Question about Drills
Registering my rigid power tool - Drills
Ridgid 18v x3 saws
The battery may have a short in it. Take it back to Home Depot for a new one. Rigid has a lifetime warranty on their cordless products.
Aug 25, 2014 | Ridgid 18v Circular Saw X3 tool Only R865n...
18 v. ridigid cordless works tools for a feww sec. then stops batt is charged same in all tools
bad battery. cells won't hold a charge. that's what it sounds like to me. for a rebuild or buy a new one from home depot.
Jun 23, 2014 | Ridgid 18v Drill R86007 Rigid
What brand attachments work with ryobi rotary tool?
Rigid accessories fit the rotary oscillating tool.
Aug 18, 2017 | Drills
Where is the blade brake on the miter saw
The brake on electric motor driven tools is the field & armature. When running the switch provides power to both sides/poles of the field through the brushes and armature. When you release the switch half of the field is powered pulling the armature to a stop. If your bladed continues to spin when the switch is released, you need to replace the switch. The Ridgid part number for the proper switch is 503317000.
Mar 06, 2012 | Ridgid Reconditioned 12 In. Compound Miter...
Charged the battery and shortly after it keeps shutting its self off?
It's a lithium battery.I can tell .Have same problem sometimes. Either need to clean the contacts on the battery and drill (use Paslode tool cleaner,aereole spray) or get a new battery. Most of my battery powered tools are Ridgid, I like them and they usually hold up , but like any other brand they can be unreliable. I buy an average of 5 new batteries a year. Some last about 6 weeks , others 3 years.
Jun 05, 2011 | Ridgid 18v Drill R86007 Rigid
I have two different cordless 21.6 volt drills that have died within a week of one another. The first went from doing fine with a hole-saw blade to completely dead, and the second, i think the bearings...
Take back and get rigid tools from home depot,gauranteed for life,if you have money buy hilti tools,offerd by home depot,been using hilti tools forever,there the best but spendieee
Jan 26, 2011 | RTO 21.6v Kawasaki 4 Piece Cordless Power...
I just got a set of power tools and the bateries just blink red when i put them on the charger? does this meen they are toast?
if u got a soilder gun u can pull battires apart and there is a burned spot patch it back and they will work i fix all of mine but if one of the tool has a short it will just burn them again
Jul 08, 2009 | Ridgid 18v Impact Driver Rigid R842301
Drills Logo
64 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
