Question about Intel Motherboard
Connect the SATA Hard Drive to MSI VIA VT237R motherboard
I connect the New SATA Hard Drive to the motherboard, but it is not detected and didn't show the sata drive in the BIOS. I kindly request to send the MSI VIA VT237R motherboard manual for resolving problem.
  • 641 Answers
Go into the setupn and enable the sata settings if you are useing a ide cd drive youll have to enable both sata and pata drivs
Posted on Jul 21, 2009
My hard disk is 80GB (IDE) when i try to connect another hard disk 320GB (SATA) the mainboard doesnot detect 320GB SATA hard disk and my pc restart every moment note: MSI 848P NEO-V
Hello samanozy ,
Some older motherboards will not support a too wide HDD whatever the interface.
Another point is to know if you have set the boot priorities in the BIOS . Your machine is maybe attempting to boot from the Sata drive .
Best regards ,
fanaudi .
May 13, 2011 | MSI 848 NEO-V P4/Intel...
MSI MS-7142 motherboard problem is not support 500gb sata hard drive
Your motherboard can connect up to 2 serial ATA devices and for this reason, it can support a 500GB sata hard drive.
Oct 11, 2010 | MSI K8MM-V Motherboard
I am not able to detect sata hard disk in msi mother board
Your model K8MM-V motherboard does not have a SATA controller only IDE disk controllers and therefore it cannot detect a SATA hard drive.
To install a SATA hard drive on this motherboard you need to purchase a PCI SATA disk controller and install it on the PCI expansion slot and then attach the SATA hard disk to this SATA controller.
Aug 21, 2010 | MSI K8MM-V Motherboard
MSI K8T Neo 2 not recognize Hitach 1 TB Sata
This is a quote from VIA:
"CHIP FIRM VIA issued a note to its customers telling them of problems with chipset support for hard drives using the Serial ATA II standard.
It said that VT8237 and VT8237R chipsets don't provide forward compatibility for S-ATA II, which is important as hard drive makers are beginning to manufacture this type of drive.
But Via is readying the release of VT8237R Plus, which will solve the problem. This means that motherboard makers that use the former chipset should clear their inventory before September.
Hard drive manufacturers position with S-ATA II is as follows, said Via in its note. Western Digital and Samsung are already shipping these devices, while Seagate and Maxtor will start shipping them during this quarter.
If you connect S-ATA II drives to an old Via chipset which includes the VT8237, VT8237R, VT6420 and VT6421L, the devices won't be detected.
Some mobo makers, such as Epox, have already responded to the problem and have warned their customers to seek the support of hard drive vendors. In a letter to its customers, it said that they should also check the specs of other manufacturers' Via based motherboards."
Jan 11, 2010 | Computers & Internet
As I stated earlier I have ASUS K8S-MX Motherboard, but when I connect IDE 80GB drive with 500GB SATA drive it does not detect my 4 SATA partitions, instead says it is only 500GB unformatted single...
Check your AHCI (or ACHI, can't remember) settings in your BIOS. Turn them off, use "standard pata mode" even though you're using a SATA drive, and try again.
Dec 18, 2009 | ASUS K8S-MX Motherboard
Msi k8mm-v board not detecting SATA 320 GB HDD
peets, is this drive a slave drive? if so, make sure you have the jumper ******** the hdd set for "slave" , the instructions that came with it and on top of the hdd itself shows you where that is. You should have it set up for this anyways so you can format it to your liking(i.e. if your going to partition it out or use the whole 320GB for your data). after doing this you will need to go to you bios screen when you boot up your computer(setup). Go to standard or advanced bios settings and see if the new hdd is there, your bios should recognize it, if not, make sure you write down all the info for your hdd (size, cylinders, heads, type) and input the info for a correct installation and when you are finished, make sure you save the info (F10) and (Y) computer will restart and it should see the new hdd. Also, I take it you have CD/DVD driveconnected to your primary SATA or IDE port, this should not be a problem, if so send a msg back.
Dec 14, 2009 | MSI K8MM-V Motherboard
Can't connect SATA Hard Drive to MSI PT8 Neo-V Mother Board
You tell where in the System or in the BIOS. In BIOS on the SATA Mode or RAID Mode while in the System you install RAID Software to recognize and detect any SATA or RAID Hardware.
Sep 29, 2009 | MSI PT8 Neo-V Motherboard
Switching from 40GB IDE HDD to 500GB SATA HDD. SATA won't boot.
Hi there
No there is no need to change any jumpers on a sata drive, go into the bios settings and tell the bios to boot from the western digital drive only.
Good luck and thanks for using Fixya!!!!
Feb 09, 2009 | VIA MSI: MSI PT8 NEO-LSR P4 PT800 DDR400...
Detecting hard drives
try bios settings it may be set for a particular hard drive not yours and not on auto detect set for auto detect
Aug 02, 2008 | MSI K9A2 CF-F V2 AMD 790X AM2+ Phenom FX /...
Intel Motherboard Logo
375 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
