-tail-lamp.html
---------- Car Tail Lights Not Working?
http://schematicsdiagram.blogspot.com/2011/12/car-tail-lights-not-working.html
Turn Signal Not working http://technoanswers.blogspot.com/2012/11/turn-signal-not-working.html
---------- Right turn signal not working on Pontiac Car?
http://schematicsdiagram.blogspot.com/2011/12/right-turn-signal-not-working-on.html
Only one side indicator light working on car?
http://schematicsdiagram.blogspot.com/2011/12/only-one-side-indicator-light-working.html
Turn signals not working on 1987 Jeep Wagoneer? http://schematicsdiagram.blogspot.com/2011/12/turn-signals-not-working-on-1987-jeep.html
SOLVE YOUR 4 WAY FLASHER RELATED PROBLEMS HERE
http://repairhelpcenter.blogspot.com/2012/11/4-way-flasherturn-signal-flashersignal.html
Thesedetails will help.
Thanks.
Nov 23, 2012 | Cars & Trucks
How do I get to the front headlight to change it
Re: Replace headlight bulb
  1. INSTALLATION GUIDE:
  2. BMW E38 99-01 HID TYPE 7 Series 1PC Halo Amber Projector Headlights
  3. Parts Identification:
  4. Projector Headlight
  5. Halo & L.E.D.
  6. Bottom of the Headlight:
  7. Ballast Bracket, Halo Wires(red/black)
  8. Turn Signal Adaptor
  9. TOOLS REQUIRE
  10. 10mm - 8mm socket
  11. Philip Screwdriver
  12. Crimper/Pliers
  13. For more information about how to install your vehicle, come visit our youtube page on
  14. http://www.youtube.com/spyderauto
  15. Remove the facotry headlight from the BMW. First remove the front panel cover below the headlight to access the bottom screw of the headlight housing. There is also two screws on the top of the housing.
  16. Once you have remove the headlight, turn the headlight around and remove the bracket that holds the Ballast. Then remove the ballast using a philip screwdriver.
  17. Unplug the wire from the ballast, and then remove the Xenon Plug from the housing. Put the Ballast aside.
  18. Carefully remove the D2S Xenon Bulb from the factory housing. Once you have remove the bulb, transfer the bulb to the Spyder headlights.
  19. Remove the bracket from the Spyder Headlight, and then install the ballast on the housing like the original. Once you have put the ballast on, put the bracket back on.
  20. Remove the Panel Cover bracket from the original headlight to the new Spyder Headlights as shown here.
  21. STEP:
  22. Install the Spyder turn signal socket if the orignal does not fit, unplug the factory plug from the harness and plug the new one on.
  23. Install the Spyder Headlight back on to the vehicle. Plug the Harness back on, the halo/L.E.D. Wires is connect to the Parking lights. These wires are optional to your vehicle, you do not have to wire them together.
  24. Factory Xenon Headlight
  25. Spyder Projector Headlight using Factory Xenon Lights
  26. STEP:
BMW e46 HID Headlight Replace
Nov 22, 2012 | Cars & Trucks
Lights on a fisher xtreme plow wont work
I'm guessing that you have already checked to make sure there is power going to the plow lights. If not use a test light and make sure. The most likely problem is the grounds from the plow lights themselves to the frame. Take the lights apart and check and/or replace the grounds, wires inside the case take a lot of vibration and that can cause them to fail.Don't forget to check the bulbs to be sure they're good too. Hope this helps.
Dec 17, 2009 | 2007 GMC Sierra 2500HD
I have a fisher minute mount and one headlight dim
A poor ground. Check the ground wire inside the light housing itself and then make sure it is getting a good ground where it mounts to the plow frame. Hope this helps.
Dec 05, 2009 | 2001 Dodge Ram 2500 Truck
Jul 28, 2008 | 2002 Pontiac Grand Prix
Garden Logo
20 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
