Question about Netopia (3347NWG-ENT) Router (3347NWGENT)
How do i identify the wep key for my router? - Netopia (3347NWG-ENT) Router (3347NWGENT)
  • BHastings117 May 11, 2010
    Do you mean the password, SSID (broadcast name)? Most of the time if you open a browser on a computer connected to the network and type in 192.168.1.1 it will bring you to your routers control panel. You should be able to set the wep key from there
    President:
  • 1,566 Answers
Here is the manual to WEP configuration:
http://netopia.com/support/hardware/technotes/NQG_113.html
And here is the manual for the whole device:
http://netopia.com/support/hardware/3347nwgent.html
Posted on Jul 21, 2009
4 Suggested Answers
wykidtech
  • 99 Answers
SOURCE: WEP key fro netgear DG834G v3 WIRELESS ROUTER/MODEM
Okay, first you will need to access your router (usually 192.168.0.1 or something like that) you will be asked for a user name and password. (admin password respectively if you never set these up previously)
From there you would click on Wireless Settings and scroll down to WEP Key. Whatever is typed in Key 1 is your WEP key. Write that down. Plug in those numbers for your printer and you should be go to go.
Posted on Mar 21, 2009
dante777
  • 623 Answers
SOURCE: Where can I find the WEP key on this router? Thanks!
If you don't have the manual, you can download it here.
Look at page 11 onwards.
1. Log on to your router:
  • type http://192.168.1.1 in the URL bar of your browser
  • default username and password: admin/admin
2. Go to Wireless -> Interface and you will find the WEP key there.
Just a note on security:
You should try NOT to use WEP, since it is not secure anymore.(Just google "hack WEP" and you will get over a million results...)
If your wireless cards a capable, try to use WPA2/PSK, which is the best protocol and the strongest encryption.
Tip: Use a random string of characters (like H98yh&VOrh... you get the idea). Save the Network key in a text document and copy it to a USB stick, so you don't have to enter it manually into your wireless computer.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Posted on May 29, 2009
devverma143
  • 163 Answers
SOURCE: How do I find or change my wep key? Belkin router
For this first of all u need to know the ip address of the wireless router.and its username & password.. Once u know the all this u will enter the wireless router configuration wizard.. In it go to security tab , there u can see security type and then change its wep key
Posted on May 06, 2010
Where do i find my wep key
Your WEP key, assuming it hasn't been changed since you got your wireless router, should be printed on a label on the router itself along with the router SSID that identifies your network when you see it in the list of available wireless networks to connect to.
If the key has been changed, then you would need to access the Admin web interface of the router and sign in to that in order to check what the current security settings are configured as.
The Admin web address is normally the same as your default gateway address and DHCP server address as shown when you open a Command prompt window and type ipconfig /all
Jan 11, 2012 | Toshiba Computers & Internet
Have a wireless modem. My laptop does not link though it identifies the modem
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
Jul 17, 2011 | Computers & Internet
Linksys router, I do not know my own wep code to
1. Step 1
Open your web browser, type " http://192.168.1.1/ " into the address bar and hit "Enter."
2. Step 2
Use "Admin" as the username in the pop-up box and leave the password blank.
3. Step 3
Connect to the Internet and click on "Internet Setup."
4. Step 4
Select your connection type from the drop-down menu. Choose "DHCP" for cable modems or "PPPoE" for most DSL modems. If you are unsure of these options, check with your ISP.
5. Step 5
Set a service set identifier (SSID) to identify the router and change the password.
6. Step 6
Encrypt your wireless connection using a Wireless Encryption Protocol (WEP) key. Under the "Wireless Security" option, enter a passphrase and click "Generate." This will generate a password which will need to be used by any client connecting to your router.
May 30, 2010 | Linksys Wireless-G WRT54G Router
Once I have enabled WEP, how do I set up the
Access the setup page of the router by typing 192.168.2.1 in the address bar of your browser.
Leave the password blank.
On the setup page of the router, go to Wireless. Take note of your SSID. You may also change the name of your SSID so that you can easily identify your network.
Then go to Security under Wireless.
Select 64-bit WEP. Type a passphrase then click the generate button.
Take note of the passphrase and wep key.
Then click Apply Changes.
On your wireless computer, you should be able to detect your SSID in the available networks.
It will ask you for the network key, type the wep key. On some computers, simply typing the passphrase works.
I hope this helps!
May 15, 2010 | Belkin (F5D5231-4) Router
What is my wep key
Wired Equivalent Privacy (WEP) is a deprecated algorithm used to secure IEEE 802.11 wireless networks. Wireless networks broadcast messages using a radio and are thus more susceptible to eavesdropping than wired networks.
Setting WEP up is done from the wireless security tab of your router configuration, this is usually accessed from your computer using the web address http:\\192.168.1.1 by default. It consists of a pass-phrase and a key. the pass-phrase is used to generate an encryption key, this is then necessary to use any packets (Bits of data) transferred over the air.
Beginning in 2001, several serious weaknesses were identified by cryptanalysts with the result that today a WEP connection can be cracked with readily available software within minutes.[2] Within a few months the IEEE created a new 802.11i task force to counteract the problems. By 2003, the Wi-Fi Alliance announced that WEP had been superseded by Wi-Fi Protected Access (WPA), which was a subset of then upcoming 802.11i amendment. Finally in 2004, with the ratification of the full 802.11i standard (i.e., WPA2)
Apr 08, 2010 | Toshiba Satellite A100-S8111TD Notebook
Wireless Connection Not Identified Aftre Password Was Set Up
There are a lot of reasons this could happen but I'll give you what I had to do. 1) Go back into your router and change the Wireless channel from 6 to 10. 2) make sure you have entered the correct WEP key in your network setting for the wireless adapter. The easiest way is to remove teh wireless network from your computer and let the computer find the network and prompt you for the wep key. the wep key is not the password you use to log into your router. The wep keys must be entered on all the wirelss machines in order for this to work.
Aug 28, 2009 | D-Link AirPlus DI-524 Wireless Router
What is a ssid and a wep key. I am dumb.
SSID is the wireless networks name you want to access.
WEP is a special hexadecimal key to secure your network means if you want to connect a wireless network you will have to put this key.
It will be provided by the admin
Aug 12, 2009 | Office Equipment & Supplies
Where is the SSID on my at&t router and what is the WEP Key? I am trying to connect my PS3 wireless up.
ssid is service set identifier usually sniffer software will find them. the wep wirless encription protocall is a key number usually found on a sticker on the bottom of the wirless modem, router .
Jul 09, 2009 | Acer Computers & Internet
My ipod touch has recognised the wireless networks and when i type the passwords in it sais cannot connect to network... any suggestions it is a netgear router
when it attempts to connect to your network, it is asking for the wep key
which is located on the bottom label of your wireless router.
look on your router and write down the wep key.
attempt to connect again and enter that key.
also go to settings and make sure you attempting to log into your wireless not your neighbors.
your network identifier should be on your router also.
if this helps please leave a vote in fixya
Apr 17, 2009 | Apple iPod touch
Mar 21, 2009 | NetGear DG834G 802.11G Wireless ADSL...
Netopia (3347NWG-ENT) Router (3347NWGENT) Logo
1,151 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
