Mobile Aircon Not cooling the room down enough. On 17 deg. Please help
Rindi 082 651 1572
  • kakima Dec 26, 2016
    Hi rindi scheepers, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model?
    And by the way, giving a phone number does no good if you don't specify a country.
2 Suggested Answers
SOURCE: Split system getting cold at first then just not cooling the room
Split Air Conditioners are not meant to run constantly. so check this first . you may have a faulty component i.e. compressor, condenser, evaporator, or evap fan. Depending on your technician you may have gotten ripped off. You need to find out if he checked the system for refrigerant (gas) leaks. A good way to tell if your ac is leaking is feel the low and high side copper pipe in between the inside and outside units.
the smaller pipe (high side) should be hot be carefull maybe touch it with an ice cube. The Large pipe should be cold but not iced over.
if there is ice on any component you should call a qualified tech. you probably have a leak. you should also clean your air filters which are right above the vents. I am a certified AC mechanic and i have seen this problem. in Iraq because of ambient temperatures being high the systems take alot of abuse and we dont fix them because repair costs exceed replacement costs alot of the time. good luck.
Posted on Nov 19, 2009
Fraser Johnston Furnace - Not heating
Check the furnace filter to make sure its not dirty . Dity airvfilters can cause the furnace to overheat and shut off on a high temperature limit switch when the switchs cools down it resets but the furnace has to be shut off to reset the control board. Hope this helps.
Jan 23, 2014 | Heating & Cooling
Not cooling
outside freeze sensor locking out operation
Jan 04, 2014 | Dometic Rooftop RV Air Conditioner
I have recently installed 1Te Voltas 2 star A.C. I need clarification on the following 1) In cool mode, what is system of auto cut. Suppose I put on remove temp 27deg C. Temp of the room goes up to 26 deg...
Dear Mahesh
In Cool Mode
Temp Diff - + - 1 deg C in Room Temp & Set Temp
This is auto cut
In Dry Mode
Comp Runs for 10 mins then get off for 5 mins then again get on for 10 mins this cycle continuues.
Oct 15, 2013 | Whirlpool ACQ158XP Wall/Window Air...
Unit will not heat, change batteries controller cleaned filters etc. Still blowing COLD air
Check the thermostat setting...in the auto machines, with a reversing valve, there is no heating or cooling, generally, in the sensing temperature band of 19 Deg C to 22 Deg C and it only works on blower mode, re-circulating the room air. When the sensing temperature goes below 17 deg C, it works on heating and when the sensing temperature goes above 24 deg C, it works on cooling
Sep 05, 2011 | Heating & Cooling
When air comes on it goes to windshield then later to floor before coming out the front vents what would cause this?
There are 2 types of Air-conditioning fitted to vehicles:
1) Manual Air - this is where you turn your temp dial to either Cold (Blue) or Hot (Red) and the heater will continue produces the same temperature at all times, until you manually change the setting.
2) Auto/Climate Air-conditioning - this is the INTELLIGENT aircon system, with many sensors placed around the car's interior. This system allows you to select your desired temperature in degrees (e.g. 18 deg C). Once you have chosen your desired temperature, the system then measures the inside temp at each sensor location. The sensor readings are sent back to your aircon computer and this is where the magic happens:
The computer then directs a priority airflow to the areas of your vehicle which would enable the system to reach 18 degrees, in the shortest possible time (this is why airflow changes between various vent outlets). As the system approaches your desired temperature, you will notice the airflow will slow down just enough to maintain a comfortable 18 deg - this is why they call it CLIMATE aircon.
However, if you choose to override the vent direction (i.e. selecting face vents only), they system will take a couple of seconds to respond to your command.
Cheers,
"If this has helped you in any way, please rate this solution"
May 13, 2011 | Mercury Marquis Cars & Trucks
Hi i need to know what size window air con for a room 30sq meters cooling onjy and what model
Hello there.. :) your room 30 sq. meters needs 2 - 2hp window type aircon as computed. But you can consider the purpose of putting up the aircon and how many occupants will stay.. :0
For the model:
NATIONAL, 2HP, Model CW-1808VPH 2HP LG Window Type Aircon Manual 2HP Koppel Aircon w/ remote model: KWR-18R1
or check the internet for other models that you want.. :)
Feb 03, 2011 | Heating & Cooling
Nov 19, 2009 | Mitsubishi MSZ09UN Air Conditioner
MY AIRCON IS BUILDING UP SOME ICE
Sounds like it's low on charge, dirty coil. Is this a ductless unit or window?
Jul 26, 2009 | LG Heating & Cooling
My KOLIN window type remote control AIRCON is building up ICE
If you already had the coils and filter cleaned and the blower is OK, that only leaves the refrigerant charge.
You are probably low on refrigerant.
Jul 26, 2009 | Heating & Cooling
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
