Question about Uniden Radio Communications
I have a uniden GMR 4060-2CKHS they only work if we are the house together It says they will work for 40 miles. Is there anything I can check to make sure everything is being done?
Uniden GMR 4060-2CKHS TWO WAY RADIO
    Master:
  • Uniden Master
  • 520 Answers
No. They say up to 40 miles. Unfortunately, it is bunk. Those are a two watt radio. In perfect conditions with clear sky and one person on top of a mountain and the other clearly in the open, it is slightly possible to get 40 miles. But remember, the earth is round, not flat. Every 22.5 miles the earth "curves" making flat, straight communication impossible. What is the minimum distance you will accept and determine if that is enough before returning them. Even moving up to business band 5 watt handheld radios will never get a long range. I use mine as an wireless intercom. I never expect even two miles.This applies to any brand, so don't be fooled.
Posted on Dec 27, 2016
  • Gwen Russell
    Gwen Russell Dec 29, 2016
    Thank you for your reply. I guess we should have done more research before purchasing them. I will keep them and make use of them when out riding with someone else.
Uniden walkie talkie
What is the condition of the batteries? Try it with new ones and if you still have this issue, you need special equipment to test the output and sensitivity of the transcievers.
Mar 14, 2014 | Radio Communications
Static
have a tech check out the filters inside the radio and set it up so that they work with each other.
Nov 22, 2013 | Uniden GMR 2638-2CK Two Way Radio
I took out the rechargeable batteries (replaced with regular AAA)in my Uniden walkie talkies and now one is set for channel 19 and one for channel 6 so they cannot communicate. How do I set the channels...
Press the channel/scan up or down arrow key to change3 the channel on either radio. Need the operating instructions? You can download/print them here:
http://www.banoggle.com/Products/Uniden/manuals/GMR-325-2om.pdf
Bill B
Aug 06, 2010 | Uniden GMR-325/2 2-Way Radio Walkie Talkie...
Should the radios be on or off while charging?
Uniden suggests that the radios be switched OFF while charging. Leaving them ON won't hurt anything, but it will extend the charge time.
BillB
Jan 06, 2010 | Uniden GMR-325/2 2-Way Radio Walkie Talkie...
Is there any place online I can get the instructions? I have misplaced mine and don't remember much of anything!
Certainly -- here's a link to the operating instructions for your radios:
http://www.uniden.com/pdf/GMR1035-2om.pdf
Dec 10, 2009 | Uniden GMR-1035-2 2-Way Radio
Hello i have a Uniden GMR-325 (7 Channels) Two Way Radio that....
Hi Zachary
I predict that you have trouble with only one unit.
Try to find some one with either the same units ( on same Frequency of course) or a receiver that also covers same Frequency and transmit on one GMR then the other to esablish which unit is faulty!
The faulty unit should then become apparent, the buzzing could be caused by transmisson of the faulty unit, check all Antenna connections, even change antennas over on testing as prescribed above,
good luck John.
Apr 05, 2009 | Uniden GMR-325/2 2-Way Radio Walkie Talkie...
Uniden GMR-1035 2-way radion, with advertised 10 mile range
The range estimates are inflated by every manufacturer I am familiar with.
Even with line-of-sight transmission, I have found none that meet the claimed distance under common circumstances.
If you have a friend who is a radio amatuer, you might let him crack the case on one to see if there are any adjustments that could be improved; an 'old dog' would be able to locate the right area in which to look and perhaps tweak something to improve either transmitted power (he should have an instrument that would monitor it for adujstment if not for actual measurement) or improve receiver sensitivity.
The factory is only concerned with function and cost, not performance.
That the Motorola meets its stated range doesn't surprise me; they were long one of the most ethical companies around.
I'm not sure of their honesty today since profit (or even survival) has become more important.
Jul 05, 2008 | Uniden GMR-1035-2 2-Way Radio
Uniden gmr 10.38-2 manual
Hi, The manual for your Uniden GMR 10.38-2 is available at the Uniden site (Support/Manuals). The file name is GMR1038-2om.pdf. The link is or . Hope this is what you are looking for. Good luck and kind regards.
Sep 07, 2007 | Radio Communications
Radio Communications Logo
77 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
