What kind of adapter do I need to connect a Samsung 23" LCD widescreen monitor to my Sony VAIO 17" laptop?
    President:
  • 3,085 Answers
Most likely you'll need a SVGA Male to Male Monitor Cable
Posted on Jul 21, 2009
My sony vaio vgn-nw320f was totally dead.i had pulled up the battery cause it could not log off.please help me.....
Most sony laptop power supplies have a power LED that indicates if the device is A) plugged in {ok it happens!}, or B) fried and not providing power to the laptop. Check this first. If the power supply is plugged in and the LED is on (usually green or red) then see if you have ANY lights on the laptop itself. Its possible that your LCD display went bad but that the laptop is otherwise running. You may see a power, hard drive or wireless network light on if the laptop works but the LCD went bad. You can also connect an external monitor to the laptop and power it up to check the LCD.
I've also seen where the battery goes bad and it keeps the laptop from booting. Try removing the battery and power up (with the ac adapter plugged in) again.
If neither of these helps, you may be looking at some kind of internal short on the motherboard which is big money. Hopefully that isn't the case.
Hope this helps!!
Jun 20, 2011 | Sony VAIO VGN-NW320F/B Notebook
I want to purchase the 28 inch TV - however when I reviewed the literature I couldn't figure out if our sound bar (Samsung model # HW-C451) would hook up to it - we only have a fiber optic connection...
Well before I can tell you if there is an adapter available, you need to tell me what kind sound outputs are available on your tv. Please provide this info so that I can tell you whether there is an adapter available.
Mar 27, 2011 | Hannspree 28" Widescreen Flat-Panel LCD HD...
How do i connect sony vaio laptop to my lg lcd 32ld310
Laptops have a VGA port (usually on the side). Once connected to an external monitor, you have to select that monitor by a combination of the Fn key and a special function key at the top of the keyboard that usually has a picture of a monitor on it.
Your LG monitor should have a VGA port on it. If it has only a white digital port, you'll need an adapter that goes from VGA to the existing port.
Sep 18, 2010 | Computers & Internet
My samsung(syncmaster 500s) monitor shows poor colours when connected to vaio laptop(XP home, nvidia geforce6200). how can i fix? could it be drivers?
yes it is drivers problem the drivers of laptop are not matching with monitor but you also try another on that laptop if persist then vga connector of the monitor is faulty
Mar 07, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
Dual Screens with a VGA connection
The easiest way would be to purchase a video card that has 2 vga ports on it, allowing dual monitor support. Here is an example.
http://www.amazon.com/Matrox-G450-16MB-Dual-Video/dp/B00194CT5A
Dec 29, 2009 | Samsung 2333SW 23" Widescreen DVI LCD...
I woul like to have a bigger monitor? where to buy and how much?
I just purchased the Acer X233h widescreen monitor. I picked it up at Staples for 139. They had a sale on it. Not sure what normal price is. Anyway I couldn't be happier with the monitor. 40,000:1 contrast ratio and can run in full HD, 1920x1080. I will be using a Xbox 360 with the hdmi to dvi conversion to take full advantage of the HD. Regardless of not being in HD. The monitor is great for a lot of computing needs. Also I went from the Samsung Syncmaster 740N. Which is a 17" monitor. Going from that size to a 23" widescreen is a huge difference and watching movies is a better experience. Check it out for sure. Hope this helps!!
Dec 19, 2009 | Hanns.G Corporation HW173D Monitor
Black line on my laptop screen
check your video settings they might have changed
Sep 05, 2009 | Samsung 2333SW 23" Widescreen DVI LCD...
Using my Samsung LCD TV as monitor for my Sony Vaio Laptop
yes sir..i think you must looking and buy VGA adapter 15 to HDMI complete with the HDMI cable set. you can find this adapter at the computer spare part store or electronic part store. not cheap but very usefull for you in the next day.
is very easy to connecting...plug you adapter to the output VGA VAIO.. connect the HDMI cable to adapter (like USB) and the rest to the input at your samsung lcd...good luck..
Jan 31, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Screen is white
You could have a video controller problem or a LCD screen problem, what you are seeing is the backlighting but no video information.
To check if you have a video problem, connect an external monitor to your laptop and bootup your laptop, if you see Windows booting up the external monitor then the video controller is OK, and your problem is the LCD screen or the video cable connection on the motherboard (may need reseating).
If you cannot fix the LCD screen then use your laptop with an external monitor.
Jan 28, 2009 | Sony VAIO PCG-Z1WAMP2 PC Notebook
I have a sony vaio lab top and a vga in to rca cable and a magnavow 32inch hdtv moldel 37mf33id and i can't get it to work togethere.help please?
Assuming that the VGA to RCA cable/adapter is functioning correctly, then what might be required are:
  • initially lower the screen resolution of the Sony Vaio laptop to the lowest possible;
  • press F? key to cycle on the display choices, LCD, LCD+TV and TV only. The F? key would be the one with the small monitor icon.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 11, 2008 | Televison & Video
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
