Question about Eclipse Audio Players & Recorders
Static on all fm radio stations on my new eclipse mp3 player
SOURCE: mp3 INSIGNIA sport Player
leave it and let it die...
recharge it and use!!!!
t happens to me all the time!!!!!
Posted on Jul 19, 2008
SOURCE: GES050 undercounter radio/cd player
..just read about your reception/interference problems and, having lived through similar situations for some time — particularly with different weather conditions. The following solution has settled it all : wrap power cable around storage brackets at back of radio with a short length then wound around support posts (between radio and cupboard from which radio hangs), then run short length to power supply outlet. In my case this result comes after much experimentation with the length of unwapped power cord (including fully unwrapped and stretched out) and different patterns of winding around the support posts. This final result takes care of everything (better sound, no interference/loss-of-reception when moving around in the room or in front of the radio, weather has no effect, stations received that could not be before due to overlap by nearby, more powerful ones). I have only about 2 1/2 feet of cable running from the brackets at back of radio, then wound once around center support and half around right support to then go to wall and down to receptacle close by (I tried all kinds of combinations of unwrapped lengths and winding patterns around 1 to 3 posts)...individual cases may be different. so GOOD LUCK, 'cause the radio is great...!
Posted on Aug 07, 2008
  • 905 Answers
SOURCE: FM Radio doesn't work
it may be that the fm detector has failed or possibly a tank(tunning coil)
Posted on Oct 06, 2008
SOURCE: Static on fm radio stations
Since my system can be mounted on the wall I found a spot on the wsll about 5 feet from the floor to mount it and now I can get the fm stations.
Posted on Dec 27, 2008
SOURCE: MY COBY MP3 610-2G PLAYER IS FROZEN
Try pressing the reset switch on the back....
Posted on Jan 28, 2009
When I try to find radio station all I get is static. How do I use radio function
You need to have an antenna to have your radio stations come in clear. If you just hear static, your antenna sounds like it's not there!
Feb 16, 2016 | Eclipse Audio Players & Recorders
I noticed static on fm station on my radio. the
i would get the alternator checked, sounds like its leaking ac current which can also kill the battery
May 04, 2010 | 2006 Subaru Forester
The radio component will not work. All I hear is static on any station.
make sure you are on fm not am, and make sure you are in a place with good reception. maybe try new earphones or while you have the radio on try moving the earphones and the player around.
May 18, 2009 | Creative Labs ZEN V Plus MP3 Player
The sales person said i could receive fm radio on this mp3 player
When it's booted up use the +/- buttons to navigate to radio, press play/pause to enter the radio tuner, it's default station is 88.something , use the |<< and the >>| buttons to navigate stations, hold the player around in the air to fin good reception, look around in the radio menu and you can record songs/talk shows off the radio, be careful, if you're recording and you hear static, it will record the static. good luck!
Mar 29, 2009 | RCA TH1602 MP3 Player
FM RADIO Reception
No, it should work, although it will depend on how good your reception is. This depends on how strong the signal is where you are trying to receive. If you have tried scanning for channels and all you receive is static, it's possible your tuner is bad. Have you tried to tune it to a known good station manusally?
Jan 20, 2009 | SanDisk Sansa e250 MP3 Player
SL100 static and bad FM reception
I have noticed various changes in my invehicle FM reception as well. There should be a external antenna that came with your car kit. This is precisely for these types of issues. It is designed to run along the windshield inside the car closest to the Cars radio antenna. It should plugin to the bottom of the cradle. Then tune it into a clean FM station (one that has no local station on it) and position the cradle and/or ext. antenna till you get the best reception in your vehicle. It could very well be that the antenna has come has loose on your car stereo backplane. You would probably notice decreased reception on regular AM/FM stations as well though.
Your wifi reception/functionality is a completely different animal and has no bearing on the FM transmitter in the car cradle. When your on wifi your not receiving signal from a sat. anymore just simply streaming internet audio like your computer.
Good luck.
Apr 08, 2008 | Sirius STILETTO 100 MP3 Player
No radio in menu. only music. voice .settings .
The service may not be available in your area. Make sure the headphones are connected to the player when searching for radio stations: Here's pg 15 of the user manual:
FM Radio (if applicable)
The Sansa
player includes an integrated FM radio for listening to live broadcast FM
stations. Please note that the FM Radio function may not be available in your region.
Listening to FM Radio
To listen to live broadcast FM station, follow these steps:
1. Select FM Radio from the Main Menu.
2. A radio frequency menu will appear.
3. Press |<< or >>| to adjust and search for the desired frequency, or select
preset by pressing Select.
4. For fast search, press and hold the |<< or >>| buttons.
Feb 20, 2008 | SanDisk Sansa Clip MP3 Player
71 people viewed this question
Top Eclipse Audio Players & Recorders Experts
Oloyede Monsuru
juanmireles1
Are you an Eclipse Audio Player and Recorder Expert? Answer questions, earn points and help others
