Question about Garmin nuvi 1310 Car GPS Receiver
Garmin nuvi1310 power up wont pass first page garmin
This happend a few month ago after completeing download
Cannot unlock maps garmin nuvi1310
You can get details of how to unlock your maps at http://www.fixya.com/support/r6197735-no_detailed_maps_found_support_routing
There's more information there than you need so you can start at paragraph 2
May 18, 2011 | GPS
I WANT TO REGISTER MY NEW GARMIN NUVI1310 BUT BECAUSE I HAVE A REGISTERED NUVI250 i AM TOLD ON MY pc THAT MY EMAIL ADDRESS IS ALREADY REGISTERED AND WILL NOT ALLOW ME TO REGISTER MY NEW NUVI. CAN A PERSON...
What you need to do is log in to your Garmin account and add a new device under your mydashboard, you cannot create 2 Garmin acccounts with the same email.
Hope this helps!
Dec 10, 2010 | Garmin GPS
Hi, 1996 Chev SUburban 1500, never any problems till a few months ago. Drove thru U.S. and filled up with gas, after a few hours, engine light came on. Now, a few months passed, and truck having rough...
where did you go? if you went through really high altitudes the oxygen levels change and could have fouled your plugs. sometimes the auto makers tune the vehicles different in different geographical locations.
Sep 29, 2010 | 1996 Chevrolet Suburban
We bought the Garmin Nuvi 1300 a few months ago. We were travelling X-country when it would just shut down for no reason. When you turn it on it will turn off almost immediately. I bought another one in...
It sounds like the battery is the issue. Try leaving it plugged in over night. If that does not help, press and hold down the power button for 30 seconds. This will reset the device, and hopefully restore functionality. Consult the user guide for more info.
Aug 23, 2010 | Garmin nuvi 1300 Car GPS Receiver
Garmin Nuvi 1300 (and 1490T) won't start up
A Garmin Nuvi 1300 that won't start, freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
Jan 16, 2010 | Garmin nuvi 1300 Car GPS Receiver
Hi i have a sony vaio LT series all in one pc, the thing is my wirless has stopped working, it happend b4 abt 6 monthes ago but used system restore to put it back to the previous settings and it sorted it...
GO to your manfacture webpage, then go to drivers download, choose your laptop model, and your operating system, and download the wirless driver, then install it, and this will fix your problem.
thanks for using Fixya
Oct 05, 2009 | Computers & Internet
The june 25th
return it to the seller for replacement or repair it's under warranty
Jul 04, 2009 | Garmin nuvi 750 GPS Receiver
Garmin gps 296
If it does not show 'charging' when connected to power, then something may be wrong with the power cord. If it is the vehicle cord (the one with the cigarette lighter plug) check the fuse in the tip of the cord.
May 10, 2008 | Garmin GPSMAP 295 GPS Receiver
Garmin Forerunner 305 usb cable won't be read
The problem is probably not with the USB cable if the GPS wont even turn on. The older firmware of the Forerunner 205 and 305 have a problem with locking up. This causes the Forerunner to look completely dead. There is a reset procedure: push the mode and reset button at the same time and then let go and hit the power on button. If it powers on that is the problem. Go to the Garmin site and load the newest rev. of firmware into the Forerunner. Fixed mine and a few friends with the same problem.
I do however have a cable problem. Sometimes my PC will come up with unrecognized USB device and my 305 wont talk to the PC, it does charge. It is the cable or dock for sure, because I have tried a different cable/dock and the 305 has no problem. This is the reason I ended up here. I hope the lock fix works for those with the above problem.
Dec 16, 2007 | Garmin Forerunner 305 GPS Receiver
Garmin nuvi 1310 Car GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
