Irulu 20 pro projector.Im only able to get Bluetooth through the android source?hooked my direct TV up to projector via HDMI, I'm only getting sound out of projector and not the Bluetooth speaker
CremeStout
  • 115 Answers
SOURCE: Analog RCA input to HDMI output?
You have said the correct thing HDMI is digital therefore Analog will not pass.
You might have RCA audio outputs on your cable box so either send them into the TV from cable or into the AMP then use AMP volume to listen to TV audio (select unused input and remember it is for TV) the key is to remember that cable box will drive the initial vol so raise or lower cable vol then use AMP vol to obtain desired volume.
Posted on Dec 03, 2007
  • 3 Answers
SOURCE: Xbox connectivity problem
As dumb as this sounds here is the mistake Sony made. The receiver does not process sound from the HDMI, it will only pass through that data to you TV. So you will not be able to get sound from your 5.1 speaker setup if you only connect the HDMI, you have to use the matching audio input for that respective HDMI input. Make sense? So the HDMI DVD Input must have digital coax for sound, HDMI Video2 must have fiber optic for sound, and there is another fiber optic port for the Sat input. Yes thats right, if you have 2 HDMI HD components and each only has fiber optic(neither one has digital coax) you cant hook both up properly the way you would think. Sony made this receiver poorly, turning High Definition Multimedia Interface into High Definition Multimedia Except For Audio Interface.
Posted on Jan 27, 2008
  • 4 Answers
SOURCE: Onkyo TX-SR875
My mistake, HDMI in is not routed to any other output but HDMI out
Posted on Oct 05, 2008
  • 4 Answers
SOURCE: Onkyo TX-SR705 - No Audio - Flashing HDMI
The posabilities is power amplifier on your reciever is bad,
replays reciever or repair it.More likely this is IC amplifier located on the main board of the reciever
Posted on Apr 17, 2009
gymhasafit
  • 31 Answers
SOURCE: no video
I am not sure if you have gone into the Receivers Menu or not? If you have NOT! Then please try this: Go into the Receivers Menu (If you do not see the MENU on the TV you can hook up a Composite (Yellow) Cable from the Receivers Monitor Out (Yellow) and select the Input on the TV that you plug into) Look in the Menu for Inputs or In/Out Config. or Video Setup. Look for the Input that you are using for that Device. Change the Video setting to HDMI. I also recommend doing this for you Audio as well. Find the Audio Inputs and MATCH each Input to there DEVICE and CABLE (Connection) Being used. Also check in the Receiver Menu for UPSCALE or UPSCALER. Turn this on or off to see if your TV is Compatible! Hope This Helps! P.S. Check the Manual for Upscaling Capabilities NOT all Receivers upscale and route the SAME!
Posted on May 04, 2009
Iam trying to use HDMI to dvi cable to hook up my Android TV box to my JVC 56 inch I art por modle number av56p30 but o get no picture nothing can anyone help with this thank u for you time
You have to enter the menu setu on the tv to select input source usually hdmi 1 2 or 3 you also need to select output on some devices .Make sure you have the correct HDMI cable...they usually have 1.1 or other codes stamped on cable and you may need to google which HDMI code you need.Android have their own version of AirPlay via Bluetooth.
May 07, 2016 | JVC Televison & Video
Does my irulu v3 mobile phone gave mhl connection capabilities, and if so how do I connect it to my TV via HDMI.
Unfortunately, the irulu V3 does not support MHL.
I wish that I had better news for you. Since the irulu Victory 3 (V3) documentation doesn't mention Miracast, I'm not sure you could even mirror the V3 with a Chromecast, Smart TV or set-top box that can stream data from another device. The Miracast feature was added to Android 4.2 but may not be enabled for the V3. The English language edition of the irulu V3 manual is available from the irulu support site. It's a PDF inside a compressed .zip file. The direct link is currently http://img.irulu.com/driver/English_User_Manual_for_iRULU_V3.zip .
Feb 02, 2016 | Televison & Video
Is my irulu x7 tab mhl enabled
Irulu Tablet - Android Forums at AndroidCentral.com
forums.androidcentral.com/other-tablets/236406-irulu-tablet.html
Dec 18, 2012 - 25 posts - ‎22 authors
The specs are below. ... I just got my irulu 4.2 Jellybean tablet and this is my first time dealing with anything other than desktop and non smart phone. ..... There is a hidden phone on the irulu X7 called dragonphone and I have ...
MHL Supported Products - Accell
www.accellcables.com/pages/mhl-supported-products
Now mirror your smartphone or tablet featuring MHL technology on a display or projector. Please ensure your device is MHL enabled by visiting the link below. •
Feature News Stories: How Do I Connect My Tablet to My ...
hometheaterreview.com/how-do-i-connect-my-tablet-to-my-tv-let-me-co...
