Logic combi 30, heating working but no hot water.
SOURCE: no hot water help
have a ariston euro combi boiler ,the problem to get hot water i have to turn the heating on to get hot water. but now it only run for a few min then run cold please help
Posted on Feb 28, 2008
  • 44 Answers
SOURCE: heating, but no hot water on a vaillant turbomax 28 combi
the problem is the diverter valve unit, source a corgi engineer to fit new one, cost for valve approx 80 quid +fitting
Kindly
Richie
Posted on Dec 16, 2008
SOURCE: Vaillant boiler - heating OK, but no hot water.
Most likey problem is the diverter valve, not energising fully. This in turn will not move the little plastic lever arm that actuates the microswitch on the side, sending the signal to ignite.
You can buy a diaghram kit from most local plumb centres, you need to replace the diaghram and seals, don't forget the silicon grease to ensure the plunger doesnt stick. Kits less than a tenner.
You should have noticed before it stopped working completely the water had reduced in temperature before the weeks it failed.
To make sure it is a diverter valve fault, depress the microswitch if you can, when the hot water is flowing and hey presto the demand for hot water light should shine.
Posted on Apr 26, 2009
SOURCE: Worcester combi boiler losing pressure & water through o/flow
having the same problem and its a new bolier. thanks , adriano.
Posted on Jul 12, 2009
  • 16 Answers
SOURCE: Baxi/Potterton wall hung fan assisted combi boiler
does the boiler come on when the hot water tap is run if not change the hot water flow switch or the diaphram in the hot water flow valve it may be split
Posted on Aug 17, 2009
Ideal Logic + Combi C30 not firing up.
Isconnect from the hive ,it has been known the hive thrmostat fails on ideal boilers.
Mar 22, 2017 | Water Water Heaters
My ideal logic combi 30+ is saying ignition lockout and my radiatiors arent heating up as well as my water not turning hot. How can i fix this please?
Lockout is a safety feature. Usually a latching condition and needs to be investigated rather than blindly reset. (The Combi has a bit more intelligence.) With the ignition locked out, you can't hi-fire the boiler, so no hot water of either type. The 'L' should also show a code number - check your user manual (google) for more guidance.
I've had a lockout on a non-combi: it was caused by lack of circulation of central heating water through the boiler.... The system boiled and the trip tripped. The pump WAS running, but wear in a valve actuator resulted in the valve feedback saying valve open while it was physically shut.
Dec 31, 2016 | Water Water Heaters
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
Is there a manual for the Ideal Logic combi 30
Hi.
Please click on the link below to download the manual for your combo. The manual is in PDF format and covers different models:
Logic Combi Manual - Ideal Heating
Regards.
Ginko
Sep 14, 2011 | Heating & Cooling
Manual for MAINE COMBI 30 ECO BOILER
Hi and welcome to FixYa. I am Kelly. I think this is your manual but if not let me know and I will do my best to find it for you:
http://www.burgeandgunson.co.uk/heating/Main_images/5119467_-_Main_Combi_Eco_Users_issue_01.pdf
Natural Gas
Main Combi 25 Eco
G.C.No 47 467 01
Main Combi 30 Eco
G.C.No 47 467 03
Thanks for choosing FixYa,
Kelly
Oct 21, 2010 | Heating & Cooling
No hot water...can any1 help i have a baxi combi 80e
check daiphragm, or micro switch best of luck
Oct 12, 2009 | Water Heaters
No hot water from combi boiler
i have a combie bolier when i turn the hot water taps on only cold water comes out central heating working fine can any one give some advise ?and can i fix it myself.
Jan 03, 2009 | Combi Centre DX - Mango
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
