Question about Vacuums
How to remove cord rewind button on a kenmore mod 116 22612201 cannister vac cleaner This not a camera
  • 7 Answers
SOURCE: pwr cord rewind reel
You have to pop the grey button off for the cord rewind. There is one more screw under there. You have to be very careful, because you can break one of the tabs that hold the button on. In fact, it is almost a garuntee. There are three tabs that stick off the button that hold it in place on the orange hood. There's a long tab about 3/4 inch long on the inside corner of the button you need to be careful of. Good luck!
Posted on Jan 09, 2008
SOURCE: kenmore progressive canister Sweeper
I figured it out ..by pushing the lever down and pry a screw driver into three different spots on the top, to release the rewind bar. Looks like three little j hooks hold it down. It took a flashlight and night time for me to see it.
Posted on Mar 20, 2008
  • 298 Answers
SOURCE: Bosch cannister vac: Cord is stuck--won't rewind
It probably is, these cords are usually 15-25' long ;-)
What you can asssume is that the cord is simply twisted upon itself and doubled up so cannot easily come out, and will not go in... therefore.
Pull gently on the cord and twist in a clockwise direction. Does the cord seem to get a bit longer? If not, or if it gets tighter, try counterclockwise. If you keep trying eventually it will loosen and you can fully extend the cord. Compare this to holding a piece of string between your hands by the thumb and index fingers. Hold one end still and twist the other 20 times (twisting the string). then relax the string between your hands. See how it immediately forms a loop? That is the problem with your cordreel too. There is a loop in there that we need to undo. Now pull a bit so you can still see the loop, and then start untwisting to see what happens. You can also do this with a YoYo ;-)
Be patient, observe, sensitize your tactile senses and see if you can figure out which direction loosens your cord - and get it out ;-)
Good Luck
Hopefully you wont have to take it all apart. that cordreel spring is very strong. Be careful if you do go in there.
Posted on Mar 26, 2009
SOURCE: Automatic Cord Rewinder is not rewinding anymore
I had the same problem - the power cord for my Hoover Elite Upright (U5507900) was stuck a few inches out and wouldn't go any further. But when I unscrewed the rewinding mechanism, the cord had clearly gotten twisted and partly buried under itself so after some work I was able to free it. Now it seems to be working fine, at least for the moment. Note that I had to use small screwdrivers to unscrew the cord rewinding compartment, like the kind of screwdrivers you use for computer repair.
HTH!
Posted on Jun 22, 2009
  • 430 Answers
SOURCE: how do you take the canopy cover off of a kenmore cannister vac?
Flip the vac upside down and look for two screws from the underside near the wheels. If they are not visible you will need to remove hidden screws from above by prying gently at the back of the vac where the body panels meet at the bumper. Also look for two vertical screws in the bag area.
Posted on Sep 06, 2009
My Eureka Rally 2 Cannister Vac randomly stopped working
I am going to tell you this it is trash the motor went out buy a new one
Mar 26, 2014 | Eureka Rally 2 Canister Vacuum with...
Cord rewind not working'
spring is sprung. Take it to a vac store for a new rewinder
May 01, 2010 | Kenmore 23313 Whispertone Bagged Canister...
I have an epic 6500SR I'm trying to change the
You really don't want to get into the vacuum. You could cause more damage than what you have now. After you do get into the vac, the cordwinder is another monster to get into.
There are two strips,one on each side of the cleaner under the rubber bumpers. The strips have to be removed by pulling off the bumper and pull them out the front of the vac.This is not easy. After you get the locking strips out, turn the vac over and pull the bottom off. Then you can see the cordwinder.
The best thing to do is take the vac to a Aerus/Electrolux shop for repair.
Nov 02, 2009 | Electrolux Lux 5500 Canister Vacuum
Replacing power cord. How does cannister come
I found the hidden screws under the cord rewind and power buttons.
Oct 09, 2009 | Riccar Vacuums
How to replace the auto rewind button on Hoover canister vacuum.
116-...... usually indicates a Sears/ Kenmore model vac Please clarify
Sep 17, 2009 | Hoover Vacuums
Also have a Kenmore Model 116. Power retractor not holding cord
The cord winder on these is spring loaded and has cog which is meant to lock with every full rotation of the spool the cord winds onto. It is tricky to work on.
Try pulling a bit more slowly and see if the rewind will stop.
The back housing on top of the vac needs to be removed to access the rewind. The housing snaps into place at the back corners, generally must be carefully pried and popped off by someone familiar with the vac. Some models may also have 2 screws under the lid in the bag area.
Sep 10, 2009 | Kenmore Canister Vacuum Vacuum
How do you take the canopy cover off of a kenmore cannister vac?
Sep 02, 2009 | Kenmore Vacuums
Power to power carpet head
it sounds like the spring on the cord reel let go. difficult to reinstall. it may have been broken already and that is why it came off. it is rather meticulous trying to work on a cord reel. many can't be disassembled without breaking
Aug 09, 2008 | Miele S548 Bagged Canister Vacuum
Pwr cord rewind reel
Jan 08, 2008 | Hoover S1361 Bagged Canister Vacuum
Vacuums Logo
35 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