Oct 14, 2013 - That means you must connect your MHL smartphone or tablet ... flash drive and plugs directly into an MHL-compatible HDMI port on your TV or ...
Amazon.com : IRULU X1a 7" Tablet - A33 Cortex-A7 1.5 ...
www.amazon.com/IRULU...Tablet.../B00M3OTG3S
Amazon.com, Inc.
Rating: 3.2 - ‎97 reviews
Jan 21, 2016 | Tablets & eReaders
Irulu Expro tablet. Where is the Bluetooth setting?
iRULU eXpro X1Plus 10.1 inch quad core tablet Android 5.1 ...
https://www.irulu.com/tablet/p-irulu-expro-x1plus-10.1-inch-quad-core-t...
iRULU eXpro X1Plus 10.1 inch quad core tablet Android 5.1 Lollipop support Wifi OTG ... Bluetooth: 4.0 ... iRulu Google Android Capacitive Tablet PC(1) ... 1 Comments 0 or 0 people found the following review helpful .... Connect With Us.
iRULU eXpro X2Plus series android 4.4 high-speed Octa Core
https://www.irulu.com/tablet/p-irulu-expro-x2plus-series-android-4.4-hig...
iRULU eXpro X2Plus series android 4.4 high-speed Octa Core Tablet 16GB ROM 10 points Capacitive IPS touch screen Bluetooth 4.2. $89.99 $179.99.
Dec 26, 2015 | Tablets & eReaders
Cant get ps4 to pass signal thru avr to projector.
Possible PS4 HDMI Handshake Output Problem - AVS Forum ' Home ...
www.avsforum.com/.../1508885-possible-ps4-hdmi-handshake-output-p...
Dec 31, 2013 - 20 posts - ‎15 authors
Nothing seems to make the PS4 pass a signal through the AVR. .... can output videothrough the Integra, why can't Sony get the HDMI working? PS4 - 3D Playback Not Working :-(
Aug 12, 2014
Run HDMI Directly to TV or A/V Receiver?
Dec 19, 2013
AV receiver problem with Xbox One
Nov 23, 2013
Solution to HDMI @ 1080p receiver/display HDCP ...
Dec 14, 2008
More results from www.avsforum.com
My Denon AVR-X4000 won't output video signal from attached HDMI ...
forum.blu-ray.com > Audio > Receivers
Dec 21, 2015 | Denon AVR-3311CI 7.2 Channel Networking...
Sound issues when connected to PS3 with HDMI
I don't think you can hook a PS3 to 350W projector. You are maxing out the PS3 output. Good luck with it
May 03, 2014 | Optoma PRO350W Projector
LG blue ray won't play sound from RCA sound bar. HDMI cable is hooked into HDMi slot on TV
the details you provided were very vague, however from my experience when a device is connected to another device via and audio capable hdmi cable, that device renders it audio output to the device its connected to and normally turn off all other audio outputs beside optical- I would assume there is an option in the blue ray player to turn off hdmi audio, which will in turn activate other audio outputs- you may also look for audio out port on your tv, it is ideal to connect the sound bar directly to the tv set audio out ports. To sum this up,
if you plan to use your player via hdmi cable you need to turn off hdmi audio output on the blue ray player and the plug an audio cable from your blue-ray player to your sound bar
you may also as i said connect your sound bar directly to your tv, the issue is most tv sets now a days do not have an audio out port, if you do then everything you play thru your tv will have audio via sound bar
there are several way to go here but unless your sound bar has hdmi av switching capabilities (im sure not) this is one of the most simple--Good Luck.
Jan 29, 2013 | Audio Players & Recorders
I need access to manual for the Image Pro 8758. We are getting no picture output from Projector. currently using the component to 15pin VGA wiring. Which is connected to the Computer 2 input terminial on...
Try pushing the source button either on the projector or the remote. It will tell the projector to look for another source. It may currently be set on one of the other sources. If you look up the manufacturer on-line, you should be able to download the manual.
Jan 13, 2011 | Dukane ImagePro 8755A Multimedia Projector
No signal being reached
I'll give you the short answer. Your receiver is either version 1.1,1.2,1.2a,or 1.2b. None of which ever function correctly. HDMI is riddled with issues. The current version is 1.3b and I havent seen any issues "Yet". Best way to solve the problem is to run sources directly to the unit and run audio via digital coaxial or optical to your receiver. If you want the long version of all the HDMI issues, you can google "HDMI forums" and there are lots! Hope this helps. If you still need some help, post a comment and I can help more.
Aug 23, 2009 | Audio Players & Recorders
 Grubhead
Grubhead
