Question about Lexmark X5495 Printer
Request a report Lexmark x5495 - Lexmark X5495 Printer
5 Suggested Answers
Roop1980
  • 228 Answers
SOURCE: lexmark x5495 all in one.paper does not come out when printing
It seems there is a possibility of a problem with the printer itself, or perhaps the cartridge. You should first self-test the printer. Since we are unsure where the problem exists, we must do eliminative troubleshooting to rule out parts of the printing system. The self-test allows us to rule out software and the cable by testing the hardware by itself. Please note that this is not a "fix," but rather a diagnostic test to determine if your hardware is at fault.
Please begin by disconnecting the power supply from the wall (not the back of the printer) for at least "30 seconds." Then plug the printer back in.
Next, try this printer self-test by following the steps given below:
1. Make sure the printer is in “Copy Mode.”
2. Press the “Menu” button once.
3. The screen will display “Copy Menu: Copies”.
4. Press the left arrow button once. The screen will display “Copy Menu: Tools”.
5. Press the check button once. The screen with read “Tools: Maintenance”.
6. Press the check button once. The screen with read “Maintenance: Ink Levels”.
7. Press the right arrow button until the screen reads “Maintenance: Print Test Page”.
8. Press the check button once. This will start the Self-Test. Once the page has printed, the printer will stop. The test is not continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues - we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Posted on May 16, 2009
ap-it
  • 54 Answers
SOURCE: Lexmark X5495 - useless
I've had a problem like this before too, it's was down to two things which might be the same for you!
1) Is your printer plugged into a Power Surge Protector? if so then remove it from that and plug it into a normal plug, the surge protector sometimes doesn't allow the correct amount of power to reach the printer which causes an issue.
2) Your paper feed rollers, I had to clean mine with white spirt to remove the paper dust from the rollers, once done feeds paper everytime since!
If this has helped you then please rate me!
Posted on Aug 23, 2009
pineworks
  • 4041 Answers
SOURCE: I have a lexmark x5495, what is the file that that
Hi there
Lexmark and Brother printers has made the pritners this way so it can not use refills.
You can not reset the inks that I know of on a Lexmark sorry.
All the best Pineworks
Posted on Mar 19, 2010
I have a Lexmark X5495 printer, and I refilled the black cartridge. Is there any way to override the ink levels?
Once a cartridge is refilled, it can no longer report it's true ink level. Just an FYI: you might not get the print quality you expect from ink that is specially formulated by Lexmark to pass through microscopic nozzles at extremely high temperatures.
May 17, 2011 | Lexmark X5495 Printer
How do I hook up the fax on a lexmark X5495
Perhaps the Lexmark X5495 Fax Guide will be able to help you. Just click on this link: http://www.lexmark.com/publications/pdfs/2007/5400-plus/v6841177_en.pdf.
Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
Jun 25, 2010 | Lexmark X5495 Printer
I recently moved and I lost my Lexmark Printers Plug that go's from the printer to the wall. It's the Lexmark x5495. I need to purchase another plug. Where can I get one????
It may be available in some electronic shops around your area. But I suggest you contact Lexmark Technical Support, for your convenience, to request for that. They can send you one for free. Just give them your contact info and the serial number of the printer. Hope this helps.
Jun 14, 2010 | Lexmark X5495 Printer
I have the telephone/computer line but can't find electrical ?
If you're missing the power cord for the Lexmark printer, I suggest you contact Lexmark Technical Support for assistance. You can request for that and they can send you one for free. Hope this helps.
Jun 02, 2010 | Lexmark X5495 All-in-One &USB...
I have a lexmark x5495, what is the file that that moniters and reports ink levels? It is what stops me from being able to use my own refilled ink cartridges.
Hi there
Mar 19, 2010 | Lexmark X5495 All-in-One &USB...
I dont have the sofeware for my printer x5495 what other way can i install it?
go straight to the lexmark site itself, type into google software for x5495 Lexmark Printer, install
Oct 30, 2009 | Lexmark X5495 Printer
Lexmark x5495
Lexmark does not allow refilled cartridge on any of their products.
Lexmark, HP and Canon and-many other vendors use proprietary code to protect themselves against the damage of OEM inks.
All companies will void warranties.
Apr 24, 2009 | Lexmark X5495 All-in-One &USB...
HOW TO REFILL LEXMARK X5495 PRINTER
When you try refilling your ink cartridges, you are taking chances that something may go wrong. I would search the web and purchase re-manufactured ink cartridges, which would be less expensive than the new ones from Lexmark.
http://www.ink-refills-ink.com/printer/Lexmark+X5495+Ink/15981/?src=gpsearch&gpprod=Lexmark+X5495&gptype=bulk
http://www.internet-ink.co.uk/lexmark-ink-cartridges-X5495/
Please remember to rate all users who assist you for free :)
Sep 20, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X5495 Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
