Question about LG Washing Machines
My LG top load washing machine is 2 1/2 yrs old. Each was now has a brown/black flaky particle in the drum and clothes. What can be done to get rid of this in my cycles?
Bob Gemmell
  • 209 Answers
SOURCE: Black particles in clothes after using a top loading samsung fully automatic washing machine
You said these particles stick to the clothes, do they come off and then leave a stain? It may be grease or oil coming from a leaking drum bearing seal.
If it is, This is a major repair and not one for DIY.
Posted on Sep 28, 2007
  • 209 Answers
SOURCE: Brown spotting on washed clothes
chances are if you have eliminated anything thats got in by accident that the drum bearings are about to go, the drum bearings are protected by a water seal, this has started to leak and is now washing the grease out of the bearings back into the wash, you may also find a small amount of water on the floor, if you also remove the back and look behind the large pulley you may also see brown water marks running from the center of the outer drum
the next step will be a very noisy spin, like a rumbling noise
DRUM BEARINGS sorry
Posted on Oct 15, 2007
jumptrout51
  • 3361 Answers
SOURCE: Drum not spinning during some spin cycles
Replace the direct drive coupling.
Posted on Mar 23, 2009
  • 850 Answers
SOURCE: The drum is stuck - it will not move
overloaded & unballanced has mabe pulled drum away from the rear bearing!
& jammed iself!
only way now is to disconnect power & water & undo cabinet to inspect it!
Cheers rob.
Posted on Jul 28, 2009
Wolfman304
  • 720 Answers
SOURCE: I have a Samsung SW62ASP top load washing machine.
This is a common problem on washing machines, if you predominantly do cold washes.
Over a period of time, a washing machine will accumulate a buildup of Soap Scum (excess soap & softener residue) which can stick to the inside of the drum.
This black coloured soap scum occasionally breaks away from the drum, and attaches to the clothing fabric during the wash cycle.
You can rectify this, by doing the following:
Firstly, purchase a packet of CITRIC ACID from your local grocery store (usually found in the baking isle).
Do the following procedure before going to bed:
1) Do a HOT WASH without clothes (Hi water level, with HOT water) - allow machine to fill with hot water, then add the CITRIC ACID to the water. Allow the machine to complete a FULL wash cycle (i.e. allow machine to agitate for 30 mins or so, then drain).
2) Fill the machine again with the HOT water / CITRIC ACID solution, but this time allow it to sit in the bowl overnight (no cycle).
3) Next morning, set machine to spin & drain (i.e. to empty the solution)
4) Set machine to fill with FRESH HOT WATER ONLY (no citric acid), then set machine to spin & drain. This will flush all remaining residue left in the bowl.
Note: Soap scum residue is caused by using excess detergent/fabric softener. Hot Water flushing should be done every 6 months.
Contrary to what the detergent manufacturers state, you should follow Samsung's instructions by using HALF the recommended detergent.
Samsung machines prefer LOW SUDS, and you may find by reducing the amount of detergent used, you may even eliminate the buildup of soap scum.
"If this has helped resolve your issue, please rate this solution
Posted on Dec 03, 2009
Why do I have plastic particles sticking to clothes in my washer?
Is the machine noisey on a spin? if so probably the drum bearings have gone or the spider {or shaft }broken
Jan 30, 2016 | LG WM2140CW Washer
Bad smell in washing machine...clothes smell bad after wash
hi there is a build up of lime and old dirt in the inside of your drum the best thing to get rid of the smell is put a very small amount of bleach in the drum and put your machine on a very hot wash it will help in your hand book it will tell you to use your hot wash with a bit of powder and no cloths at leased once a month i dont know if you use your hottest wash most people dont these days because of the low temp powders, also the best product to use is lim away but you can only get it on usa bases or from the usa you might find someone on line that sells it that will get rid of all the lime thats been built up in your machine if you cant just use a bit of thick bleach hope this was helpful
Nov 18, 2011 | LG WM-2277HW Front Load Washer
Small brown particles are found in filter and also what appeaars to be small grease stains on clothing what could be the problem?
The brown stains are likely coming from the felt drum seal. The OEM adhesive is tar based - and after time and use - breaks down.
You'll need a new felt seal - and the adhesive that is used should be silicone based... eliminating the brown streaks.
if it's appearing on whites mainly (hot cycle)...
This is from not enough HOT loads.
Fatty deposits gather between the basket and tub during COLD washes.
Then they are being released in large numbers when you do your whites on HOT.
It is recommended to do 1 HOT load per week.
Do an empty load with some degreaser added (like Goo-Gone) on the fullest/hottest setting you have.
Thanks for using FixYa
Feb 07, 2011 | LG WFT1071TP Top Load Washer
LG washer - loud noises & brown spots on clothes.
The drum bearing has perished this wild cause the noise and the brown spots on your clothes is probably the grease from the bearing
May 05, 2017 | LG WM2077CW Laundry XL Front Load...
Brown streaks on clothes
do you have the matching dryer on the earlier models they didn't use a seal on the drum and once the paint rubbed off they left brown rusty looking marks on the clothes
Jun 29, 2009 | Frigidaire ATF6000ES Front Load Washer
Iam getting brown spots on white shorts after washing with Kenmore front loading washing machine
If it's gunk or build up the marks should wash away. In this case run a long cycle using "affresh" or "washer fresh" with an empty load and use the hottest water available to help rinse the gunk out.
If the marks do not wash away, it could be grease due to a bearing failure. Listen for loud growling or grinding either by spinning the drum by hand or putting it into a spin cycle. If this is the case, the rear tub assembly (contains bearing) will need to be replaced. Not much can be done about the ruined clothes :(
Jan 18, 2009 | Kenmore 44102 Front Load Washer
Black, tar-like spots on some clothes after wash
Hi
Its probably coming from the outer drum of your machine. That's what holds the water. Your inner drum, what you see, is full of holes and allows the water to pass through in the drum and wash the clothes. that outer drum gets crud in it which then passes through the holes onto your clothes. the easiest way to get rid of it is to get a product called "affresh" from W mart or the big Hardware chains and follow the directions. Good Luck
Dec 10, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Clothes dryer brown marks problem
if that mark is comming from the dryer .the drum has a rust. and you cant paint it or the seal of the drum is bad that seal is around the drum.
Feb 18, 2008 | Whirlpool LTE6234D Top Load Stacked...
BLACK TAR-LIKE DEPOSITS INSIDE WASHER BASKET
THE DRUM INCLINE BOTH PLASTIC AND MEATAL SCRATCHING FROM DRUM CAUSE LIKE A CRAYON /SMALL PARTICLES , THE SUPPORT SPRING BESIDE THE DRUM ARE DETACHED NEED TO INSTALL SPRING / AVAILABLE IN APPLIANCES CENTER.
Jan 04, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Sep 28, 2007 | Washing Machines
Washing Machines Logo
23 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
