Question about Home
Seat fasteners are loose and moving on Pfister toilet
kachbibi1
  • 979 Answers
SOURCE: How to tighten the hinges on a slow close toilet seat?
You don't want to overtighten since you could crack the porcelain. Are your rubber washers in good shape? This will help. You should be able to do this w/out doing any damage.
Posted on Jan 28, 2009
woobie dog
  • 1273 Answers
SOURCE: Toilet seat connectors mounted on toilet is loose
There should be a way to tighten the bolts without going that far Here's two things:
Look at the lid, with the seat down. The bolts are sometimes covered with a snap-in palstic cap or flap. If so, pry up with a screwdriver. Then use a screwdriver and wrench to tighten.
If the bolts appear to be cast as a part of the hinge assembly, you should be able to reach around the seat to the back side (no pun intended) of the toilet, and tighten with a wrench.
I sometimes use a 'mirror trick' to get a better idea of what's back there. Just use a small mirror and hold it to where you can see the bolt and not on the back.
Hope this gets you going (oops, another unintentional pun).
Best regards, --W/D-- please feel free to rate this solution..thanx!
Posted on Aug 01, 2009
  • 54 Answers
SOURCE: loose Toto toilet seat
Lift up plastic caps located on ends of hindge behind seat. use flat screw driver and hold the nut under the outside toilet rim with your fingers or a pair of pliers. Do not over tighten or might crack the bowl.
Posted on Sep 14, 2009
  • 11800 Answers
SOURCE: I have a Villeroy and
There is no way to adjust the hinges themselves, just their position on the bowl relatively to the seat cover. If they are loose then they are damaged. Since they are guaranteed for 10 years this is clearly a manufacturing defect.
To fix that you will have to contact the ones that sold it to you and they will replace it free of charge.
Posted on Jun 09, 2011
  • 300 Answers
SOURCE: Toilet lid not closing quietly. It drops down
Replacement "hinge kits" are available here.
Posted on Jul 04, 2011
How do I fasten a loose toilet seat on GSI Panorama which does not have the new quick release function?
Underneath below seat hing you will find a nut usually plastic. Tighten it if screw spins on the hinge should be a cover located on top of the screw, pop it up and use a coin to hold it.
Jan 10, 2018 | Home
How to tighten a vitro nupva toilet seat.
Christina, how to tighten or install hidden fasteners on your toilet seat. check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Remove Vitra Shift toilet seat
Soft Close and Quick Release Toilet Seats Installation
How to fix loose toilet seat
http://vitraglobal.com/
Jun 27, 2016 | VitrA Home
Why does my toilet seat pop to the side when you sit down on it?
It may not fit but most likely the attachments at eh back are loose.
Sep 21, 2014 | Home
How do i remove a broken bolt which is embedded in the toilet, the bolt keeps the toilet seat lid fastened to the toilet?
There has to be either a nut and washer under the toilet, or if its reversed a bolt head with a washer under it holding it down. To remove it you can either use a hacksaw blade between the bowl and the bottom of the seat. Or use a dremel tool to slowly cut away the metal rod, etc., from the top. If using hacksaw put down some masking tape on the bowl so you don't scar up the enamel surfacr of the bowl. Work slowly and you will eventulaly cut through it.
Aug 16, 2014 | Crane Plumbing Home
Toilet seat too loose
Is the nut thats on the under side fastened all the way and If you've done that and the screw keeps getting loose then the threads inside the nut or on the screw may be worn away. If thats the case, you may have to by some new screws and I'm not sure if they sell those separately you would usually have to buy a new toilet seat to get new screws, but try home depot or walmart.
May 10, 2013 | Home
Home Logo
63 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
