Cd not working but dvd does work - Computers & Internet
  • kakima Dec 26, 2016
    Hi roy kets, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model?
  • Brett Duxbury
    Brett Duxbury Dec 27, 2016
    what were you trying to put on the CD ?
    Data or Audio and what software were you using to write to CD ? Did you get any error message ?
How DO i Fix DVD Writer Works As CD ROM Only. Not Detecting any DVD.
There are 2 assemblies inside it.
One works to read/write CD media.
One works to read/write DVD media.
So, your device is "half-broken".
Replace it.
Apr 02, 2015 | Computers & Internet
Cd dvd drive not working
>> try to check with other cd's or dvd's
>> if not working go to device manager and reinstall dvd drivers
>> still if you persist with problem n you know about hardware try to replace with other dvdrom
>> last but the best let allow to visit hardware technician..
Dec 17, 2012 | HEWLETT-PACKARD 620 XT964UT Notebook PC
It works with CD-ROMs but when i put in a prerecorded DVD, it says "insert disk"
HI,INOUYE56,
THE CD RW/DVD ROM DOES NOT WORK BECAUSE ,IT MAY BE THE OPTICAL LANCE OF DVD ROM HAS BEEN DEFFECTED.FIRST YOU SHOULD PUT ANOTHER DVD DISK HICH ONE WORKS WELL IN ANOTHER PC.WHEN IT ALSO DOES NOT WORK PLEASE CLEANE THE DVD LANCE.IF IT WORK SAME AS BEFORE,YOU MUST CHANGE BECAUSE NEW VERSON DVD CD CAN NOT WORK IN OLD DVD ROM.IT IS THE SOFTWARE PROBLEM.
Nov 21, 2010 | Teac DV 28E Internal DVD Drive
I CANNOT GET MY CD TO READ AND BURN A CD.....DVD
Try using a good quality dvd cleaner. The cd lens could be dirty causing cd funstions not to work. There is a different lens for the dvd so it's highly possible that one function will work but not the other if dirty. If this does not work you may have a lens that has become disoriented. If this is the case then with todays priced, decent dvd/cd burner for under $40 it would be cheaper to replace the drive than attempt to repair. Good luck & I hope this helps.
Jul 19, 2009 | Lite On (SHW-1635S) DVD RW Dual Layer...
Working only with CD, but can not start any DVD
open your device manager , off a right click from ,,, my computer . click properties , hardware tab , then un-install both the cd and dvd . re-start your system and let windows detect the new hardware and re-install it for you . Let me know if this works .... if not we can troubleshoot further.
good luck
May 24, 2009 | BenQ CB523C CD-RW/DVD-ROM Combo Drive
DVD/CD DRIVE NOT WORKING
Check the cables if they are connected properly and see if the cd/dvd rom is first detected in bios..
Jan 28, 2009 | Toshiba SD R2312 CD-RW/DVD-ROM (Combo)...
My DVD/CDRW only reads commercial dvds
My hl-dt-st cdrw/dvd gcc4244 ata device cannot write on DVD-rw imation cd why. How to resolve this problem
Dec 23, 2008 | Teac (DW224E/S) CD-RW/DVD-ROM (Combo)...
Cd/dvd dosen work pleace geimy a solution
i cant get you. cd/dvd is not working or cd/dvd rom drive is not working ? To work cd/dvd rom drive properly, Make sure the Jumper settings of the drive is set to slave or else remove all the jumpers from the cd/dvd rom drive, it automatically sets to slave. Check the power cable and the FRC(flat ribbon cable) of the cd/dvd rom drive. Hopefully it should work. Thank you.
Sep 11, 2008 | Computers & Internet
DVD drive cannot read DVD
may be dvd lence is not working,it want service
some time dvd works but cd not -same problem
regards prasanna
Mar 02, 2008 | Computers & Internet
Boot error, won't even boot with xp cd
hi.
you might wanna check if your XP is a dvd or cd. if it is a dvd your cd drive can not read dvd cd's. if it is a cd than your cd/dvd drive is not working. another thing you can do is to take out your cd/dvd drive and plug it back in. to see if it works. if the drive is working, you can try a different XP CD to see if it is working. if it is still doing the same thing. you might wanna check your hard drive to see if it works.
hope that helps.
thanks.
Dec 27, 2007 | Toshiba TE2100 Notebook
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
