Question about ZTE Cell Phones
Zte blade l 3 volume very soft - ZTE Cell Phones
I had that problem but finally realised that I had the screen protector film over the speaker slot.
Posted on Dec 26, 2016
  • willie j bay
    willie j bay Dec 27, 2016
    thanks does not help cant set higher volume
I have an ZTE blade Xmax phone when i turn the power on its only goes to the welcome screen thats it . i can't get to settings how can i fix that
your battery should not work properly as it could be too low. so, change your battery.
And never let it to be discharge below 0%.
OR if you are facing different problem then,
Hard reset your phone by pressing Power bottom and volume up Key.
Jun 27, 2017 | ZTE Cell Phones
Second hand zte blade v7 lite and i cant get past the google account verification. I have tried resetting to factory settings but it keeps saying that i need to enter the last owners google account
You need to reset the phone, you are trying to recover someone else's phone.
You can reset your ZTE device's password after power on: input *983*987# in emergency dial-up pad. Select Erase everything. It will restore factory settings and your personal data will be erased.
You can access to emergency dial up even the phone screen lock is on.
Another way to reset your password or gesture lock on your ZTE Blade V7 Lite is
ZTE Blade V7 Lite Andorid recovery menu
Turn off your device. (Sometimes you have to remove the battery and reinsert it before this procedure, if the device has a removable battery.)
Press Volume UP + POWER ON the device.
Keep pressing both key until the Android recovery menu appear.
Now select from the following options.
Highlight wipe data/factory reset with Volume key (power to confirm).
Now highlight Yes -- delete all data and press power to confirm.
After done select reboot system now.
All data will be deleted!
Jun 22, 2017 | Google Computers & Internet
Telsra network unlock code for ZTE Blade L5
Just to the page https://www.unlockninja.com/unlock-zte+blade-l5
make the necessary selection and get the unlock code for ZTE blade L5
Aug 18, 2016 | ZTE Cell Phones
Need motorola ZTE locked up don't know why need help ASAP please help
Do a soft reset as described.
A HARD reset removes EVERTHING and put the phone back to new. All Data GONE.
  • ZTE Warp - Soft reset ' Phone Tips and Tricks www.phonetipsandtricks.com/tips/zte-warp/soft-reset-76 ZTE Warp - Soft reset - To soft reset your phone press and hold the Power and Down button together for 10 seconds and the phone should restart. Wait about 10 seconds ...
  • DROID - Master Reset / Factory Data Reset - Motorola Support https://motorola-global-portal.custhelp.com/app/answers/detail/a... Factory Data Reset is a tool used to remove everything that was imported, added or installed on the device. WARNING: When using this feature; everything is deleted.
  • Reset Cell Phone ::: How to reset ZTE resetcellphone.com/solution/ZTE How to hard master reset ZTE series cell phone One stop site for cellphone ( mobile ) hard master reset instruction to factory default for all makes - alcatel apple ...
  • Jan 02, 2016 | Motorola Cell Phones
    Hard reset zte n817
    1: Power off phone
    2: Hold volume DOWN (not up) and POWER BUTTON simultaneously until ZTE logo appears
    3: With volume keys scroll down to wipe data/Factory reset press POWER button to accept
    4: Scroll down to YES press POWER button to accept
    5: Press POWER button on Reboot Phone and phone should restart like right out of the box
    Many forums say volume up and power button but that is only for FTM mode on ZTE N817. So remember VOLUME DOWN AND POWER takes you to screen where u can choose to reset etc.
    Dec 06, 2015 | ZTE Cell Phones
    How can I unlock network code on my ZTE blade L2.
    Hello. You can unlock your ZTE Blade II safer and easier using unique unlock code. You can get the unique unlock code for a ZTE Blade II from MobileUnlockSolutions.com at an affordable cost. Good luck.
    Dec 14, 2014 | ZTE Unlocked San Francisco 2 Blade 2...
    My zte n9500 flash screen won't turn on
    PRESS AND HOLD VOLUME DOWN ARROW AN POWER BUTTON BOTH REAL TIME AND HOLD FOR 20 SEC PROP PUSH BOTH THEN BLUE SCREEN CAME POP UP AND SOFT RESET
    Sep 29, 2013 | EMAX Rubberized Hard Shell Case w/ Holster...
    I need to unlock my zte blade
    How To Unlock ZTE Through An Unlock Code
    1. Insert SIM card from a source different than your original Service Provider (i.e. if you have a Rogersphone, use a non-Rogers SIM card)
    2. Phone will ask you to enter SIM unlock PIN
    3. Enter unlock code
    4. Your ZTE phone will be unlocked!
    That's how easy it is!
    There also other ways to unlock your ZTE device by using a mobile device unlock app (for MetroPCS and TMobile USA subscribers). Learn more about this app here : Everything You Need To Know About How To Unlock a ZTE Device
    Apr 20, 2013 | ZTE Blade Android 2.2.2 Os Pocket Router...
    How to unlock my netphone 701
    smart netphone 701
    problem:
    smart lock
    tools:
    1. 1 gb mmc (sdcard)
    2. z4root for ZTE BLADE
    3. Recovery Manager v0.37b
    4. Recovery Clockwork 4.0.1.5
    5. Official Cyanogenmod 7.0.3 stable
    6. Google Apps
    procedure:
    1. transfer all files to root of your SDCARD
    2. install z4root and root your device (temporary or permanent)
    3. install recovery manager
    4. run recovery manager then click install recovery then select recovery clockwork 4.0.1.5 blade gen2.img
    5. reboot and enter recovery mode (pressing volume down on green android)
    6. backup you rom from recovery (backup and restore > backup)
    7. wipe data/factory reset
    8. install zip from sdcard (choose update-cm-7.0.3-Blade-signed.zip)
    9. install google apps (choose gapps-gb-20110613-signed.zip)
    10. reboot
    Oct 03, 2012 | ASUS Eee 701 Netbook
    Cell Phones Logo
    29 people viewed this question
    Top ZTE Cell Phones Experts
    Audrey Messer
    Audrey Messer
    john smith
    Nyte_Ryder
    Are you a ZTE Cell Phone Expert? Answer questions, earn points and help others
